How to focus moving action in a studio setting with f8 or f16?
Started Nov 28, 2022 | Discussions
goncalomp Forum Member • Posts: 57
Hi all!
So I am using a sony a74 + 28-75 tamron and have this combination during events and congresses, portraits, and it has performed super well.
But now I have a challenge, I was taking photos of my dog in a studio setting with strobes and to get his nose, eyes and ears with great focus I had to close the lens to f8 or f16, but when I do that the camera AF becomes super slow even if there is ambient light. If I open up the fstop then it is speedy again.
How does one overcome this?
I have tried raising the iso so that the camera "sees more" but it is does not seem to improve af speed.
My other settings are iso 100, 1/100th
Any help is welcome!!
Thanks!
(unknown member) Senior Member • Posts: 1,469
Re: How to focus moving action in a studio setting with f8 or f16?
im shooting f3.2 in the studio with the same combo and have no problems. are you using caf ? af is fast and accurate even dancers moving towards the camera to do leaps.
Rp
OP goncalomp Forum Member • Posts: 57
With f3.2 or f4 the af is fast, with f8 or f16 it becomes slow.
I tried animal eye, animal eye af off and all the different sized boxes. What settings are you using for your photos?
s-trap Regular Member • Posts: 205
This is because Sony cameras focus stopped down. At f/8 there is very little light and very little separation at autofocus cells.
Try setting aperture drive to focus priority.
AlephNull Veteran Member • Posts: 5,553
goncalomp wrote:
Hi all!
Thanks!
I assume you are shooting with flash in the studio? Under those circumstances you do want to be using f/8, or thereabouts, and ISO 100, or maybe the bottom of the second gain step, at most. Surprised you are at 1/100 - I am having no trouble syncing at 1/200, but I guess it depends on your lights.
I am surprised the AF is slowing down so much. I have only shot in the studio with the A7RIV and A1, and neither suffer that problem, even in studios with relatively dim ambient light.
I agree with the person who recommended focus priority for aperture drive. Let the camera focus like a DSLR, with the lens wider, stopping down for the shot. You will have ample depth of field at f/8.
 AlephNull's gear list:AlephNull's gear list
Sony a1 Sony a7R V Sony a9 III Sony FE 85mm F1.4 GM Sony FE 24mm F1.4 GM +8 more
what is your focal length ?
Rp
Lan Veteran Member • Posts: 4,791
Sounds like you need to increase your ambient light levels to compensate for shooting stopped down. More light = better AF, up to a point anyway.
Thank you everyone for the tips!
I changed the aperture drive to focus priority as suggested and it improved alot! I had no idea that setting even existed!
Thanks!
Thanks!
There are a lot of settings on these bodies, and I'd be surprised if many people used half of them. Sometimes it's worth investigating what's in the menus, and why it's there.
