Can x100v shoot tethered?
TeddyBetty New Member • Posts: 16
Hi all,
Does anyone shoot their x100v tethered? Was debating on purchasing one but I mainly shoot fashion editorials in studio. Does anyone know if the x100v can be connected to strobe lighting and the Fujifilm tethering software?
Fujifilm FinePix X100 Fujifilm X10 Leica X1
DBHH Forum Member • Posts: 59
Re: Can x100v shoot tethered?
Not sure, but I'm curious. Why would you use the travel-light, go-anywhere, fixed-lens camera in a studio environment instead of an ILC?  Is it for a Youtube channel "I shot a studio fashion shoot with the 100V!" (Yes, I'm being a little snarky but I am genuinely curious.)
When discussing the greatest images ever taken, no one has ever commented on the "Bokeh".
nand Veteran Member • Posts: 3,352
TeddyBetty wrote:
Hi all,
The X100V does not tether with either Capture One or Lightroom. It does work well with Godox  wireless flash triggers.
Nand.
Taking good photos isn't hard. Not creating poor ones is hard.
RustyRus Senior Member • Posts: 1,696
Why would you use an ILC when you could get the same results from a small fixed lens camera?
So you can sound cooler on the gear head forums and get to be rude and snarky?
If a 23mm F/2 lens work for what you need in the studio, the X100V is as good as anything IQ wise Fuji has on the streets right now minus the GFX. I will try and few programs I have and test if it can be tethered if someone else doesn't chime in before.
 RustyRus's gear list:RustyRus's gear list
Ricoh GR III Leica Q2 Fujifilm X100V Fujifilm X-Pro3 Leica M11 +1 more
