Fuji X-H2S - Impossible to do fully manual time lapse (interval shooting)
Started 5 months ago | Questions
svensl New Member • Posts: 6
I have done time lapses on every camera I have ever owned and it always has been possible to shoot with full manual control. On the H2S however, I can only change aperture and shutter speed. The ISO cannot be changed during the time lapse as the light changes.
Am I the only one who has noticed this or am I missing something. Please help! I need to be able to change ISO whilst shooting a time lapse.
Thanks for any advice.
Fuegi Forum Member • Posts: 75
Re: Fuji X-H2S - Impossible to do fully manual time lapse (interval shooting)
Let me ask a silly question first, have you set ISO to Auto and tried again? I understand someone wanting to set a constant shutter speed and aperture. I personally would set ISO to a fixed value as well and change exposure in post later.
Make sure you setup your auto iso settings properly first.
 Fuegi's gear list:Fuegi's gear list
Fujifilm X-T3 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Sigma 150-600mm F5-6.3 | C Fujifilm 16-50mm F3.5-5.6 II Fujifilm XC 35mm F2 +3 more
OP svensl New Member • Posts: 6
Hi Fuegi,
I don't want to set the ISO to auto. If I do the camera will adjust the ISO during the time lapse which results in flickering, especially as you go from day to night. I'd rather change it myself and be in full control. Unfortunately I cannot adjust the ISO once the time lapse is in progress. I think the problem is that on the H2S one cannot assign the ISO to a command wheel. I think this is a major flaw and needs a firmware update.
svensl wrote:
Hi Fuegi,
Svensl,
I think I'm missing something here. Are you saying that you set your camera up for interval shooting but you manually adjust ISO as time goes along right before the camera takes the next photo? Wouldn't the flickering you are talking about exist in both sets of timelapses (your manual intervention and Fuji Auto ISO)? If you are shooting from day to night, wouldn't that be exhausting to keep monitoring the situation? I would try to plan for the brightest scene you would have and set ISO accordingly as to not blow out the highlights. The rest of the exposures can be brought up in post production if you feel they are a bit underexposed.
I'm trying to understand a use case where you want to manually adjust ISO as time goes along instead of having the camera do it and fixing in post if it is not to your liking.
Yes, that is exactly what I do.
It is time consuming but the only way to get consistent results. The camera is a dumb device and does not meter consistently, especially as it gets darker. You always want to be in full control to get a proper time lapse and hence exposure.
As you manually change exposure you of course get steps but these are maybe every 100 pictures or so and programs like Lrtimelapse are designed to handle these steps. If I let the camera choose the exposure I will get changes with every picture, very hard to smooth out. Also the camera often gets the exposure wrong as the metering may expose for the bright sunset and not the darker foreground or vica verse. It does not know what I want.
In any case, I find it odd that Fuji does not cater for fully manual control on their pro body. So if anybody knows of a setting I may have missed please let me know.
Thanks,
Erik Baumgartner Senior Member • Posts: 6,894
As changing the ISO doesn’t change the exposure, wouldn’t you rather adjust the SS? In any case, how about using manual with Auto-ISO, locking the exposure with the AEL button, and then just tweaking the EC dial up or down as needed? That should effectively do what you want.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Erik, ISO does change exposure.Aperture, SS, and ISO do.
As I mentioned Auto ISO will not work as it relies on the camera's metering to find a value. Try using the metering system of your camera in the dark. It won't give you the correct shutter speed / ISO. That is why I need to use the camera in manual. My 2011 canon rebel did it, so did my Sony, so did my XT3 and XT4. Why not the H2S?
I contacted Fuji and am awaiting their reply. Not sure how long it will take though.
No, ISO changes brightness after exposure, it doesn’t actually affect the sensor exposure at all. In many cases, you could adjust it just as effectively in post. Much better to optimize the exposure at base ISO if you can (on a tripod you probably can if you aren’t limited by SS issues).
Not after the exposure is locked, it doesn’t. Once locked, you can simply click the ISO up and down with the EC dial.
What exactly are you shooting?
If the XT3 and XT4 allowed you to do this then I agree that Fuji should allow the same functionality with the H2s. Most of us don't have this very hands on approach to timelapses so I think we were confused as to why you were doing this.
In regards to ISO, it technically isn't part of exposure. Only shutter speed and aperture are. Fuji cameras are ISO invariant so adjusting the ISO in camera is similar to adjusting the exposure slider in your RAW editor.
Anyway, please report back with what Fuji says.
Yes Erik, you are correct! ISO is just the gain applied after. Thanks for correcting me. I believe in manual mode and auto iso the EC on the rear command wheel does not work.
On the XT4 you could program the command wheel to change the ISO (or use the manual dial of course) but on the H2S the ISO cannot be assigned to a command wheel. You always need two button presses to change the ISO. Maybe that is the reason ISO cannot be changed manually when in interval shooting mode. Not sure.
Timelapses, day to night. Start before sunrise and continue into the night sky. I always found it easiest to change the settings as I time passes. So you can start with low ISO and fast shutterspeeds and as you go into the night you may go up to 20sec (depending on focal length as to not get star trails) with an ISO of 64000.
You are right. Erik, the other forum contributor corrected me on this. Thanks!
I will.
robert1955 Veteran Member • Posts: 7,302
But if your exposure [Time and Aperture] is controlled manually, changing the Exposure Compensation necessarily changes the ISO setting. Looking at the manual EC is or can be assigned to a dial.
EC should work in full manual mode as long as Auto-ISO is on (it does on all the other cameras, anyway)
It’s just beyond stupid that you can’t properly assign ISO to a dial. They really need to rework the whole dial assignment option thing on the PASM cameras, IMO.
Can you maybe do it with the (admittedly crappy) remote app?
Sorry, but If I were you, I’d be thinking about exchanging for an X-T5.
Hopefully they’ll do something about this. You aren’t alone in your displeasure….
https://www.fujirumors.com/i-am-sorry-fujifilm-but-you-must-fix-this-now-a-firmware-request-and-a-workaround/
