Will X-T5 video quality be worse than X-T3/4?
ap356 Forum Member • Posts: 67
Based on the specs - it seems like the video quality of the X-T5 might actually be worse than the X-T4, and possibly even the X-T3.
The only option for over-sampled 4k requires a crop, whereas the 4 and 5 used the full sensor. Will it actually look worse than the older cameras?
I have no problem with the X-T5 not being a huge upgrade in terms of video capabilities, but having it actually get potentially worse is a bit weird...
Otherwise I would be happy enough to just get the X-T4 now, but I prefer the tilt screen
Fujifilm X-T3
JNR
JNR Veteran Member • Posts: 4,652
Re: Will X-T5 video quality be worse than X-T3/4?
Odd perspective... you have two H cameras, and an economical S camera that meets your needs, and you really think it makes sense that those of us who shoot stills 90+% of the time should endlessly bend over backwards to meet video needs to our exclusion?
In any event, T5 has better IBIS, better EV, better screen, better AF tracking, almost certainly significantly better overall IQ for video (based on both processing and number of pixels), and higher battery rating (CIPA)... yet you think the video compromises elsewhere are greater. Not in real-world use - at least based on the stats and early impressions we've seen so far.
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
RustyRus Senior Member • Posts: 1,696
I wouldn't buy the XT5 if I wanted to shoot any video at all. The screen is a hinderance for me and what I need.
Which is why I own the XH2. Gives me everything I need for video and photo stills. Fuji's lineup is about as perfect as it can get right now. It has a camera for everyone.
 RustyRus's gear list:RustyRus's gear list
Ricoh GR III Leica Q2 Fujifilm X100V Fujifilm X-Pro3 Leica M11 +1 more
rla1022 Contributing Member • Posts: 762
exactly.  Fuji even said in the video they wanted to make a photo first camera.  I’d have been happy with cutting video completely and then giving us more simulations.
 rla1022's gear list:rla1022's gear list
Fujifilm X-E4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 16-80mm F4 Fujifilm XF 27mm F2.8 R WR +1 more
DarnGoodPhotos Forum Pro • Posts: 11,881
Your choices for the best video Fujis are the X-T4 and the X-H2/2S.
Preferring a tilt-screen doesn't change that.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Nebeldiener
Nebeldiener Regular Member • Posts: 188
I think you misunderstand how video works. Yes, the X-T5 has a 40mp sensor, but this doesn't matter for video.
Full HD is 1080x1920 = roughly 2mp
4k is 3840x2160 = roughly 8.3mp
What normally happens is that the full sensor width gets used and then combined into 3840 pixels (oversampling). The X-T4 oversamples 6k footage into 4k. This yields sharper image quality (with other benefits).
The heat sink of the X-T5 seems to be too small for the sensor/cpu combination. So one only has the option between subsampled 4k (only using 3840 pixels, NOT the whole width of the sensor) or oversampled 4k with a 1.23x crop.
So yes, 4k video should look sharper on the X-T4 compared to the X-T5.
This is also the reason why cameras like the Sony A7S or FX3 only have 12mp sensors.
 Nebeldiener's gear list:Nebeldiener's gear list
Fujifilm X-Pro2 Panasonic GX850 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R Panasonic 20mm F1.7 II +4 more
JNR
I never made any reference to the pixel density, nor the oversampling - so you're guessing that I don't get it. In reality, if you do a test, you will find that the various X-T cameras perform best in sharpness and lack of artifacts at 2k... but you are buying into the "my amp goes to 11" marketing gimmick.
We haven't been told the heat tolerance of the T5, so it is anyone's guess if it is better or worse than the T3 or T4. We do know (based on CIPA rating) that the T5 uses less energy, so likely generates less heat than the T4.... So, very possibly the T5 could outperform the T4 on that measure.
The other thing I should have mentioned is the lower ISO @ 125 yields greater DR and lower noise. This is especially beneficial for FLOG and FLOG 2 which rely on higher ISO (2x-3x), allowing for presumed lower noise - but again this is just a best guess based on specs for what is still a pre-production camera. But don't be surprised if it performs quite impressively - at least for shorter clips - which is what most stills shooters are going to want for the occasional video.
JNR
Nebeldiener
You specifically wrote:
...almost certainly significantly better overall IQ for video (based on both processing and number of pixels), ...
So I'm not guessing anything. The thread is about video quality. Not about stills quality.
The X-H2 manages to shoot oversampled 4k without a crop. The X-T5 on the other hand has a 1.23x crop. This means that the heat sink is not sufficient for the 40mp sensor in video mode. Even if it had better heat dissipation than the X-T4 it wouldn't change a thing because the 40mp sensor is way more demanding compared to the 26mp one.
And again, this thread is about the video capability. CIPA rating is for photography only (how many photographs can be taken until the battery runs out).
Of course, if one can live with the additional crop factor, the image quality should be almost identical. But the crop factor means that for example the 16mm lens is going to behave like a 20mm one, the 23mm like a 28mm, etc.
And I don't quite understand why you're talking about 2k. 16:9 video is either 1080p, 4k or higher. Anything between doesn't make sense. And 4k is slowly but surely the new standard.
TL:dr
We're talking about video NOT photography. An oversampled 4k image is almost always sharper and cleaner than a subsampled image.
Oversampled 4k shot on the X-T4 is going to look better than subsampled 4k on the X-T5.
Oversampled 4k shot on the X-T4 is going to look similar compared to oversampled 4k on the X-T5 (with 1.23x crop).
JNR
Processing and pixels have a relationship to video quality.
You overestimate the significance of the 1.23x crop. Watch the new Mumford video. He is correct on that score. You basically are saying that Panasonic can't produce a proper video with that small sensor... which is essentially a crop compared to APS-c. You're terribly misguided. In any event, the 1.23x crop very likely has to do with the processing pipeline capacity far more so than the heat sink - but that is speculative at this point.
Wow... so you don't think CIPA rating battery efficiency has to do with video capability (in terms of heating, hot pixels and length of video). Well, wrong again... you're consistent.
Yes, a lens crop factor similar to Panasonic. You do have that right.
Yes, I mean 1080 which is often referenced as 2k for shorthand.
TL:dr
Sometimes, but not often. Yeah, it depends on the particular sensor and the pipeline. It is often very close, and simply easier to work with 1080 to get good editing done quickly.
We don't know that yet. Again, DR and NR are really important for video processing (especially when shooting FLOG which is really the only way to go if you're serious about getting the look you want in a finished product). My guess is that the lower ISO will be far more important than the oversampling or crop factor, but we really don't know yet. We also know that the new AF system tracks better - and we are highly likely to see that in video, as well.
In any event, I'm betting that the T4 drops at least $200... because it really does appear to lag overall by comparison - mostly on the stills side, admittedly. I'm a bit worried about possible compromises in build quality and durability. Possibly that's where T5 corners were cut.
JNR
jdominh Forum Member • Posts: 58
Bumping up this topic as I am quite interested to hear the feedback as well as I am hesitating between the two for my B-Cam for light traveling with say 60/40 photo/video split.
Essentially the 40Mpx is a nice upgrade, along with better AF/IBIS for the X-T5 but I will dearly miss the flip screen and don't necessarily need to print large or crop that often.
I did some research and maths and would like to see how the two cameras compare for video especially.
From my understanding,
For 4k up to 30p, the X-T4 already oversamples from 6.2k without naming it "4KHQ" and that is without a crop versus the X-T5 which crops at 1.23x giving the used sensor the size of a (slightly larger) MFT sensor.
For 4k60p, I am not entirely sure if Fuji uses Line Skipping or Oversampling but from Gerald Undone's review of the X-H2 (which might be comparable to the X-T5 process), the camera line skips from 6.7k sensor size (1.74x total crop factor) which also affects dynamic range and seems to crush the blacks by almost 1-2 stops. The sensor size for the X-T4 is very much the same for 4k60p but would cover only 5.3k with its smaller resolution.
Do you guys know if that 4k60p from the X-T4 is line skipped or oversampled ? Is this loss of dynamic range/crushed blacks also an issue there? I reckon if it is instead oversampled then the X-T4 would be better than the X-T5 for video IQ (assuming similar sensor tech and the fact that not everybody needs 6.2k)
Happy to hear your thoughts there!
Fuji Maine Senior Member • Posts: 1,702
As was already answered in your other post, yes the xt5 line skips the 4k60. All those extra pixels for photos don't come without a cost for video. There's a balance that has to be achieved between line skipping, cropping, pixel binning, over sampling, rolling shutter and moire within the limits of the processor when the fps is increased. The XT4 will remain the B cam to my XH2s until I cough up the funds for a second XH2s as the xt5 doesn't represent any real benefit for video.
