The K3 III in the comparison tool
KPM2 Senior Member • Posts: 2,076
Hello
I need your help to understand this:
In the DP Studio scene comparison tool I looked at the K3 III ISO 100 RAW file and did download it. Than I opened it in LR :
My LR has a default sharpness amount of 25, but now it use 0 !!!
with my EXIF tool I find in the XMP exact this : sharpness = 0 , SharpenDetail= 0, SharpenRadius=0.5
This picture above look's like what I see in the comparison tool window.
when I delete this XMP in my downloaded RAW file all is ok in LR:
my LR use now the default sharpness amount of 25 (and also it's defaults for SharpenRadius= 1 and SharpenDetail = 25) and even the embedded color profile
so, the numbers look's better now and also the colors.
Now I did download the Nikon Z9 RAW file in this comparison tool. I can not look at this RAW file with my LR version, but my EXIF tool show me in the XMP: sharpness =40, SharpenDetail = 25, SharpenRadius=2. Now this can be an read out error of my EXIF tool...or the XMP use really a sharpness of 40 (instead a sharpness = 0 as for the K3 III and also for a K1, K1 II and so on)
When you open this Z9 file with your LR or with an other RAW converter, is the sharpness amount really set to 40 ?
I ask you, because I simply will know if this comparison tool use via the XMP different sharpness settings.
best regards KPM2
Nikon Z9 Pentax K-1 Pentax K-1 II
PeterPentax
PeterPentax Senior Member • Posts: 1,131
Re: The K3 III in the comparison tool
I opened both dng files in Camera Raw.
The Pentax file defaults to Adobe Standard / 6850 WB (+12 tint)/exposure +0.53/sharpening 0.0
The Nikon file defaults to Adobe Color/6850WB (+14 tint)/ sharpening +40/ Color NR +25
OP KPM2 Senior Member • Posts: 2,076
+1 and thank you !
Hello PeterPentax
Thank you for to compare it with your Adobe Camera RAW tool.
So, I see in the DP comparison tool window a K3 III, K1 or K1 II RAW file with a unusual sharpness amount of 0, meanwhile the Nikon Z9 RAW file get displayed with a sharpness amount of 40 in this comparison tool window...that is not fair !!!!!
best regards  KPM2
JeremieB Senior Member • Posts: 2,041
Re: +1 and thank you !
KPM2 wrote:
Hello PeterPentax
best regards KPM2
Thanks for the finding.
So the images from K3III not only have severe shutter shock (not shot again with ES), but also have different sharpening applied ...
Makes that tool pretty much useless IMHO.
 JeremieB's gear list:JeremieB's gear list
Pentax K-70 Pentax K-3 Mark III Pentax smc FA 50mm F1.4 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc D-FA 100mm F2.8 Macro WR +9 more
Hello JeremieB
JeremieB wrote:
KPM2 wrote:
Hello PeterPentax
best regards KPM2
about this:
I use other words:  it take full effect, because the Z9 view looks  sharper as the K3, K1, K1 II view....but who know that this was made with the help of using different sharpness settings in the XMP-file...normally you see with a viewer only the EXIF, and here you see sharpness: Normal and you think the comparison view sharpness is for all  'Normal'
best regards  KPM2
James O'Neill Veteran Member • Posts: 6,117
JeremieB wrote:
KPM2 wrote:
Hello PeterPentax
best regards KPM2
A great many such tools are utterly useless. How do you compare camera bodies independent of the lens attached to them? How do you compare shooting the same indoor scene with similar settings between cameras (e.g. all the defaults) which real photographers would not use?
How do you compare (real world example) my Dad sold his Pentax and bought a Canon (in the early days of Film AF), but didn't like the Canon and stopped taking pictures.
The methodology is frequently lousy, the explanation of results poor, and to get a comparison with past results the test is often not realistic. This problem is not confined to DPR or even to photography.
 James O'Neill's gear list:James O'Neill's gear list
Pentax K-5 IIs Pentax K-1 Pentax smc FA 50mm F1.4 Pentax smc DA 18-250mm F3.5-6.3 Pentax smc FA 43mm F1.9 Limited +3 more
hikerdoc Veteran Member • Posts: 3,513
Is the issue DPR, or is the issue ACR assignment of specific default adjustments on import? Whenever I import through LR or ACR I must assign an import profile as the starting point for what I see on the screen. I have neither of these cameras but always import raw. When importing images from any of my cameras the initial image viewed can appear dramatically different depending on my choice of import default, be it an Adobe default or an Adobe interpretation of a camera profile default. This tool strikes me to be of limited value for comparing cameras; much like a DXO score which is valuable to assess different lenses on a specific sensor at a specific aperture, and of no value in comparing with the same lens on different sensors much less platforms.
even different ColorNoiseReduction via the XPM files
Hello
PeterPentax posted that the Nikon Z9 XPM setting for the ColorNoiseReduction is +25.
Now I downloaded ISO 6400 RAW files of the K1, K1 II and the Z9, where a ColorNoiseReduction do influence the look of a ISO 6400 RAW file.
The ColorNoiseReduction in the XMP file is for the K1 and K1 II = 0 ....and for the Z9 = +10.
Do you remember all the talk that the K1 II use NR in the RAW file....and now DP use per XMP (= via software) a ColorNoiseReduction view for the Z9 RAW file, but not for the K1, K1 II RAW files, because for them is's set to off (=> it's set to = 0)
BTW: my LR use presets for the sharpness and NR. For example, instead to remove the XPM file, I can also use the reset-button in LR....and than this RAW get viewed with LR's presets (default values) for sharpness and NR . Do ACR has also default values for this, like my LR ? Do use ACR for example a sharpness = 0 as a default value, or a amount of 25 like my LR ?
best regards KPM2
It's a little bit of both. DPR will say, if you reset the camera to its defaults,  and take an out of camera JPEG, or a RAW and process it in the same program without changing any settings, then that gives a good indication of the what the camera's image is like.  (With the kit lens, under artificial light, indoors, on a tripod, shooting a still life).
Anyone who has  used a Pentax knows the cameras, by default, apply the least sharpening of any brand, and "defensively under-expose".  It appears the Nikon wants sharpening of +40 and ACR / Lightroom accepts that setting from the RAW file.
People can (and will) argue at length whether camera defaults are a true base line, or if different steps are needed in ACR / Lightroom for each camera to give comparable results. Those of us who go back a long way with DPR will remember the "Canon sharpen a lot, Nikon sharpen a bit, Pentax don't sharpen" arguments 15 years and more ago. If they change their methods it means you can't do a comparison with and old test (it might have been meaningless but changing the method means it is meaningless for sure).
Re: even different ColorNoiseReduction via the XPM files
KPM2 wrote:
Hello
best regards KPM2
A Nikon user and a Pentax user would follow steps so their camera's images did got NR which was to their taste. DPR shows the defaults, and since different cameras are set up in different ways, and we shoot raw to not get the defaults, one might question the validity of the test.  If one compares Nikon and Pentax models with the same sensor (i.e. the same noise for the same exposure), the noise should be the same - except Pentax applies some pre-save NR in some models. So what would the actual user of each camera set ? DPR ducks the issue by going for the defaults.
Hello James O'Nell
about this:
for it's JPG's
that is my point: my LR default settings for my Pentax RAW files get changed do to the XMP file, where the sharpness is set to OFF (=0). Don't think that this is done do to my Pentax RAW file, it is done via the XMP file, which is included in the RAW file, when you download the Pentax RAW file in this comparison tool. That's why I used my EXIF tool, where I can delete this embedded XMP files...for to see where my LR behaviour comes from. So without the XMP file my LG use for my Pentax RAW file it's normal default settings and for the sharpness amount it is 25 (and not Off (=0).
I have not this ACR, therefore I don't know if the sharpness of 40 is normal (the default value) for the Nikon, but I don't think so, because in the ISO 6400 RAW file of the Z 9 there is used a little different sharpness value than.
best regards. KPM2
flektogon
flektogon Veteran Member • Posts: 6,226
Hi KPM2,
Regarding the out-of-camera JPEG shooting, Pentax usually allows you to set:
- fine sharpenning
- extra sharpenning
The first one corresponds to the radius of 2 In the photo editors (at least in ACDSee, which I use), while the second setting is finer, it corresponds to the radius of 1.
The sharpening "strength" can be set (in the Pentax cameras) somewhere between -4 to + 4. The setting of 0 corresponds to the sharpening amount of 50%, the maximum negative setting actually disables sharpening completely.
Peter
Hello flektogon
Thank you for your reply about the JPG's. I only know that I can match the look of the JPG's via this settings, but I personally use only RAW files. But of cause, when you see the Pentax JPG's in this comparison tool, a user like you know that the look of the Pentax JPG's depend so much on this camera settings, like for all other brands too. I think DP use here for the comparison tool the standard (default camera) settings for the JPG's, but I am not sure about this.
flektogon wrote:
Hi KPM2,
- fine sharpenning
- extra sharpenning
best regards. KPM2
Forgive me if my naiveté is obvious, but if Adobe is trying to mimic the basic profile each manufacturer designates as default to render the image visible after import is it possible that the scale or zero point assigned by each manufacturer differs? That is, as ACR interprets what Pentax assigns as “0” in default rendering may be equivalent on the ACR scale to a Nikon “40” to achieve equivalent amounts of default profile sharpening. As it is raw data imported one can then add or subtract sharpening to form their own desired profiles or import settings.
Hello hikerdoc
I can not answer this, because I use not a ACR. This only can answer users, which have this ACR and than they can say....yes, for Nikon the ACR default for sharpness is 40 and for Pentax it is 0. I can only say that my LR use a sharpness amount of 25 as a default for my Pentax RAW files....but not a sharpness amount of 0 !
best regards. KPM2
KPM2 wrote:
Hello hikerdoc
best regards. KPM2
I ask if this is Adobe ACR interpretation used in the studio comparison because I downloaded the images into ACR and get the basic sharpening setting of 0 for the Pentax .dng and 40 for the Nikon .nef. However, if I download the .nef directly into Nikon Studio NX convertor the default sharpening is listed as 0. I do not have a Pentax raw convertor to compare data there. Obviously the Nikon native convertor and the Adobe Standard profile in ACR assign different values for the default sharpening and a Nikon .nef 0 is a 40 as an Adobe .dng and a Pentax .dng 0 is a 0 as an Adobe .dng
It look's like I was wrong !
Hello hikerdoc
hikerdoc wrote:
KPM2 wrote:
Hello hikerdoc
best regards. KPM2
Thank you for your reply !
Now when you count in what you wrote and Lessiters post's I think now that my thread do have in that what I wrote a wrong conclusion ! On the other hand, I do now not understand what my LR did....using it's default sharpness amount of 25 for all my own K1,Kp DNG files out of the camera and for this downloaded K1 DNG RAW file of the comparison tool suddenly a sharpness amount of 0
best regards. KPM2
Alex Sarbu Forum Pro • Posts: 13,257
Wait... did DPR reshot and update the K-3iii samples, with electronic shutter?
But I see they only did it for the low ISO shots; from ISO 1600 there's still the mechanical shutter penalty.
Alex
"When you tear out a man's tongue, you are not proving him a liar, you're only telling the world that you fear what he might say." - George R.R. Martin, A Clash of Kings
 Alex Sarbu's gear list:Alex Sarbu's gear list
Ricoh GR III Pentax K-5 IIs Pentax K-1 II Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited +9 more
Hello Alex Sarbu
Alex
Thank you for this hint !
best regards. KPM2
KPM2 wrote:
Hello James O'Nell
about this:
for it's JPG's
The camera does not create an XMP file.  In lightroom the database holds the processing settings for each file, and the DNG files are not changed. Lightroom will read an XMP file if one exists (but only writes an XMP if catalog settings tell it to). .
If you open a DNG file in photoshop, it uses the Adobe Camera Raw extension, (ACR) which can either update the DNG file with the processing settings OR write those settings to an XMP file. The settings button configures what it does with DNG. PEF or NEF files can't be changed so those always create an XMP.
I'm seeing files set to portrait or B&W on the K1 import with sharpening +40 and colour NR 25 in lightroom and Photoshop.
best regards. KPM2
