Should I stay with Pentax?
Adam Rich New Member • Posts: 6
Pentax is the only brand of DSLR I have ever had. I own a K100D, K-x, and a K50. Unfortunately, the K50 is dying the sad slow solenoid death, and I am debating on what to do next. I only have a handful of non-kit lenses, the Sigma 170-500mm and a Tamron AF 28-75mm f/2.8. I have been debating whether I should move to another camera system or stay with Pentax. I need to make a decision fairly soon as I am taking a big trip over thanksgiving and would like to have a good camera. I really don't have the money to spend much more than $1500. I thought I could possibly get a used K3 Mark III, or I could jump into another system's basic camera with a kit lens or two. But I figured I would ask you guys that have way more experience with these cameras than I do what you feel is the best way to go.
Pentax K100D Pentax K-50 Pentax K-x
Younes B Senior Member • Posts: 1,257
Re: Should I stay with Pentax?
10
With your budget, your best move would be a good condition K5iis ( you can find it used in the $350-$450 range, in great shape ) and you'll have money left on hand, for both a 21 limited & 15 limited.
See what it does:
 Younes B's gear list:Younes B's gear list
Pentax K10D Pentax K-30 Pentax K-5 II Pentax K-5 IIs Pentax smc DA 15mm F4 ED AL Limited +6 more
James O'Neill Veteran Member • Posts: 6,117
Do you like using the Pentax kit you have ? Does it do the job(s) you need it to do? If the answer to either of those is no, change. If the answer to both is yes, stay.
If I were looking to buy another APS-C body, and the K3-iii was too expensive, and the KF didn't quite cut it, I'd look at used K3 / K3-ii bodies. The K3 is new enough to work with all modern lenses, produces images that are plenty good enough, but for some uses the AF shows its age. There are lightly used MK I bodies selling on ebay for peanuts, then spend the rest of your money on lenses.
The alternative is to find another brand that you do like and does the job. Then you have $1500 + whatever your Pentax gear sells for - don't rule out buying used if you go that path either.
No-one else can say which option is best for you, and if you leave whether it should be for Canon, Fuji, Nikon, Sony or whoever.
 James O'Neill's gear list:James O'Neill's gear list
Pentax K-5 IIs Pentax K-1 Pentax smc FA 50mm F1.4 Pentax smc DA 18-250mm F3.5-6.3 Pentax smc FA 43mm F1.9 Limited +3 more
flektogon
flektogon Veteran Member • Posts: 6,226
Those are really nice pictures, Younes (B)
Peter
The Squirrel Mafia
The Squirrel Mafia Senior Member • Posts: 1,017
If you don't want to spend too much money & want a trouble free experience, provided the body wasn't abused, a used K-3/3II, KP, or a used K-5II/IIs would be the ticket. The K-5II/IIs can run newer KAF4 lenses, but can't control their aperture. Lots of used bodies on eBay & sites like MPB or KEH. Pentax Forum will have some bodies in its marketplace as well.
According to several Pentax users, the latest version of the Pentax K-70 should be 100% trouble free, even though it's still using a solenoid. The KF will be replacing it soon. It's basically a K-70 with a few minor tweaks, but the cost will go up.
Keep in mind that any switch that is worth it is going to cost a lot of money. I wouldn't bother with a basic camera & kit lens. Not worth a switch. Lots of great options, but you're gonna have to pay to play. There's Sony, Nikon, Fujifilm, & others.
 The Squirrel Mafia's gear list:The Squirrel Mafia's gear list
Pentax K-3 II Pentax smc DA 21mm F3.2 AL Limited Pentax 11-18mm F2.8 Pentax DA* 16-50mm F2.8 ED PLM AW Pentax K-50 +10 more
kypfer Contributing Member • Posts: 985
Given that you already own the Sigma 170-500mm and a Tamron AF 28-75mm f/2.8, replacing these for another system would likely screw your budget before you've even considered a decent body to put them on.
A K-70, if you can still find one, will suit your needs nicely.
The K-70 replacement, the KF, will be more expensive but still well within budget.
Even a K-3iii should be just about manageable, body only, seeing as you already have the lenses.
So … personal opinion … stick with Pentax
Remember, even if your K-50 is "dying", it's not irrepairable and you can still use it in manual mode as it is, with the appropriate lenses
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
klimbkat
klimbkat Senior Member • Posts: 2,659
7
My daughter's 5-year-old K70 recently had an aperture failure, so I got her . . .  another K70. It is still a great camera, has improved solenoids now, and is under $600 new. B&H currently has a package with the WR 18-135 for $827. That would be a great replacement for your K50, will use your existng glass, and will not break the bank.
Good luck and good light.
henryk1 Senior Member • Posts: 1,236
I had this dilemma two years ago and wanted a full-frame brand that kept up with the times, so bought a Sony A7Riii. Later, for travel, I bought a Sony A7c. I use them both, but not exclusively. I actually prefer the old K-01 and 40mm XS lens as a knockabout camera for daily outings around the block, and my wife loves my K-3 with 18-135 lens. Old kit often finds new uses.
Pentax H1a, H3v, Spotmatic, MX, ME Super (2), KX, *ist DS, K10D, K20D, K-5, K-01, K-3; Sony A7Riii, Sony A7c.
Adam007 Contributing Member • Posts: 805
For years, I have pledged to stop buying new Pentax lenses, but I keep forgetting this pledge.  I have tried two different high-end  MILCs, but ended up returning them with.  I am not sure what I will do - maybe transition to something else while keeping enough Pentax kit around to have fun.
What I would NOT do is buy into a new system in time for Thanksgiving.  If that k50 works ok, bring it and a nice phone to Thanksgiving and hope for the best.  You can start shopping on Black Friday, taking advantage of the very generous holiday return policies.  The new Fujis are nice, if you want to stick with APSC.  Good luck!
 Adam007's gear list:Adam007's gear list
Fujifilm X100F Pentax K-1 Pentax K-3 Mark III Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 31mm F1.8 AL Limited +7 more
OpticsEngineer Veteran Member • Posts: 7,839
My experience getting a new camera right before a trip was I got poorer shots on the trip than I should have because I was not up to speed on the new cameras quirks.
Of course it depends on what camera.  Generally I have had little issue with going between older Pentax models.   But it did kind of throw me when they changed how Auto ISO works a few years ago.
The K3III has a whole new GUI compared to older Pentaxes.  I have found it easy to use but I don't know about switching to it right before a big trip.
But if you are just wanting to switch brands quickly for some reason, Canon has  the most logical and easy to switch to GUIs.  I have found it almost boring how easy it is.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Pentax *ist D +27 more
flektogon
Well, not the most reliable solution, but still worth risking:
A new Pentax K-70 with DA 18-135. Great IQ, great flexibility and well below $1000.
Peter
Gary Martin
Gary Martin Veteran Member • Posts: 5,301
As someone who has flirted with switching (or migrating, whatever you want to call it), I would suggest proceeding with caution. I've spent a lot more money than necessary, just to discover that the old cliché is true: the grass does always seem greener on the other side. In the meantime, as another poster has suggested, try picking up a used K5IIs, and use it with your existing lenses while you contemplate your future goals with photography. The K5 is built like a tank, gets great battery life, and you'll appreciate how nice it feels in your hands compared to your previous camera. And the sensor in the K5 makes beautiful files. So, save your money for more important things, and bring a K5IIs on your trip and have fun. Just my humble opinion
 Gary Martin's gear list:Gary Martin's gear list
Ricoh GR III Pentax K-1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R +9 more
MarBa Senior Member • Posts: 1,038
Maybe you should also say what kind of shots you are doing the most. There are some weaknesses that the current offers from Pentax have and switching to another system could give you far better experience .. so it might be worth some extra cash.
Best,
M
 MarBa's gear list:MarBa's gear list
Pentax K-1 Pentax K-3 Mark III Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +6 more
zakaria
zakaria Veteran Member • Posts: 6,556
A used k5iis and keep the rest $$$ for the trip.
pentaxian .
 zakaria's gear list:zakaria's gear list
Fujifilm X-H1 Pentax K-1 II Fujifilm X-T3 Nikon D780 Pentax smc FA 31mm F1.8 AL Limited +8 more
OP Adam Rich New Member • Posts: 6
Best,
M
I mainly do landscape photography, with the occasional event I take photos of. Very little if any sports. I'll be in NYC for Thanksgiving which is why I wanted to try and figure out what to do. I think I will stay with Pentax, I'm just debating between the K70 kit or a used K5II and a new prime for landscape.
xmeda
xmeda Senior Member • Posts: 1,899
Here in Europe, when used USD$ as comparison value:
2nd hand K3 (mk1) is around $450
2nd hand K5IIs is around $450 and are a bit rare
2nd hand K5II is around $400
2nd hand K5 is around $350
So the obvious choice is the K3..
K30/K50/K70.. that are all bodies with solenoid issue risk included. I just ignore those.
Somewhere between is KP which is also in $500-700 price league depending on how used it is. But if you give me hoice between K3 and KP, my reaction would be
http://pentax.xf.cz/ - Personal page about my favourite system.
 xmeda's gear list:xmeda's gear list
Casio QV-R40 Casio Exilim EX-Z110 Olympus XZ-1 Pentax X-5 Olympus XZ-2 iHS +42 more
bob5050 Senior Member • Posts: 2,948
Depending, of course, on how you prioritize those issues. Don't underestimate the question of use enjoyment--most modern cameras will give you great pictures most of the time; differences tend to be in marginal situations, and depend a lot on who you are as a shooter.
On the money side, FWIW the US Pentax site lists the K-70 at $579.95. If it's still in stock, that's a pretty good deal.
https://us.ricoh-imaging.com/product/pentax-k-70/
bob5050
All pictures I post here are SOOC, downsized 50% unless specifically identified otherwise.
 bob5050's gear list:bob5050's gear list
Fujifilm XP130 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Sigma 17-50mm F2.8 EX DC OS HSM +6 more
bkpix
bkpix Senior Member • Posts: 1,013
Adam,
Another vote here for the K-5 IIs. They're available at KEH.com for under $300, and you get a warranty. It's a marvelous, tough little camera and feels exquisite in the hand.
I shot for several years with a K-5 and a K-5 IIs, mostly -- like you -- shooting landscapes and a few events. The camera was great for both.
These days I'm shooting with a pair of KPs -- a beautiful little camera, though more expensive and harder to come by -- but could easily go back to the K-5, which has better battery life and is built a little tougher than the KP. The main things I like about the KP are the compact size, the flippy screen, and the amazing high-ISO image quality.
I tried all three versions of the K-3, but never bonded. That's in part because I'm using a Canon R these days for birds and wildlife, and partly because I don't like the K-3 III's bulk.
Good luck with your choice.
Bob
 bkpix's gear list:bkpix's gear list
Pentax KP Canon 6D Mark II Canon EOS R5 Canon EF 135mm F2L USM Canon EF 28-135mm F3.5-5.6 IS USM +12 more
KPM2 Senior Member • Posts: 2,076
Hello Adam Rich
The K 5IIs don't have an AA filter and that's very good. Like others write, that is a good solution.
On the other hand, the K5 types don't got the update for that they can use the lens with the electric aperture...like the DA 55-300mm PLM.
In your situation, with the lens you have, you cover already a wide focal range, but you have with the 28mm only a mild wide angle lens. Maybe for your trip you add a 18mm focal range to it.
So, that is not really a decision: I would maybe get a K5 IIs and something around 18mm and than you have all the time to find later the camera you will use in the future.....the K5 IIs you can sell for sure with only a little loss, because it's the only K5 model, which has no AA filter.
best regards. KPM2
12
Thank you everyone for your suggestions. I ended up ordering the k70 kit and a Pentax HD Pentax DA 21mm f/3.2 AL Limited Lens to use as my walk about lens in NYC next week.
