A slightly loose Canon OEM EOS M-EF adapter issue
Iyou1 Regular Member • Posts: 111
Hi all
I have a Canon genuine EF-M to EF adapter. I recently found out that while the adapter connects very tightly with all my EF lens, the connection between the adapter and the camera is slightly loose.
If I try to lightly rotate the camera, it can move slightly clockwise. Just slightly.
On the contrary, if I do the same to the connection between the lens and the adapter, I don't see even the slightest movement.
Is this normal? Should I worry about it? Thanks!
