fuji x-h2/x-t5 crop mode
Started 5 months ago | Questions
redout New Member • Posts: 3
Hello,
I'm considering to switch to fuji and wondering if using a lenses in crop mode does the result will be good enough (i guess 20mp from a 2x crop 40mp).
Goal is to travel light with only a prime lenses. Ex: 16mm 2.8.
Suggestions / advise ?
And-roid
And-roid Senior Member • Posts: 3,208
Re: fuji x-h2/x-t5 crop mode
redout wrote:
Hello,
Here's how it works;
4:3 ratio is a 1.125x crop of Horizontal FOV, hfov, so horizontally you can see the effect, you may want to crop it to 3:2 in post but the result in-camera is that a 16mm is now a 18mm (plus 1.5* crop)
5:4 ratio is a 1.2x crop, as above, so 16x1.2 ie 19.2mm
1:1 ratio is a 1.5x crop, as above, 16x 1.5 ie 24mm
〈4:3〉 6864 x 5152 〈3:2〉 7728 x 5152 〈16:9〉 7728 x 4344 〈1:1〉 5152 x 5152 〈5:4〉 6432x5152
In all results if you shoot raw, the full 7728x5152 raw can be recovered, only the jpg is cropped!
Now you also have, sports finder mode, 1.29x crop, so the 16 becomes 21mm, but in this mode you get full view but a white border of the crop is presented. The raw and jpg are both cropped by 1.29, ie you now have 24mp image in 3:2 and raw
You also have 2 further options, 1.4x, this crops the image by 1.4x and also repositions the viewfinder so it fills the frame, completely. Now, we also have the smaller raw and jpg, ie 20.3mp and the 16mm would now be a 22.5(+1.5x crop)
as above the 2x reduces the size to 10mp and the 16mm becomes a 32mm(+1.5x crop) and the raw and jpg will also be 10mp
So, yes, you can make the 16mm work all the way 24mm to 40mm FF equivalent, without much effort and even to 50mm FF if that's what you need.
You can also just use above ratio's and converters to show the effect in-camera and then revert back to the full field of view for the shot.
OP redout New Member • Posts: 3
Thanks And-roid for your clear explanation and time. really appreciate.
Fuji-Lover-from-Belgium New Member • Posts: 1
Hi there,
I'm doing this as well, have the view mode button program to go trough the crops...and just travel with a few small lenses. Does the job for me, after all, 20 or even 10Mp is still plenty for most uses. Use mainly the 35mm 2.0
Let me know how you are getting on?
iRanN
iRanN Contributing Member • Posts: 660
And-roid wrote:
redout wrote:
Hello,
Thank you for this, i was very interested in these options before purchasing the XH2, i still wish when one selects 4:3 on camera the RAW would also be cropped and not just the jpg. After shooting with gfx for a while i just can’t go back to 3:2, i can’t and i won’t.
ChrisGibbons001
ChrisGibbons001 Regular Member • Posts: 234
Due to the 40mp sensor of the XT5 I have been using crop modes a lot for street photography, very akin to how people you the Leica Q2.
The quality does downgrade considerably if it was to be used for Wildlife or anything where fine detail is important. But for street where I usually add a little grain It works great. Its defiantly something a lot more possible now then with the 26mp sensor.
Attached an example with the Viltrox 13mm (My Fav lens atm) using 2x crop.
@bychrisgibbons
@chrisgibbonswildlife
 ChrisGibbons001's gear list:ChrisGibbons001's gear list
Fujifilm X-T5 Fujifilm XF 23mm F2 R WR XF 150-600mm
inlawbiker Senior Member • Posts: 2,066
And-roid wrote:
redout wrote:
Hello,
Thank you this is a super-helpful post so I'm reviving this thread for now. I have ordered an X-T5 and was kind of dubious about 40mp, but I never did consider that it would make crops more useful. I'm actually kind of excited about this now.
So if I have this right the modes behave a little differently. I'll use a sample focal lengths as an example.
18mm lens (28mm FF equiv) prime lens becomes:
  23mm (35mm FF equiv), in sports finder mode = 24mp jpg + full res raw file
  25mm (38mm FF equiv), in 1.4x crop mode, 20mp jpg + 20mp raw
  36mm (54mm FF equiv), in 2x crop mode, 10mp jpg + 10mp raw
23mm = 30, 32, 46., but 32 and 46 are lossy.
I think this is another way of saying, Sports Finder mode draws a box around a 1.29 crop but you still have the full res raw. Tele-convert (crop) modes really crop the raw and jpg in camera.
Of course, you can always crop a full file later if you want. But these modes are useful if you want to "use" another focal length, and compose with it in the camera, without buying a new lens. So the increased resolution really helps.
Greg
 inlawbiker's gear list:inlawbiker's gear list
Panasonic Lumix DMC-G7 Fujifilm X-T2 Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
Alan Sh Senior Member • Posts: 2,774
So, If I have a 23mm lens, do I also need the 33mm lens if Sports Finder mode does a 1.4x crop? I'm considi=ering buying both, but not if I don't need to. I have the X-T5 and a 1.4 crop takes it down to 28mp - which is plenty for printing.
Alan
 Alan Sh's gear list:Alan Sh's gear list
Canon EF-M 55-200mm f/4.5-6.3 IS STM Panasonic Lumix DMC-ZS40 (TZ60) Canon EOS M100 Canon EOS M50 Fujifilm X-T5 +13 more
GMacF Contributing Member • Posts: 999
Alan
It’s actually a 20mp file. Still plenty for printing of course but just making you aware in case that 8mp makes a difference to you.
 GMacF's gear list:GMacF's gear list
Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +9 more
No, that's still plenty
Alan
Alan
You're a little off on the conversions, but whether you "need" a 33mm lens depends. If you want to shoot a 33mm and get the full 40mp image, yes you need one.
Sports Finder vs Teleconverter are different modes that do slightly different things. So for a 23mm lens (I have one too), if I understand correctly:
23mm in Sports Finder (1.29x). You get a 30mm @24mp jpeg. You also get a 23mm 40mp raw file, per normal, as though you never used Sports Finder mode.
23mm Teleconverted at (1.4x). You get a 32mm @20mp raw + jpeg.
23mm Teleconverted at (2x). You get a 46mm @ 10mp raw + jpeg.
So a 23mm can be "used as" a FF equivalent 35, 50, or 70mm (roughly) "zoom lens" with these modes, with resulting loss of pixels for the TC modes. In either case you get a compositional aide.
Now, whether using a different focal length changes the physics of the images, I don't know. I'd leave that to smarter people than me.
If I had to guess, I would think that perspective does not change, because you're still standing in the same exact spot no matter which crop you use. But distortion is different between lenses. So if you try to use an ultra wide-angle lens cropped to a normal, the image would probably be different than if you used an entirely different lens.
Greg
Thanks Greg, I'll try the teleconverter option when I find it in the menu (I've seen it, but there's so many options, I keep losing stuff )
Alan
John Gellings
John Gellings Veteran Member • Posts: 9,742
Once this becomes a reality in all cameras (if it does), it will be "game changing" especially if you viewfinder shows the crop well and you have enough MPs to choose whatever you want to do (which, let's face it, will be the case since MPs just keep going up).
https://www.johngellings.com
Instagram = @johngellings0
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
GIo Doe New Member • Posts: 6
For info, only the sports finder mode crops the raw (for reasons to me unknown). Digital TC modes do not, you get the full sensor map in the raw and the crops in the jpegs.
pidera Senior Member • Posts: 1,033
is there also an uncropped 20 MP mode ?
I previously thought so, but it looks like the only 20 MP mode available is the 1.4 crop mode ; can anyone confirm ? Kr, P.
 pidera's gear list:pidera's gear list
Nikon D800E Fujifilm X-E1 Fujifilm X-Pro2 Nikon AF-S Nikkor 14-24mm f/2.8G ED Tamron SP 70-300mm F4-5.6 Di VC USD +10 more
Re: is there also an uncropped 20 MP mode ?
Maybe it depends on the camera. I tested my T5 before writing my previous message, and I checked again now. I confirm that the raw is the full-size 40 Mp with either the 1.4 or the 2.0 crop modes (AKA digital TC). The jpegs are 20mp (1.4x) and 10 Mp (2.0x).
The only setting that crops the raw on my camera is the sport viewfinder.
