X-T4 AF box placement
Resoman Regular Member • Posts: 268
Often, when I pick up my X-T4 and turn it on, the AF focus indicator has moved to the perimeter of the frame, often in the very corner; it wasn't there when I last used the AF. I typically use a fairly small AF indicator and always with the focus mode set to "S".
Any ideas?
 Resoman's gear list:Resoman's gear list
Fujifilm X100V Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +7 more
charisgratia Regular Member • Posts: 225
Re: X-T4 AF box placement
I've seen this issue come up in this forum and others. If you have the touchscreen active, it may be that the focus point is being changed accidentally by being brushed up against another surface when not in use. This has happened on all of my cameras with a touchscreen, usually when I'm walking with the camera hanging against my body. One suggestion I've seen is to turn the touchscreen function off, but I cannot go that far.
Mike Carroccio
Mike Carroccio Contributing Member • Posts: 641
Turning off the touch screen was my solution!
Michael Carroccio
San Antonio, TX USA
http://michaelcarrocciophoto.us
 Mike Carroccio's gear list:Mike Carroccio's gear list
Fujifilm X-T4 Fujifilm X-E4 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +5 more
OP Resoman Regular Member • Posts: 268
Thanks, Michael! I never thought of the touch screen because I've long ago disabled that feature on all my Fujifilm cameras. Somehow I inadvertently enabled it...
