baby spider lunch treat
jim mij Senior Member • Posts: 1,027
8
I was about to remove a gnatt/fruit fly from the windowsill when I noticed it looked odd, so I ran and got my camera to see what it actually was... a baby jumping spider
As well as the macro lens there was a 20 extension tube attached... I need to get a raynox for more control, these are probably 50% crops
2nd one is a stack or 5 using helicon - b gave best results with these handheld shots
I found it again a couple hours later, fly was long gone
1st one is a stack or 3 using helicon b
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
macrouser
macrouser Senior Member • Posts: 3,979
Re: baby spider lunch treat
Well captured.  I like to find out what the spider is eating but it is not always possible.
I found this one this month.  It is the largest of this species I have ever seen or heard of.
I don't know if it is the same species as your baby spider.  This one is near 15 mm long!
This helps to show the color pattern and eye arrangement.
 macrouser's gear list:macrouser's gear list
Sony SLT-A77 Sony a7R III Sigma 150mm F2.8 EX DG Macro HSM Sony FE 90mm F2.8 macro Sony FE 70-300mm F4.5-5.6 G OSS +2 more
OP jim mij Senior Member • Posts: 1,027
15mm! That’s massive, I’d probably run away, then pause and get a portrait lens 😀
I couldn’t even see mine without using a magnifying glass on a smudge that moved. A few mm at most. I bought a raynox250 this morning so it’ll likely be months before I see another and get to try it out
where is that spider from ?, mine was in the uk and I’ve only seen small jumping spiders here
J
macrouser
I am in South East Queensland Australia.
That species of spider is normally very small.   It was a shock to see one that big.  I often see other jumping spiders eating them.
That’s would explain it, all that heat and summer sun makes them grow, in our wet and cold they shrink, a month from now I’ll need a microscope
Jim
