ET-65III Alternatives for EF 100mm f/2
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,493
Hi,
I am looking for an ET-65III alternative for EF 100mm f/2.
Sometimes smaller hoods fit onto another lens but I couldn't find any hints yet.
I would like to add something smaller than the original if this is possible and, still maintain sufficient protection from stray/side-light.
Anyone here with a good alternative?
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX100 VII Sony RX10 IV Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
QuietOC
QuietOC Veteran Member • Posts: 6,838
Re: ET-65III Alternatives for EF 100mm f/2
The hood is pretty inexpensive. You can cut one down to make it less deep.
 QuietOC's gear list:QuietOC's gear list
Pentax Q7 Sony a7R IV NEX-5T Sony a77 II Sony DT 16-50mm F2.8 SSM +104 more
msowsun
msowsun Contributing Member • Posts: 740
The ET-65 is the correct hood, but the ES-65 and EW-65 also fit perfectly.
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D Canon EOS D30 +27 more
Maxmolly7
OP Maxmolly7 Senior Member • Posts: 1,493
Ah, thank you very much, this is the answer I was looking for. 😀
Maxmolly7
Tried to find the 2 shorter versions but wasn't successful.
Probably will end up with the long one...
msowsun
The ES-65 and EW-65 are harder to find, but they do show up on eBay.
Maxmolly7
I found an ES-one on a German used platform at a rather high price... 🥶
Photobygms
Photobygms Regular Member • Posts: 296
Are you sure? The EF 85mm and 100mm have both a snap-on lenshood, lock mechanism works by pressing the two buttons on the mount.
The 85mm and 100mm don't have a locking notch for the newer bayonet hoods. Have tried several options just a few minutes ago but no bayonet type will lock and hold
The ES-65 and EW-65 are bayonet type lenshood (twist and lock)
Edit: made a big mistake
All mentioned hoods are snap-on lenshood and should fit.
Newer bayonet type lenshoods will not fit as I mentioned above
.....Of course I'm out of my mind. It's dark and scary in there.....
Mostly analog at: https://www.flickr.com/photos/photobygms
Digital and some analog at: https://www.instagram.com/photobygms/
 Photobygms's gear list:Photobygms's gear list
Canon PowerShot SX740 HS Canon 6D Mark II Canon EOS 5D Mark IV Canon EOS R Canon EOS RP +46 more
Sittatunga Veteran Member • Posts: 5,413
Maxmolly7 wrote:
Hi,
If you already have the ET-65III hood there's nothing to stop you shaving a bit off the end with a Stanley knife as it's a soft enough plastic to let you do that. The more you shave off, the less protection from stray/side-light it gives, of course, and it's pointless to try to turn it into a petal hood as it rotates freely.
msowsun
What do you consider high? There are a bunch on eBay right now for about $25-$30.
eBay ES-65
here_and_there Regular Member • Posts: 194
No need to buy the canon one. Usually Amazon or B&H carry third party ones that are just as good quality as the Canon ones at a fraction of the cost. I've bought JJC (in amazon) and Vello (on B+H) and both are as good as Canon's.
See e.g. https://www.bhphotovideo.com/c/product/749643-REG/Vello_LHC_EW65II_EW_65II_Lens_Hood_for.html
 here_and_there's gear list:here_and_there's gear list
Canon EOS R5 Canon EOS R7 Canon RF 16mm F2.8 STM Canon RF 50mm F1.8 STM Canon RF 100-400mm F5.6-8 IS USM +3 more
Thank you for this! I was looking into this very same question (but for a 85/1.8 coming my way) and had a guess these may work, but was hesitant to purchase to experiment
Maxmolly7
eBay ES-65
Well, I consider 25-30$ plus 10-16$ shipping to Germany high.
Is ES-65 III or, ES-65b the same thing as ES-65? I can have a 3rd party ET-65 for as low as 7.99€ including shipping.
Photobygms
No not the same, the ES-65B is a bayonet type lenshood designed for the RF 50mm F1.8 lens.
As mentioned before Bayonet type lenshoods will not fit on the EF 100mm F2 (and 85mm F1.8)
Edit:
Do own that ES-65B and a EF 50mm F1.8, the ES-65b will not fit on our EF 85mm F1.8. (have tried it)
Maxmolly7
Edit:
Thanx.
Photobygms
Edit:
Thanx.
Do mean the RF 50mm F1.8 version not the EF 50mm F1.8 as I wrote
The ES-65B also won't fit on all the EF 50mm F1.8 versions only on the RF 50mm F1.8
rodriguezPhoto
rodriguezPhoto Veteran Member • Posts: 4,244
What about an old fashioned screw in rubber lens hood?  They're shorter and collapsible.   That is what I used on my 100 until I got the 85 1.8.  With two lenses sharing the same hood I got the ET-65III.
~~~ Kim
 rodriguezPhoto's gear list:rodriguezPhoto's gear list
Olympus E-3 Canon EOS 6D Olympus E-1 Olympus E-M1 Olympus E-M1 II +55 more
Maxmolly7
I have a rubber lenshood for another lens. Turns out that the rubber doesn't slide as nice into a tighter lens compartment as those plasticky ones. After a few years of use, the outer element broke off.
