AF-area using 600mm/f11 and 800mm/f11 with EOS R6 II surprises a bit...
Stig Nygaard
Stig Nygaard Regular Member • Posts: 385
5
I just thought some would fine this interesting.
The AF area using RF600/11 and RF800/11 on EOS R3 are larger than when used on the R6 or R5. Since they are all fullframe cameras, there are no crop-factor to explain that. My theory was it had something to do with R3's sensor being stacked. But apparently there are other factors involved. It turns out the R6II offer same 80%x80% AF area as the R3 when used with those lenses...
HxW:
R5/R6: 40% x 60%
R7/R10: 60% x 80%
R3: 80% x 80%
R6II: 80% x 80%
https://cam.start.canon/en/H001/supplement_0110.html
 Stig Nygaard's gear list:Stig Nygaard's gear list
Olympus TG-5 Canon G5 X II Canon EOS 7D Mark II Canon EOS R7 Canon EF-S 10-22mm F3.5-4.5 USM +18 more
Canon EOS R6 Mark II
Duckman21 Regular Member • Posts: 273
Re: AF-area using 600mm/f11 and 800mm/f11 with EOS R6 II surprises a bit...
HxW:
R5/R6: 40% x 60%
R7/R10: 60% x 80%
R3: 80% x 80%
R6II: 80% x 80%
Makes you wonder about the "hammer"! The EF 100-400mm II + 2X Extender (effectively 800mm f11) apparently supports the full AF area.
What I'm curious is whether AF acqusition is actually faster or not. On my R6 I find the 800 f11 usually tracks nicely but struggles to acquire focus at times. While not as rampant as the Sigma or Tamron 150-600mm, it does have occasional episodes of losing focus (bordering on pulsing).
Instagram @FYLegend21
500px @frankyboy5
 Duckman21's gear list:Duckman21's gear list
Canon EOS Rebel T6s Canon EOS R6 Canon EF-S 18-135mm F3.5-5.6 IS STM Tamron SP 150-600mm F5-6.3 Di VC USD G2 Canon RF 800mm F11 IS STM
MaStErPsX
MaStErPsX Regular Member • Posts: 203
Very good news
 MaStErPsX's gear list:MaStErPsX's gear list
Canon EOS R6 Mark II Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4.0-7.1 IS STM Canon RF 85mm F2 Macro IS STM +6 more
koenkooi Contributing Member • Posts: 919
HxW:
R5/R6: 40% x 60%
R7/R10: 60% x 80%
R3: 80% x 80%
R6II: 80% x 80%
My guess would be that the angle of the microlenses plays a part in it. When Canon reused 'old' sensors in the R and RP, they didn't have 100%  coverage. More recent sensors expanded that to nearly 100%. Again, this is just a guess: I think the microlenses near the edge are angled in to deal with wide angle lenses with a short backfocus distance. On EF the lightrays would be a lot closer to perpendicular due to the large flange distance. On RF the lenses can be a lot closer to the sensor.
The angle would make the pixels below them slightly less sensitive, which becomes an issue with f/11 lenses. And Canon has tradionally erred on the "It really needs to work most of the time" side of features, so we get a really small AF box.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
HxW:
R5/R6: 40% x 60%
R7/R10: 60% x 80%
R3: 80% x 80%
R6II: 80% x 80%
Not sure that explains why the EF 100-400 II with 2X can still use the entire area for AF though.
I do find that the centre box for the 800mm f11 seems more reliable than having the entire focus region of my RF 100-400mm in low light, even though the latter lens focuses much faster it seems to get confused easily in this situation (eg a bird with branches/leaves in foreground).
500px @frankyboy5
thunder storm Forum Pro • Posts: 10,139
That's huge.
HxW:
R5/R6: 40% x 60%
R7/R10: 60% x 80%
R3: 80% x 80%
R6II: 80% x 80%
With that combo there's probably more AF speed available to make hunting a matter of a split second making less good AF at the borders less of a problem. That said, it would have been nice if the R5 had at least a setting giving you the choice if you want to use the full frame for AF or not.  Not giving the choice sounds like a hammer thing to me.
No I'm not blown away by these lenses anyway. The 600mm is still just 600mm, and the 800mm is still fairly big to take with you for "just in case" which is a clear disadvantage for a truly one trick pony.  I'm also not sure if the lenses are truly satisfying using a 45Mp sensor. Maybe these lenses are more at home at 24Mp anyway. And having 80*80% AF area really adds to the value of these lenses.
45 is more than enough, but 500.000 isn't
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
