G7X Mk.III --Have the Niggles Been Fixed?
Nyalgy Bubu
Nyalgy Bubu Regular Member • Posts: 116
About 3 or four years back, I [twice!] bought the Canon G7X Mk.2 and twice sent it back as, although I loved the hardware, I just couldn't get on with the way the camera worked in software.
I wrote a post about it at the time:
https://www.dpreview.com/forums/thread/4168536
One of my main bugbears with the camera was the lack of info in the viewfinder when in either Aperture or Shutter priority mode. ie. as you changed aperture or shutter speed, the viwfinder info didn't update in real time to show you how the other setting was changing. Or as Kenneth123 succintly explained it in that thread:
What is odd to me is that in AV (or TV), the display only shows the value that you're actually adjusting, but not the corresponding related value, until you half-press the shutter. In other words: if I'm shooting in AV, as I adjust the aperture I don't have any real time information on what's happening with the shutter speed. When I go to half-press the shutter, it will tell me the shutter speed that it's about to use for the exposure, but it doesn't provide that information simultaneously with my adjustments of the aperture.
By comparison, my Canon DSLRs, and my Sony DSC-RX100 Mk. 1, always show these values linked. So, as I adjust the aperture I'm instantly able to view the change on shutter speed.
Am I missing something? I get from the above that the AE lock can give me this information, but only if I actually lock the exposure first. It seems awkward that this information can only come up if AE lock is used.
So, as the title asks; have these things been 'fixed' in the G7X Mk.III or is it still functionally the same, software-wise?
Canon G7 X II Canon G7 X III Canon PowerShot G7 X
Pap38
Pap38 Veteran Member • Posts: 4,143
Re: G7X Mk.III --Have the Niggles Been Fixed?
You answered your own question. Use the cameras that do you bidding!
Pap
 Pap38's gear list:Pap38's gear list
Panasonic Lumix DMC-FZ28 Panasonic Lumix DMC-ZS8 Canon G7 X III Nikon D60 Nikon D5100
KEG
KEG Veteran Member • Posts: 4,910
I got curious so I tested this on R, M3, M6 mk I and M6 mk II, both R and M6ii have FV so they both support this but the others not.
G7 X III around the same age as R and M6ii so I guess that it is possible for it to have it also but on the other hand, this is something I have never noticed and has never bothered me.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
KEG
For another just fun check I tried my ancient Lumix G3 and it also shows shutterspeed when I change aperture.
KEG
KEG
SX60 behaves the same way as the older cameras.
KEG
