Bluetooth pairing with xiaomi redmi 9
Started 4 months ago | Questions
LillyLo Junior Member • Posts: 41
Hello. I ve been trying to use my smartphone as a remote, i used the app but couldnt connect. Is it possible that xiaomi redmi 9 is not compatible with eos M50? Still wifi works fine, Bluetooth connection settings/   check/clear connection settings is inactive on the M50s screen. Any ideas? Thank you
Canon EOS M50 (EOS Kiss M)
StevenSHH
StevenSHH Contributing Member • Posts: 609
Re: Bluetooth pairing with xiaomi redmi 9
I have never own M50, so it's not likely I know the answer, make sure both the firmware of M50 (make sure it's not M50 mark II)
https://www.usa.canon.com/support/canon-product-advisories/firmware-notice-eos-m50-firmware-version-1-1-0
and the canon app is the newest supported by your android device, once updated give it another try and search youtube or check with canon....
Have fun with photography! Start taking photos!!
 StevenSHH's gear list:StevenSHH's gear list
Canon EOS M6 II Canon EF 24-70mm F4L IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 32mm F1.4
tvcat Forum Member • Posts: 51
1. Clear Bluetooth pairing on both phone and camera.
2. Go to camera Bluetooth settings and select pairing.
3. Turn on Bluetooth then open Canon app on phone.
4. Follow the on screen instruction to finish pairing.
OP LillyLo Junior Member • Posts: 41
How do i clear it??
It dosnt have anything to do with wifi right?
If the clear option is greyed out, that mean there is no pairing info stored.
Proceeded to reset phone Bluetooth pairing setting.
Photato
Photato Veteran Member • Posts: 3,151
Did you connect your M50 with another device before ?
If so, that might be the issue here.
If your M50 is like my M6ii, the camera's Bluetooth is limited of connecting with just one device.
The trick is to create a new connection or clear your wifi/bluetooth settings.
Then try to connect by following the on screen instructions via Bluetooth.
*Don't* attempt to connect via Bluetooth manually, Canon implementation is a bit different but after you manage to connect for the first time, next time it will seamless,  as simple as opening the Canon App from your phone and you'll be connected as long as you use the same device.
 Photato's gear list:Photato's gear list
Panasonic LX100 Canon EOS M Canon EOS M6 Canon EOS M6 II Canon EOS R10 +22 more
