Is there any way to use the EVF on the M6 II while using off camera Flash?
Bejersey
Bejersey Forum Pro • Posts: 15,383
thanks
Rick
Canon EOS M6
StevenSHH
StevenSHH Contributing Member • Posts: 609
Re: Is there any way to use the EVF on the M6 II while using off camera Flash?
Probably not possible, can you use mini HDMI cable to use on external small monitor (with hood) if you wish to use flash? or connect to your phone wirelessly or via cable.
No PC terminal.
Have fun with photography! Start taking photos!!
 StevenSHH's gear list:StevenSHH's gear list
Canon EOS M6 II Canon EF 24-70mm F4L IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 32mm F1.4
Bejersey
OP Bejersey Forum Pro • Posts: 15,383
No PC terminal.
Thanks..Steven  I was pretty sure there was not. Not great planning on Canon's part IMO. but not a deal breaker as it used it for an even Sunday
Rick
Alexis
Alexis Senior Member • Posts: 1,998
5
Bejersey wrote:
No PC terminal.
Rick
The very reason I bought M50 mk2 over the more performant M6 mk2!
 Alexis's gear list:Alexis's gear list
Canon EOS 50D Canon EOS M50 II GoPro Hero9 Black Sigma 17-50mm F2.8 EX DC OS HSM Canon EF-M 11-22mm f/4-5.6 IS STM +12 more
Photato
Photato Veteran Member • Posts: 3,152
Yes.
7
Yes, but you are limited to Flash manual mode.
1. (Slave) Set your off camera flash in optical trigger mode at the desired power level.
2. (Master) Set the M6ii onboard flash in manual mode to the needed power level to trigger the external flash.
The onboard flash can be deployed with the EVF on, no problem.
 Photato's gear list:Photato's gear list
Panasonic LX100 Canon EOS M Canon EOS M6 Canon EOS M6 II Canon EOS R10 +22 more
bgreg
bgreg Contributing Member • Posts: 641
I did exactly the same thing.I almost bought the m6ii several times but that evf hot shoe oversight stopped me each time. The $200 evf didn't help either. Great camera otherwise i understand but I figure for a thousand dollar camera I should be able to use  the evf and the speedlite  at the same time. Some people don't need it i suppose.
ericka287 Regular Member • Posts: 102
Re: Yes.Photato
I tryed all combinations.....canon flash or cheap $20 Chinese, I can't get this to fire as you suggested. Perhaps my understanding is flawed. Would you please try your system and confirm if this actualy works . I also would like to use flash & EVF for bird photography. Thank you
 ericka287's gear list:ericka287's gear list
Canon PowerShot G12 Canon PowerShot G1 X Canon EOS M3 Canon EOS M6 II Canon EF-S 60mm f/2.8 Macro USM +8 more
Rock and Rollei Senior Member • Posts: 2,899
Re: Yes.Photato
You need a flash unit with a built-in optical slave module, or a separate optical slave unit you can attach to it's hotshoe or PC cable.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
Bejersey
Re: Yes.Photato
I won't be able to use the EVF though
Re: Yes.Photato
The hotshoe foot on the flash, not the camera. So yes, you will.
Photato
Re: Yes.Photato
Your off camera flash needs to have a basic mode where it can be triggered by your camera’s  built’in flash. Read its users manual if you have it.
If your remote flash doesn’t have that capability you can get a $10 optical trigger, see picture.
The remote flash will fire at the same time you take the picture with the builtin flash.
You only need to adjust manually the power level of the remote flash and make sure the optical sensor is positioned to be triggered by your M6ii flash.
I hope this worls.
Bejersey
Re: Yes.Photato
What triggers the flash?
koenkooi Contributing Member • Posts: 919
Re: Yes.Photato
The built-in, non-hot shoe, pop up flash of the M6II
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
Bejersey
Re: Yes.Photato
The POP UP flash is not a trigger
Rick
Photato
Re: Yes.Photato
Rick
Any pop-up flash that can be set manually, can trigger an external one with optical sensor.
100% sure about this.
With my M6ii, I set the pop-up flash to manual, at the lowest power, which is 1/128 and that is enough to trigger my external Metz 48 AF-1 flash or a very old $10 Minolta Flash, or both.
Bejersey
Re: Yes.Photato
Well Then, I will give it a try.
thank you
Rick
Brian Slater Regular Member • Posts: 432
Re: Yes.Photato
I can confirm that the pop up flash does work as an optical trigger for an appropriate external flash. I use this for macro work with a small, inexpensive Meike MK320 flash. I set the M6ii flash to manual, minimum output, and the Meike to Manual S1 mode. That way I can use the EVF. No issues.
 Brian Slater's gear list:Brian Slater's gear list
Canon EOS 6D Canon EOS M6 Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm F4L USM Canon EF-S 60mm f/2.8 Macro USM +4 more
Bejersey
Re: Yes.Photato
I have the 430 ex II. I will try it
Rick
Bejersey
Re: Yes.Photato
Here's the 430 ex II manual. Can you when you have a moment check to see if this flash is compatible?
https://gdlp01.c-wss.com/gds/6/0300004116/03/sl430exii-im4-en-es-fr.pdf
Photato
Re: Yes.Photato
I'm not sure if the 430 ex ii can do Manual slave mode.
But on page 31 seems the closest thing to it.
You can try that to see if it works. Be careful not to look at the flash directly and use a low power setting so it cycles the power faster.
"Setting Manual Flash with the Slave Unit"
Hope this work.
