Very good mechanics and form factor. Optics are somewhere around average minus
Started 5 months ago | User reviews
47872Mike Regular Member • Posts: 222
Good AF motor. Not too big or heavy.
To approximate its optical performance, it's good at 100mm, Ok at 200mm if you stop it down a bit, and sometimes OK at 300mm if used around its optimal aperture range of f8-11 (depending on camera body, due to diffraction on densely-populated sensors. It's slightly better on full-frame than cropped sensor, but the above approximations still apply. Vignetting is pretty heavy, but well-enough corrected by the Canon lens profiles. There is quite a lot of purple fringing at 300mm and as it approaches; the Canon profile reduces it a fair bit. Linear distortion is not minimal, but is very well-corrected if you use the Canon correction profile.
Overall the lens is nice, but optically seems very similar to me to a good example of the 75-300, albeit that the superior mechanics increase your chances of achieving perfect focus.
Still quite a good lens if you can be bothered with it and don't want to drop hundreds of pounds on something much bigger and heavier, especially on full-frame.
All examples below with in-camera lens corrections activated.
Canon 7Dii 220mm F8
Canon 7Dii 300mm F9Third Example: Canon 6D 105mm F8
 47872Mike's gear list:47872Mike's gear list
Canon EOS 20D Canon EOS 50D Konica Minolta Maxxum 7D Sony SLT-A37 Canon EOS 6D +12 more
Canon EF 100-300mm f/4.5-5.6 USM
Telephoto zoom lens • Canon EF
47872Mike's score
3.0
Average community score
2.8
Canon EF 100-300mm f/4.5-5.6 USM Canon EOS 6D
OP 47872Mike Regular Member • Posts: 222
Re: Very good mechanics and form factor. Optics are somewhere around average minus
Canon 6D 220mm F11
Canon T3i/600D 210mm F10
