Several things to look out for
6
grsnovi wrote:
I just ordered one of these for $179 USD from B&H.
Their price is $100 less than the current price on Amazon.
Yes, B&H is indeed dumping them for $100 off right now. Just the version with the Novoflex "quick release of death", not the one with the sideways Arca clamp, though. That one is still $279.
My Castle-L disappointed me almost from the start. These days, I use a couple of NiSi rails for most of my work, and only bring out the Novoflex when I need one more rail for something.
Here's some things to watch out for.
- Like many Novoflex products, there are bearing blocks of some hydroscopic plastic in the mechanism. Those swell and contract with changes in humidity and temperature, so it can jam solid on warm, humid days, and get so loose it wobbles on dry days. There are two tiny Allen screws on the side of the slider with the locking knob that will let you compensate for this.
- The Novoflex round quick release can spontaneously loosen enough to let a camera spin freely. This is dangerous as heck. I ended up drilling four holes in mine, tapping them, and screwing in pins, so they could lock into holes I'd drilled in an ARCA clamp.
- The lock knob can be spun until it falls out. It can do this all by itself in a camera bag. That happened to me at a botanical conservatory one time.
- It's 15 mm/turn of the knob. That's a bit too imprecise for focus stacking if you're going for magnifications 2x or higher.
My primary rail is the NiSi NM-180. They can frequently be found on sale for $129. The NM-180 is the current darling of the macro scene. You'll see them in Allen Walls's videos among other places. The NiSi
- Has an Arca clamp that can be unlocked and rotated 90 degrees, but won't come loose spontaneously.
- Moves 1.25mm/turn instead of 15. That's a good range for higher magnification work. Has a crank on one knob to help you make long adjustments pretty quickly.
- Although the locking knob can be removed like the Novoflex, this rail has a fine-pitched lead-screw and will stay put without the locking knob, even when vertically oriented. (I think it only has a locking knob in the first place because some of its rack-and-pinion competitors like Novoflex do).
- Has 160mm range of motion, as opposed to 140mm for the Novoflex.
- Has a distance scale that's much clearer and easier to read than the Novoflex.
- Doesn't lock up on humid days. I believe the track adjustment is metal, although it has a two screw adjustment system like the Novoflex, I've never needed to adjust it.
NiSi also has the slightly more expensive NM-200 with a 180mm adjustment range, and a release mechanism so you can pull the lever, slide the carriage smoothly to anywhere on the rail, and release it to lock it back onto the headscrew. Unfortunately, it's $200 and never seems to go on sale.
I also have a Haoge FM-160. That's a dirt-cheap ($70) rail which has a 4mm/turn leadscrew, a non-rotating Arca clamp (that, unfortunately, is sideways so it can't work with my 200mm f/4 Nikon.
Note: about drilling holes...
I've drilled and tapped holes in the Novoflex Castle L and the Novoflex Magic Ball head. A long time ago, I wanted to make an anti-twist Arca plate for my Nikon PB-4 bellows. The PB-4 has one standard 1/4-20 tapped hole in the center, and 8 untapped 6mm holes around it in an octagon, each hole being 20mm from the center. So I drilled 4 holes in my Arca plate, tapped them, and added Allen screws with 5.6mm heads. The amount of torque needed to sheer that would be enormous.
Later, when I got the Novoflex stuff, I noticed that both the Castle L and the Magic Ball can let loose with catastrophic suddenness. I added the same pattern of Allen screws to them, and made some Arca clamps with the same holes as the PB-4. I jokingly call this the "X-20" standard, 4 holes in an X with 20mm arms. 4 holes in an X means I can remove and replace the Arca clamps 90 rotated 90 degrees.
Sounds like a lot of bother, and it is, but it's really the only way I've seen to make the Novoflex stuff safe to use.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
