R6 ii e shutter read out speed?
Started Nov 3, 2022 | Discussions
alantan Contributing Member • Posts: 705
Is there any reviews that tested this?
 alantan's gear list:alantan's gear list
Nikon D700 Nikon D800 Fujifilm X-E1 Fujifilm X-M1 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +3 more
Canon EOS R6
catastrophe Regular Member • Posts: 180
Re: R6 ii e shutter read out speed?
Higgins2002
Higgins2002 Contributing Member • Posts: 962
7
No test yet, but here's some other cameras  readoutspeed.
So where does R6II fit in..... probably in the R5 region
 Higgins2002's gear list:Higgins2002's gear list
Canon EOS R5 Canon EOS R7 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +2 more
cnyphotoguy Contributing Member • Posts: 879
Is there a source for this graphic?
 cnyphotoguy's gear list:cnyphotoguy's gear list
Canon EOS 90D Canon EOS R7 Canon EOS R6 Mark II Canon EF 100mm F2.8L Macro IS USM Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye +13 more
Higgins2002
Here
OP alantan Contributing Member • Posts: 705
How is r5 is faster than r6 with more megapixels?
Higgins2002
R6 has an older sensor inherited from 1 DX
In that case, if it inherited the r5 readout architecture it should be faster than the r5 because it has less lines.
Messier Object Forum Pro • Posts: 13,459
Olympus / OM cameras are not included here.
I guess that many birders are still ignorant of the Micro FT system or don't think it rates a mention     The OM-1 can do 120 fps in electronic shutter mode and that suggests a sensor readout time of around 8ms.
More interesting to me in that video were his comments about IBIS contributing to rolling shutter effects and the distortions we see from frame to frame even when not panning and when shooting static subjects
Peter
Tom Bak New Member • Posts: 11
graph is massively wrong in multiple entries
The graph is nonsense.
The Sony A7R IV (and A7R V can be assumed the same with the same rebadged sensor) have readout speeds of 100 ms, making them the worst of all.
Source: https://www.fredmiranda.com/forum/topic/1613934
The Sony A7III and IV have readout speeds of 66 ms, placing them also on the poorest performing end, far behind a R7.
Source: https://www.dpreview.com/reviews/sony-a7-iv-review#HC
Sidenote:
When discussing this you do need to highlight that you discuss photo readout and not video rolling shutter values. These do differ significantly and also are mode (both resolution and FPS) dependend.
A stacked sensor is by no means a guarantee that video rolling shutter is good. The A9 in 4k video has very bad rolling shutter, worse than a lot of non-stacked sensors.
Stig Nygaard
Stig Nygaard Regular Member • Posts: 402
Re: graph is massively wrong in multiple entries
Tom Bak wrote:
I don't know the read-out speed of the different cameras, except I remember R5 being unusual fast for a non-stacked sensor. So I don't know if this graph is nonsense or not.
I just want to remind that many sensors has multiple modes (power-use and heating varies probably with them), so readout speed can be different in different cameras even though they use the same sensor. And most importantly, as far as I know the readout speed is usually different in photo- and video-modes. The graph doesn't tell if the numbers are from photo- or video-modes (I haven't watched the video mentioned as source).
 Stig Nygaard's gear list:Stig Nygaard's gear list
Olympus TG-5 Canon G5 X II Canon EOS 7D Mark II Canon EOS R7 Canon EF-S 10-22mm F3.5-4.5 USM +18 more
Higgins2002
I can't say if Sony's values are with  14 or12 bit raw.
This can be your answer why Sony's value in this graph is not like  Jim Kassons 14bit test.
In this graph it says 1/16s  for R4
1/37s on A74 probably 12bit
All canons is 12 bit
More likely it is damaged/lossy compressed raw or even JPG on the Sony figures. Sony doesnt even publish FPS figures for lossless raws and they know why they hide it.
The Canons values are for lossless compressed raw.
That is the only numbers I would consider for a comparison.
Anyhow without proper source the graph doesn't have any credibility.
Higgins2002
Well it is the the way Canon make their linup and allways has.
The 6 serie is lower than the 5 serie
The 5 serie is lower than 3 serie.
But we'll see what the new R6II sensor is about soon I suppose.
Looking at the task (not involving compression or other things)
R6: 20x20MP=400Mpixel/s : 1/50s
R6II: 40x24MP=960Mpixel/s : If this one is 1/60s it is a big jump from R6
R5: 20x45MP=900Mpixel/s : 1/60s
Higgins2002
This is how it is, no-one will test a bunch of cameras with equal method.
I'm quite dissapointed of the wobbling ES result of R7  Duade Paton shows in his video even with multiple shots of stationary subjects.
Some part in it can be the IBIS as he stated, compensating for handheld movement at longer FL.
I'm aware of one can use mechanical shutter but that is so for every other camera aswell.
Higgins2002
Some part in it can be the IBIS (combined with slow readoutspeed) as he stated, compensating for handheld movement at longer FL.
Stig Nygaard
Are you sure about the R7? Afaik electronic shutter on R7 is still 14bit?
Higgins2002
Do you have any source saying 14 bits?
bclaff he said in the thread "Canon R7 bit depth on electronic shutter"
this:
I received 3 files which is sufficient to do a quick initial test.
The files were black frames taken with mechanical, EFCS, and electronic shutters.
From the histogram I would say that electronic is 12-bit with some small amount of smoothing (I haven't done spectral analysis yet)."
Stig Nygaard
this:
No other source than Canon usually writes it in the manuals if the bit depth is lower with electronic shutter. But for R7 I haven't seen any mentions of reduced bit depth anywhere in specs or manuals...
Stig Nygaard
I just checked specs on canon-europe. For R6, R6II and R5 it is specifically mentioned for all that electronic shutter is 12-bit. Look under "Still Image Type":
https://www.canon-europe.com/cameras/eos-r6/specifications/
https://www.canon-europe.com/cameras/eos-r6-mark-ii/specifications/
https://www.canon-europe.com/cameras/eos-r5/specifications/
But for R3, R7 and R10 there are no mention of reduced bit depth for electronic shutter:
https://www.canon-europe.com/cameras/eos-r3/specifications/
https://www.canon-europe.com/cameras/eos-r7/specifications/
https://www.canon-europe.com/cameras/eos-r10/specifications/
I'm not saying R7 (or R10 or R3) is 14 bit. Just asking if someone knew for a fact it is 12-bit?
