Any recommendations for a good but not big wrist strap for M6II?
ezriel Regular Member • Posts: 414
 ezriel's gear list:ezriel's gear list
Nikon D90 Nikon D500 Canon EOS M6 II Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
Canon EOS M6
StevenSHH
StevenSHH Contributing Member • Posts: 609
Re: Any recommendations for a good but not big wrist strap for M6II?
Never really needed one, it's so small, but for some if you vlog, it's on gimbal / cage / or some small tripod.
If you are using it with big lens then just use anchor link from peak design and use any of your neck straps or buy one of peak design cuff.
Have fun with photography! Start taking photos!!
 StevenSHH's gear list:StevenSHH's gear list
Canon EOS M6 II Canon EF 24-70mm F4L IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 32mm F1.4
Brian Slater Regular Member • Posts: 432
5
I use and like the Peak Design Cuff. Smallrig makes a virtual copy for half the price.
 Brian Slater's gear list:Brian Slater's gear list
Canon EOS 6D Canon EOS M6 Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm F4L USM Canon EF-S 60mm f/2.8 Macro USM +4 more
JRET
JRET Contributing Member • Posts: 840
DIY solution - take an existing M neck strap, cut it in half (measure wrist size requirement first).  If your wrist size is not too large you will be able to make two wrist straps from one neck strap.
Once cut, undo the threads holding the uncut end of the strap.  Next fold the cut end over  and re-stitch the two ends together.  With a sewing machine the entire mod can be accomplished in about 5 minutes.  Connect the wrist strap to the camera.  I use the right end.
I've used this on an original M, M2, M50, first M6II, and will be putting one on my second M6II that arrived earlier today.
Need two bodies for a shoot?  Use the neck strap on the body with the heaviest lens and the wrist strap on the other body.  This is a convenient solution I've been using for several years.
GENESIS 1:3
 JRET's gear list:JRET's gear list
Canon EOS M6 II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM Canon EF-M 32mm F1.4 +7 more
OP ezriel Regular Member • Posts: 414
Amazing
ihgold2 Regular Member • Posts: 163
Nice idea!  Would you attach a photo or two of your DIY strap so we can see it -- how it's made, how it attaches to the camera, etc.?  Thanks!
 ihgold2's gear list:ihgold2's gear list
Canon EOS M5 Canon EOS M6 II Canon EF 70-200mm F4L IS USM Samyang 12mm F2.0 NCS CS Tamron SP 90mm F2.8 Di VC USD Macro +2 more
JRET
GENESIS 1:3
Found this 1.
like it because:
1. connected to camera with a metal ring and not a thread that can be ripped.
2. it adjustable.
anyone tried it?
JRET
I occasionally shoot concert events where two bodies are substantially more efficient than having to constantly change lenses - e.g. I might have a 6D + 70-200L around my neck and a M6II + EF85 f/1.8 prime on my wrist.  Even when hanging on my wrist the weight of the M6 & smaller prime does not inhibit shooting with the larger 6D + L zoom ... and I can switch back & forth quickly.
When I'm doing the tourist thing I usually carry the M6 (on my wrist) and a couple of M lenses in a small shoulder bag.  Since the camera is always by my side except when shooting, most people don't even realize I have a camera.  The system is simple, inexpensive, and it works well - at least for me.
The only downside (and it's not a downside for me) is this wrist strap is NOT a quick detachable type.  I've tried several of the detachable straps, even tried adapting a quick release to my current wrist straps and I was never satisfied with the security of the release mechanisms that I was using.  I purposely tested several of the quick release setups and was able to break most of them with little effort.  So the OEM direct connection is all I trust at this point.
GENESIS 1:3
Dareshooter Veteran Member • Posts: 5,842
Optech USA have neoprene wrist straps that are quite small. I  wrap the original neck strap around the palm of my hand though and when I need both hands free to change lenses or answer the phone for instance I put the strap around my neck .
koenkooi Contributing Member • Posts: 919
Another recommendation the for PD Cuff from me as well I especially like how easy and fast it is to remove and reattach.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
gmcooper Regular Member • Posts: 471
Rainbowimaging WS1 Wrist Strap. If you can find it.
 gmcooper's gear list:gmcooper's gear list
Canon EOS 5D Mark II Canon EOS M Canon EOS 5DS R Canon EOS M3 Panasonic Lumix DMC-GX85 +5 more
Decided on this set up.
cheap, sturdy, compact.
Added a back up in case the ring will break.
Not taking space in the bag, and protecting the lens as well.
lumenite Senior Member • Posts: 1,207
What a good idea of a backup strap added!
By the way, here are my set-ups.
Old: Joby + Canon original lug
Current: Joby + PeakDesign quick release connector (replica) + lug ring
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
23speaker23 Contributing Member • Posts: 557
I was looking for a wrist strap as well... but ended up doing a diy strap off of a piece of paracord and a fishing split ring. This strap and a small pouch let me take the m6-2 with a single lens anywhere I go (I'd normally put it on my belt in summer).
Why diy?
1. Dirt cheap.
2. Fits my hand perfectly and the loop is lockable.
3. I am 100% sure it will not fail since a) the split ring is rated 47 kg for rupture and b) a single piece of 4 mm paracord will withstand a lot more load than the m6-2.
It's not the best photo. If you are interested I can do more pictures in a week. Or you can search youtube for e.g 'camera paracord lanyard' or 'snake knot lanyard'
(I know the paracord color is kinda funny... but that was all I had on hand)
Take care.
ChrisPCrunch Regular Member • Posts: 145
Peak Design Cuff is great
I add my vote for the PD Cuff. It really is fast and easy to remove and attach.
 ChrisPCrunch's gear list:ChrisPCrunch's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Panasonic Lumix G 25mm F1.7 ASPH +1 more
aaaarrrrteee Junior Member • Posts: 36
VKO Black Camera Hand Wrist Strap
$9 at amazon
