ezriel
Regular Member
Canon 11-22mm vs Laowa 9mm F2.8. Can't Decide.
4 months ago
I've had the 11-22 for couple years and was very happy.
Recently that lens went bad, and I was in the market for a replacement.
Around same time I saw few threads regarding the Laowa 9mm as well the Rokinon 12mm.
I have tried the Rokinon since it is 2 stops faster, but decided that the 11-22 IQ is so much better, and is the better decision.
Now, I can't stop thinking about the Laowa, especially with sale discount, But can't see how it makes sense?
It has mainly 2 advantages:\
1. 1 stop faster.
2. Another 1.5mm (All 11-22 I've tried to goes extra 0.5mm)
When thinking of each 1 of the advantages in order to get to a decision:
1. The extra 1 stop is nice advantage, but not huge.
Especially when I see that for best sharpness which I care A LOT, it's has to be stopped down...
Also, for good Architecture and Scenery which is 75% of my need of UW, you also need to stop down for DOF.
On the other hand, with the 11-22 I'm getting around 3 stops, 2 more than Laowa, due to stabilization, for anything that not includes moving subject. Again. most of my shots with UWA.
Add to that the Auto focus, which IS important especially in the cases the Laowa has advantage such with fast moving subjects, and it looks like the 11-22 is a winner.
2. The extra 1.5mm, in all the UWA I've ever took, and even in many of the photos in previous threads praising the Laowa, I've almost never saw a common case (which will be important enough to carry that lens and switching to it), where that 1.5mm made the difference.
For sure there are cases, but in my experience usually either 10.5 is enough, or 9mm is also not enough.
On the other hand, going with that instead of 11-22, is a sure recipe to lose many photo opportunities where the need to switch back and forth bet. 9mm and 22 or 32mm, will make you lose.
Add to that that for that 1.5mm you sacrificing Zoom, DLO + EXIF info, Better sharpness at max aperture, and usually you pay more for that, (even now, you can get the 11-22mm with 15% off loyalty with Canon), and to my eyes that leaves the 9mm a good decision only for Astrophotography, or specialty such as Real estate where you do need that extra 1.5mm or 1 stop and not appreciate all of the reasoning above.
Am I wrong? It is still a difficult choice for me.
