On an R body this is NOT the lens to buy :(
Started 5 months ago | User reviews
OP davel33 Senior Member • Posts: 2,978
Re: On an R body this is NOT the lens to buy :(
Canon_Guy wrote:
davel33 wrote wrote:
Any weight or balance issues are just a case of getting used to it.
I disagree with your statement, its not getting used to it, its putting up with it.
All this body-lens "balance" thing is fully artificial issue. When holding the combo properly, right hand carries only a small fraction of the whole weight. Left hand supports majority of the weight by supporting lens from below in the center of balance of the combo. Potential front/back imbalance of the combo is solved by moving the left hand forward/backward on the bottom of the lens barrel. Therefore there is no "unbalanced" combo (when considering normal weight lenses <1.5 - 2 kg).
Your 100% correct on this.  I should of been more precise in my response. I did not mean to imply that my comment was also about balance as well was weight.  It was only about weight.  In high school photo class I was thought to  keep my left hand under the balance point of the lens/body.  It became 2nd nature to me and I never stopped to think about it
"Just one more Lens, I promise....."
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
Tannin Senior Member • Posts: 1,510
davel33 wrote:
Tannin wrote:
You got the problem the wrong way around. I had constant trouble getting reliable focus with my EOS R and EF 70-300L. I got rid of the dreadful EOS R and replaced it with another SLR and all was well.
It does seem like you supported my post with your story, thank you
No, the EOS R was just as bad with any other lens. Complete dog of a camera. Canon should never have released it.
 Tannin's gear list:Tannin's gear list
Canon G9 X II Canon EOS-1D Mark IV Canon EOS 7D Mark II Canon EOS 5DS Canon EOS 5DS R +10 more
Then you have a bad copy. I ordered my copy the day it was announced and have never had a problem with it. Go over to the EOS R forum and you will find the same respect for it.
Dave
tdbmd Senior Member • Posts: 1,547
I have seen some nice work with the R.  It appears that you need to use it within its parameters.  Most say it is not really a sports/action camera but does many other things well.
 tdbmd's gear list:tdbmd's gear list
Canon EOS 7D Mark II Canon EOS Rebel T8i (EOS 850D) Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +11 more
100% correct.  Use the correct tool for the job
Dave
It was a dog doing landscapes too. I never expected it to be much good for wildlife, but it was amazingly unreliable doing landscapes too. And the ergonomics were dreadful. Worst Canon camera since ... well, worst I have ever known, and I've owned a lot of them.
Given some of the photos I have seen from the R, that surprises me that it was not good for landscapes.  I have heard that the ergonomics were so so.
Sittatunga Veteran Member • Posts: 5,413
I like the ergonomics, but they're different from a DSLR, not necessarily worse, but different. I bought a bargain 5Ds a couple of years after my EOS R and that really does have poor ergonomics in comparison. It all depends on what you're used to.
The 5Ds has no touchscreen, no articulated rear screen, no exposure simulation through the viewfinder, a viewfinder screen that can't show the true depth of field of fast apertures and is non-interchangeable, the joystick only moves orthogonally, not diagonally and can only select 61 focus points over the middle half of the image area, no colour histogram in the viewfinder, and needs to go to the rear screen to get focus magnification for critical manual focus or to chimp. It's really frustrating to work with sometimes.
dave_bass5
dave_bass5 Veteran Member • Posts: 7,342
Well disagreeing doesn't make you any more ‘right’ than anyone else.
If you cant make it work for you then fine. I make it work, love it and take photos.
What am i doing wrong 😂
 dave_bass5's gear list:dave_bass5's gear list
Canon EF 24-70mm F2.8L II USM Canon EF 35mm F2 IS USM Canon PowerShot S110 Canon EOS 5D Mark IV Canon EOS M50 +10 more
