Fufjilm X-T100 IQ at base ISO
ayolos Junior Member • Posts: 39
I just check flickr and imaging-ressource and I notice the same thing a lot of people already noticed of discussion boards : X-T100 produce the best color / sharpness of all recent fujifilm line from 100 to 6400 ISO. After, it seems to be reaaly bad compared to xtrans.
It's seems even close to RP, S5 or R3 at base iso ! in details and colors! (cf imaging-ressource). What's the f... is this sensor?
I know that this camera is low cost and body is cheap. slow, bad AF. Ok, I use a X-E1 and X-PRO1 so I know what a bad AF is...
But, if I only want a tool for landscape and use with a stabilized lens like 10-24mm (light setup). do you think it's a good idea idea to come with my X-E1?
I don't care about high iso. when i need high iso i use RP.
Other question : is the sensor in the X-T200 is as good at base ISO as the one is the X-T100?
thank you
Fujifilm X-E1 Fujifilm X-Pro1 Fujifilm X-T100 Fujifilm X-T200
JayPhizzt Senior Member • Posts: 2,374
Re: Fufjilm X-T100 IQ at base ISO
thank you
Sharpness is an almost entirely lens sided characteristic and has very little to do with the sensor.
And bad compared to X-trans? Bayer yields more detailed photos with most softwares. I'm not a fan of X-trans and I definitely prefer bayer.
Else when it comes to base ISO there is generally little difference between sensors. You should be looking at lenses instead.
