Sensor Error
Karil New Member • Posts: 2
Sensor Error
After I changed the shutter kit myself, an error appeared in the sensor, but it changes the size of the band.
There are photos that don't appear, while others are like a digital failure when saving the colors.
I have already disassembled the entire system and reassembled it 4 times to see if there was any flat that was poorly connected or damaged.
Some help?
Aoi Usagi Veteran Member • Posts: 3,221
Re: Sensor Error
Are you saying that you replaced the mechanical shutter assembly yourself?
It does not look like a "digital" failure, but a mechanical one.  The areas where there is the issue, still contains part of the image.  For example, the photo with the racing cart, still has the all the data of the image, such as the tire wall, road markings, and mountains.  It looks like the shutter is not opening completely. I would visually check if the shutter is opening and closing properly.
Some help?
Kameratrollet Senior Member • Posts: 1,106
Re: Sensor Error
