Fujifilm X-E2 would always shoot dark photos on Auto shutter/iso on bright environment
Started 5 months ago | Questions
ableslayer New Member • Posts: 6
I've always shot with my X-E2 with 35mm 1.4 on a bright sunny day with this settings before I updated it:
  • Dial Shutter: A
  • Dial Exposure: "0"
  • ISO Auto 800
Now I have updated my firmware and whenever I take a photo on a bright environment, my LCD is very dark although when I press the shutter, it will light up a little and turn back to very dark again. The actual photo is also very dark,
The only thing I can at least make my LCD preview bright is when I dial my shutter to 180x but that will still be dark. Even higher like 125 and up then my shot will be blurry. I also try to make the ISO higher at around 1600 auto but same blurry photos.
Here's a video where I'm testing it very near to a window where its very bright outside with my iPhone. You can see the settings that I use on the LCD and the actual settings of my dials. Please suggest what can be done with this. I have already reset my settings but still the same thing happen.
Fujifilm X-E2
allineedislight Senior Member • Posts: 1,311
Re: Fujifilm X-E2 would always shoot dark photos on Auto shutter/iso on bright environment
What's your photometry setting?
And your aperture setting?
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
Fz2000user uk Senior Member • Posts: 1,509
It looks like the rear dial has over rode the ‘A’ option on shutter dial.
check custom settings for your dial.
shutter speed showing fixed at 1/4000
its also showing your in manual mode.
What’s this full frame malarkey then….
 Fz2000user uk's gear list:Fz2000user uk's gear list
Olympus OM-D E-M1X Fujifilm FinePix IS-1 Fujifilm X-S1 Sony RX10 II Nikon Coolpix P1000 +5 more
OP ableslayer New Member • Posts: 6
My photometry settings seems to be Spot. My apperture settings is A + M but I cannot change it. Here's a video of my settings. If you can help spot the problem that I can change, I'll appreciate it.
Thanks!
I can see now that on the bottom left, I'm on manual mode. But how can I get out of manual mode? How can I change that setting? I tried changing a lot of the settings but none seems to work.
Here's another video to show my settings. If you can please help to check what I need to adjust. I hope this is enough but if it's not I'll take more videos. Thanks!
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,432
Front of camera next to Lens
Look at the front of the camera.
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
Happy JPEGer Contributing Member • Posts: 897
In the clip, you turn the camera around (lens facing you) and you switch from M to S at the same time.
Put it on Auto and see if the photos are still dark.
 Happy JPEGer's gear list:Happy JPEGer's gear list
Fujifilm X100S Fujifilm X20 Fujifilm X30 Leica Q2 Olympus TG-6 +9 more
Rotate the rear dial until shutter speed changes from 1/4000 to “A” so it matches your top shutter speed dial.
Mczar2u Regular Member • Posts: 227
I think I know what is going on.   I dont have the X-E2, but in some cameras you have the option to manage Shutter speed with one of the wheels when you put it on A (aslo called Command setting) , rather than being really in  Auto. Is a setting in the Menu
In the screen I can see that the shutter speed is in blue, with the 1/2 wheel on top, this indicates that you are not really on auto speed, but it is in Command, and you have to control the shutter speed with the back wheel.
I think is in wrench 2, button/dial settings, to change the option to Auto
Mario
I figured out the problem now. In this video, you can see that the dial is not responding properly after I set the SS dial to more than 15.
So when I rotate the SS dial from 4, 8, 15, the blue indication on the bottom left changes correctly. When I finally change it to 30, the blue indicator at the bottom stays at 15. So
Dial == Indicator
15 == 15
30 == 15
60 == 30
125 == 60
4000 == 2000
A == 4000
Meaning, it's not actually turning to "A", it remains at 4000 because when the dial turns to 30, the indicator did not change to 30. So I'm shooting at 1/4000, not auto.
Is this a hardware problem? I really thought this changed  when I updated the firmware.
Mario
Dial == Indicator
15 == 15
30 == 15
60 == 30
125 == 60
4000 == 2000
A == 4000
nightowlnz
nightowlnz Contributing Member • Posts: 518
Others that have had similar issues, generally it is a hardware fault requiring repair or replacement of the top plate by Fujifilm.
 nightowlnz's gear list:nightowlnz's gear list
Fujifilm X-T4 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR
KennyXYZ
KennyXYZ Contributing Member • Posts: 567
I used an XE-2 for about 6 years and during that time I had a problem after I had updated the firmware. I sent the camera back to the camera shop where I had bought it. When the camera shop returned the camera I noticed that they reset the firmware to the previous version. I was always under the impression that a firmware update cannot be undone, but it is what it is and the camera worked as before the update.
 KennyXYZ's gear list:KennyXYZ's gear list
Fujifilm X-T4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR +2 more
I wonder if I can just downgrade the firmware and it will all be back to normal or do I need to send it to the fujifilm service center for them to fix it. In anyway, I'll email them and tell them the problem. Thanks!
Tiajjm Junior Member • Posts: 47
I'm following this thread...The exact thing happened to me last night while trying to shoot in low light. I never use this camera for low light so I had never noticed the problem after I upgraded the firmware.
 Tiajjm's gear list:Tiajjm's gear list
Nikon D750 Fujifilm X-T30 II Fujifilm X-H2S
