Close Up Filter on Wide Angle Lens
Oceanmonkey123 New Member • Posts: 23
As a Macro/Close Up photographer (Flora and Fungi) I have been looking at options to get a wider field of view in then a dedicated Macro lens offers.  I own the Z105MC.  I have looked at the Venus Optics 15mm Macro lens but not quite what I want as the focus distance is virtually non exsistent so have wondered about using a Close Up filer on my Nikon Z14-30 lens.  As an 82mm filter is well in excess of £100, before I purchase has anyone tried anything like this.   Maybe there would be a better lens option if someone can think of !
I am not looking for life size but generally closer focus than what is standard on this lens.  Would there be a better lens option on Nikon Z Full Frame ?
Maybe someone has put together something like this before
 Oceanmonkey123's gear list:Oceanmonkey123's gear list
Nikon Z50 Nikon Z6 II Nikon Z 24-70mm F4 Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR +3 more
BBbuilder467 Veteran Member • Posts: 7,057
Re: Close Up Filter on Wide Angle Lens
What diopter strength is it?
I have an ultra-wide zoom and never thought to try that. I'll have to try to find my old close-up lenses and see what it does.
Joseph S Wisniewski Forum Pro • Posts: 35,461
Try an extension tube, or a reversed lens
The only close-up lens I can recall that comes in 82mm is Hoya, and it's a plain single-element, which will give you quite a bit of chromatic aberration. It's also fairly low power. Remember, 14mm is 71 diopters (1000/14mm) and 30mm is 33 diopters. To get 0.5x magnification, you have to pile about half that in front of the lens, and getting to 15 diopters with closeup lenses would be a pain. It would also have a short working distance, which combined with that honking big 82mm front will be difficult to light.
There are Z extension tubes which cost less than a single element closeup lens but deliver higher image quality. I have a Meike set with an 11mm and 18mm tube that cost me $40 US, about £32. The problem is that the front node is pretty far back in a wide angle zoom and if you add extension, you will quickly run out of working room. Extend too far, and you hit a point where the subject actually has to be inside the lens. (You'd have this same problem with a strong close-up lens: anything you do to try to get high magnification out of a 14-30mm zoom is going to bring the subject almost into contact with the lens.
Duct tape!
(That's only half a joke. My first high magnification macro experiment was done using a technique called "coupling". Since the two lenses I was coupling together had the same filter size, and since I barely had enough money for film, let along the $10 it would have take to improvise a coupling ring, I duct taped the lenses together).
When you put a lens on your camera, and then attach another lens to it face-to-face with a little adapter called a macro coupling ring, you get magnification equal to the ratio of the two focal lengths, and a working distance of approximately the "back focus" (rear element to image sensor distance) of the reversed lens.
The problem is that this is a technique only useful for magnification from 1:1 on up. But you can get high-quality wide-angle setups with decent working distance this way. A reversed 50mm f/1.8 F (not Z) in front of a 24-70 Z has potential.
I'd seriously start with the extension tubes.
All sorts of things.
I have an idea. Let me get back to you in a day or two.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
I tried a +4 and +6 at 9mm with a micro 4/3 and it did gain image size, but narrowed the angle of view of the background at the same time. It looks a lot like I just cropped the image of just zoomed to 18mm without the diopters.
Donovan L Regular Member • Posts: 104
hey joseph!
Duct tape!
it's been two days.
just sayin'
yes, most everything is in lower case. i'm mildly arthritic and seldom use my pinkies when i type.
 Donovan L's gear list:Donovan L's gear list
Nikon Z7 II Nikon Z 24-70mm F4 Nikon Z 50mm F1.8 Nikon Z MC 105mm F2.8 VR S Nikon Nikkor Z 28mm F2.8 (SE)
stitched panorama head?
so do i.
have you considered stitching panoramas? i use a nodal ninja mk3 (it's the 2nd heaviest piece of photographic equipment i own, so that tells you much i like it). i've never tried it outside with fungis (funges?) but i have done wildflowers outdoors and all sorts of still lifes indoors. the hard part is adjusting your panorama rig so the nodal point is exactly centered. once you do that, 3 vertical shots gets you to something like a 50mm but at the 100mm's working distance, and 2 rows of 4 shots will get you down like a 30mm. i think you'd need to go about 3 rows of 6 shots to match a 20mm.
if the 50mm had enough working distance you could get to 30, 20, even 15mm equivalent with much less shots than the 105.
sorry. that's where i pick the brains of someone like joseph.
Re: stitched panorama head?
so do i.
I made the assumption the OP wanted the dof of the ultra-wide close-up with more magnification. When I added the diopters, I seemed to lose as much as I gained.
Hey L!
it's been two days.
just sayin'
Running in slow-mo right now. My head is pounding, my throat is itchy as heck, and I have a light cough. Covid test negative, temperature normal.
I think yardwork triggered my allergies.
Ciao! Joseph
Re: Hey L!
it's been two days.
just sayin'
well, i hope you feel better soon.
vitamin c and garlic, just in case it isn't allergies.
