Blood Moon 😡
Started Nov 10, 2022 | Discussions
fotoword
fotoword Contributing Member • Posts: 626
Blood Moon 😡
12
Blood Moon from a couple of nights ago in Sydney (Australia)
XT4 100-400 tc1.4 on a tripod
pp in C1 and Topaz AI
Guess it's a bit boring but I don't normally shoot for the moon and I went outside and saw it was red so I thought I'd better take a picture.
We haven't seen clear sky in a while here.
Tried handheld at first but realised I needed a longer shutter speed so it came the tripod.
I haven't used the xt4 much since I got the xh2s and then the XE4. I seemed to spend an eternity trying to set up the camera on the tripod and then work out how to focus. Tried continuous, manual then settled on single af with a square covering the moon.
Anyway I think I got some half decent shots.
C&C welcome.
Cheers
Paul
 fotoword's gear list:fotoword's gear list
Pentax Q7 Fujifilm X-T1 Panasonic Lumix DMC-GM5 Canon EOS M5 Olympus E-M1 II +44 more
Peter M J Contributing Member • Posts: 872
Re: Blood Moon 😡
Hi Paul
A good effort Photographing the Moon is not as easy as it seems. The earth and the moon are both moving quite large distances IN ONE SECOND
Here is one of my efforts ( with exposure details etc ) Its a little bit oversharpened
I used a tripod- Why not try again with a faster shutter speed ?
REGARDS AND BEST WISHES PETER
 Peter M J's gear list:Peter M J's gear list
Nikon D850 Nikon Z7 Nikon Z6 Fujifilm X-H2S Nikkor AF-S 300mm f/4E PF ED VR +3 more
fotoword
OP fotoword Contributing Member • Posts: 626
Re: Blood Moon 😡
Peter M J wrote:
Hi Paul
Hi Peter
Thank you.
I definitely did not find it easy lol.
There were too many things going wrong from tripod not cooperating issues to forgetting where any camera settings were on my xt4.
The movement of earth and moon didn't help.
That is amazingly sharp and detailed.
I chose a one second exposure because I was not getting much of an image at the faster shutter speed and I wanted to reduce ISO from 6400 to 3200.
I did try shorter durations but they were either too dark or for some reason the was shake it very obvious motion blur funnily enough.
Thanks for the reply and the connects
Cheers
Paul
Feugi Regular Member • Posts: 211
Re: Blood Moon 😡
fotoword wrote:
Peter M J wrote:
Hi Paul
Hi Peter
Thank you.
Cheers
Paul
Hey Paul,
I'm a fellow moon enthusiast as well. The moon should never be shot at a shutter speed less than 1/125th in my opinion (unless you have a tracking mount). Were you accidentally shaking your tripod when using faster shutter speeds? Try to use the 2 second self timer feature to allow the lens to stop its shake. When shooting a regular full moon, my typical settings are base iso (160), shutter speed around 1/180th, and aperture of f8.  The blood moon or lunar eclipse is much darker so maybe 1/125th of a second, f8, and then adjust ISO to get things looking right in the viewfinder (possibly ISO 800)
 Feugi's gear list:Feugi's gear list
Fujifilm X-T3 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Sigma 150-600mm F5-6.3 | C Fujifilm 16-50mm F3.5-5.6 II Fujifilm XC 35mm F2 +3 more
fotoword
Re: Blood Moon 😡
Fuegi wrote:
fotoword wrote:
Peter M J wrote:
Hi Paul
Hi Peter
Thank you.
Cheers
Paul
Hey Paul,
Most definitely, there were 2 issues, 1. not using the timer and 2. when using the timer, grabbing the camera when the exposure started (the beep threw me off). I got plenty of really bad shots.
In terms of tracking mount the camera and tripod were off doing there own tracking as for some reason the arca Swiss p0 ballhead seemed to sag a little, which didn't help.
I guess I was already at f8 with the tc.
Your settings surprise me but I checked some previous photos I'd taken of a normal full moon a few years ago with an Olympus em1 and they were at 1/400, ISO 200 f8.  I think that time I was trying to cut down the light to get some detail.
Heavily cropped Oly em1 image
This image has a little more detail in it.
I try to shoot the moon at least once every 4 years or so lol.
Thank you for commenting, really appreciate the tips.
Cheers
Paul
baobob
baobob Forum Pro • Posts: 18,761
Re: Blood Moon 😡
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
GMacF Senior Member • Posts: 1,241
Re: Blood Moon 😡
I find the use of a tripod for shooting the moon rather unnecessary. If you have time and the inclination to set one up then you’ve nothing to lose of course.
I usually just shoot at 1/125 or higher and hand hold in CH burst mode. I might take 40-50 frames and I usually manage to get 75% tack sharp. It also helps if you want to stack in post later on.
 GMacF's gear list:GMacF's gear list
Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 27mm F2.8 Fujifilm XF 50-140mm F2.8 +9 more
