Canon 20mm f3.5 Macro Bellow Lens
SigmaTog
SigmaTog Senior Member • Posts: 1,114
Green Iridescent Jewel Beetle's Shell at over 20x Magnification.
I added some baffles into a long extension tube to cut some flaring. When I re-assembled the tubes I accidently added the remaining few extensions I had & now the tube is 430mm long !
Getting a bit out of hand, but it works ?
Canon 20mm f3.5 Macro Bellow Lens.....the little big lens that can !
Green Iridescent Jewel Beetle at over 20x Magnification.
The picture is of a 1.5mm x 1mm section of its shell. 19 stacks in Zerene Stacker with DMap.
ken_in_nh Senior Member • Posts: 2,399
Re: Canon 20mm f3.5 Macro Bellow Lens
How'd you move your assembly for the stack? Step size?
Nice to see your lens and rig in action!
SigmaTog
OP SigmaTog Senior Member • Posts: 1,114
The rig is getting too big & is vibrating with the slightest touch.
The steps were 19 into 1mm, ie 0.02mm.
My rig at present.
Tube length is 430mm flange to flange.
Is making the tube length 1/2 as long & using a 2x converter a useful arrangement ?
Do I place the 2x behind the lens or in front of the cameras mount please ?
Wow.  That's an impressive looking rig!
Regarding use of and placement of a teleconverter, I think experimentation is the only way to go, especially since the experiments are easy and can be fun...
You don't see kit like yours very often, partially because, I suspect, many people use microscope objectives for higher magnification work.  For example, I use a 10x objective and my existing lenses as a tube lens, either my 100mm macro or my 55-250 telezoom.  I can also do my pics for focus stacking using the internal focusing motors of my "tube" lens and the in camera focus bracketing function of my camera.  Whether this sacrifices resolution or creates other issues I can't say because I haven't compared.  I'm sure others will comment, since they always do...
You might also consider whether reversing your lens would improve results at higher magnification, if you care.
SigmaTog
Thanks Ken
Yes always experimenting
Joseph S Wisniewski Forum Pro • Posts: 35,461
Teleconverters go near the camera, but don’t bother
My rig at present.
Absolutely. Your Canon lens is optimized for a relatively short bellows. It's not well corrected at 450mm, so you will have problems with chromatic aberration, spherical aberration, and curvature of field that you won’t have at 200mm.
And you're likely to pick up a decent quality improvement from controlling vibration better.
Of course, you don’t really need the teleconverter, because you don’t have the resolution. Are you familiar with the term "empty magnification"? That's when you try to operate past the "diffraction limit" of an optical system, so all you're doing is magnifying blur. Your 20mm f/3.5 is really only built for magnification up to 10x, and even then it's a bit "iffy".
I only used super-long extensions back in the day when I needed greater working distance. You really don’t want to build a high magnification system this way, because you're creating a bunch of optical problems. Extending a 20mm f/3.5 lens some 450mm (I've included the camera's internal depth) means you’ve got 21.5x magnification, which sounds great until you realize that the lens is about f/80 effectively. (3.5x430mm/20mm).
That means is a very strong "empty magnification" situation. The diffraction limit calculator says we're looking at an Airy disc of 107um at f80. I believe your Sigma has about 9um pixels, so the finest detail that can be resolved is about 5 pixels wide.
You could get the same, or better, pictures by dropping the tube to 200mm, cropping, and enlarging, with a lot more stability and controllability, and you’re in the range your lens was corrected for. You don’t need the teleconverter, because that would just be piling on more empty magnification.
What you really need, at 10x or 20x, is a faster lens. A much faster lens.
Microscope objectives are insanely fast. My favorite 20x objective is a Nikon CF M Plan 20x ELWD. It's an 11.1mm focal length (which doesn’t really matter) with a 10.5mm working distance (which does matter). It has a numerical aperture of 0.4, which converted to an f stop is f/1.1. That's over 3 stops faster than the 20mm f/3.5. More importantly, at 20x it's effectively f/22 instead of f/80, so you have an Airy disc of 30um instead of 107um.
In front of the camera mount. A teleconverter is a negative lens (multi element, and pretty well corrected, but for analysis purposes it's effective a simple negative lens) of about -60mm focal length. If you put it near the positive 20mm lens, you'll get a net -40mm, and the system won’t focus light.
Interesting rail. Is it borrowed from your 3D printer?
And what's holding up the rear end of it?
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
Focusing a tube lens, empty magnification, and other stuff
It reminds me of something I did many years ago, using a length of PVC pipe as a very long extension tube. But I had a faster lens.
That won’t be an easy experiment, and as I pointed out, the answer is already known.
I only used super-long extensions when I needed greater working distance. You really don’t want to build a high magnification system this way, because you're creating a bunch of optical problems. Extending a 20mm f/3.5 lens some 450mm (I've included the camera's internal depth) means he's got 21.5x magnification, and it means the lens is about f/80 effectively.
That means he's in a strong "empty magnification" situation. The diffraction limit calculator says we're looking at an Airy disc of 107um at f80. I believe his Sigma has about 9um pixels, so the finest detail that can be resolved is about 5 pixels wide.
He could get exactly the same pictures by dropping the tube to 200mm, cropping, and enlarging, with a lot more stability and controllability.
Well, since you insist…
Lenses are sharpest when they're designed to operate at only one specific magnification. When you optimize a lens to cover a range of magnifications, you decrease resolution and increase aberrations across the entire distance range. This was a necessary compromise for "general purpose" photographic lenses for most of the 200-year history of photography.
Old-style "finite" microscope objectives are optimized to reach focus at a designated "tube length" from the objective's mounting flange. Most of mine are Nikon 210mm tube length objectives. As you diverge from 210mm, chromatic aberration and spherical aberration get worse, and the field becomes less flat.
Infinity objectives are optimized when going from their designed focal distance to infinity. Move your subject farther from the lens and it now focuses to a finite distance, and you'd need a camera lens that focused "beyond infinity" to bring it back into focus. Move the subject closer and you can bring it into focus by focusing the camera lens closer, but you're moving outside the optimally corrected range of your objective. It's a complex lens, so aberrations may get really strange doing this: the field may literally be "wavy" with multiple peaks and valleys.
It will get "worse", but we can’t easily predict how bad.
It won’t help. His lens is optimized for magnification in the 5-10x range. It's not a symmetrical lens, so reversing it would be forcing it to operate in the 0.1-0.2x range.
One reverses a "regular" photographic lens because those lenses are designed to work in the 0.0-0.2x range, so reversing them means they are better corrected for 5x to infinite x (although they will be diffraction limited long before you reach infinity, lol).
Same thing with enlarger lenses: they're optimized to go from maybe 0.25-0.1x, so reversed you can go from 4x to 10x.
Ciao! Joseph
Re: Focusing a tube lens, empty magnification, and other stuff
all great in theory, but experimenting with optics can be full of surprises.  We're not talking about theoretical perfection, but what's achievable in practice.
As a former bench scientist, I can cite endless examples of the departure of practice from theory.
That's why I encourage the OP to experiment a bit.  You may say it's a waste of time, but I don't agree.  Many real life situations don't comport perfectly with theory.
SigmaTog
Thank you Joseph & Ken
You have introduced me into a new world of knowledge.
Yes I have used the same track & gantry trucks that many 3D printers use.
I started off using a heavy bicycle workshop stand & mounting the macro rail so it was balanced equally. I now need more stability.
My project is to photograph the surface of the iridescent beetle's shell to see the structure that gives it the colour, 'Structural Colour'.
I appreciate your shared knowledge here thanks.
