Separate system for macro use?
Pansottin
Pansottin Contributing Member • Posts: 501
Hello, I use the Canon MP-E 65mm that does 5:1, with a Kipon adapter, but with a small vignette, on the GFX50R.
I have several classic Zeiss ZE (including the 100mm Makro-planar) that I use with the same adapter and I even use Fuji Mcex tubes with them, but a bit of vignetting too.
I use the GF120mm (a closeup lens; it's not a 1:1 macro) and the Mcex 18 & 45 tubes.
Try to do macro and everything else with the GFX50R, but in the case of the macro I find the limitations I mentioned.
For macro I consider the possibility of using a Fuji XH2.
Doubts:
1. The APS-C sensor won't have the detail and dynamic range of the GFX, but is it good enough for macro? I assume so .-) but I would like to have concrete feedback from users.
2. Can problems arise between full frame lenses like the ones I have from 1999-2012 and the 40 megapixel aps-c sensor? Discrepancy between lens capacity and pixel pitch of this sensor? Images with loss of sharpness?
3. Are Fuji X macro lenses any good? I'd rather get user reviews than many of the online reviews, which are so often biased.
4. Other non Fuji X macro lenses, for the APS-C?
5. What obvious advantages can you point to the use of the APS-C or Full Frame sensor versus the GFX MF?
One last note: I can go back to Canon APS-C or Full Frame for macro as long as the sensors are better than they were. I used Canon FF between 2009 and 2020 and they leave a lot to be desired .-( I don't know the new ones.
All opinions are welcome. Thank you all.
Regards.
 Pansottin's gear list:Pansottin's gear list
Fujifilm GFX 50R Canon MP-E 65mm f/2.5 1-5x Macro Carl Zeiss Makro-Planar T* 2/100 Fujifilm 120mm F4 Macro Fujifilm GF 110mm F2 +4 more
SigmaTog
SigmaTog Senior Member • Posts: 1,114
Re: Separate system for macro use?
I am gob-smacked with the results some are getting with their phones & macro lens.
I don't understand why they are so good ?
meow
meow Veteran Member • Posts: 5,752
Look at these
Take a look at the oneofone25's macro work. He use Olympus equipment. I'd say sensor size isn't a major issue.
https://www.dpreview.com/members/4664472364/forums/threads
In the case of oneofone I'd say he's skill is at a level mortals can only dream about. Those hand stacked sand grains... I can't fathom how he does it.
 meow's gear list:meow's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Venus Laowa 7.5mm F2 MFT 7artisans 7.5mm F2.8 Fisheye +2 more
Pansottin
OP Pansottin Contributing Member • Posts: 501
Re: Look at these
Thanks. I will take a look .-)
Eniigma_21
Eniigma_21 Senior Member • Posts: 1,134
I dont think sensor detail is a problem for macro. Lenses play a more important role. Dynamic range isnt an issue if you use flash.
 Eniigma_21's gear list:Eniigma_21's gear list
Sony a6000 Tamron SP 70-300mm F4-5.6 Di VC USD Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Samyang 12mm F2.0 NCS CS
Pansottin
I do use flash.
macrouser
macrouser Senior Member • Posts: 3,979
If you are not using the full width of the censer for the macro picture and cropping the image, then the vignetting is not a problem.
I use a Sony 7RIII and often find even at the most magnification I can get, the subject is still so small that I have to crop a lot.
This fly is small and I cropped a lot.
From the antenna to the tip of the wings is three mm.
This was using an FE 90mm macro lens from Sony with a five diopter lens on the front.  That gives me a possible 1.8 to 1 magnification.   Even so, the amount of cropping is extreme on a full frame censer.
If you are photographing something like a painting and need extra high resolution, you can probably do better with a very high quality longer lens.
 macrouser's gear list:macrouser's gear list
Sony SLT-A77 Sony a7R III Sigma 150mm F2.8 EX DG Macro HSM Sony FE 90mm F2.8 macro Sony FE 70-300mm F4.5-5.6 G OSS +2 more
oneofone25
oneofone25 Senior Member • Posts: 1,586
Re: Look at these
Any questions let me know!  I answer anything and everything....(except the EXACT location of my sand pocket near Bandon, Oregon)
 oneofone25's gear list:oneofone25's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Samyang 16mm F2 +1 more
BBbuilder467 Veteran Member • Posts: 7,057
I'd be considering the image size and aspect ratio. I think the Medium Format has a 4:3 aspect ratio and 44mm sensor width. The apsc would produce about twice the image size using the same lens and magnification, but also be 3:2 aspect ratio.
The micro 4/3 gets 17.3mm x 13mm in frame at 1:1. It takes about 2.5:1 with the MF to do that.
jim mij Senior Member • Posts: 1,027
Re: Look at these
I’d agree, the person behind the viewfinder who perceives and sets up the shot seems able to produce results on any gear
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
I saw a vid the other day (Allan wells) comparing ff vs apsc for macro, same lens for both, both resulted in the subject being the same size, but the ff had a lot of wasted space around the subject, hence had to be cropped.
Jim
It Must be that time of year, dark nights and nothing to photograph, I’m also considering gear and have been looking at the recent Fuji cameras, etc
but ultimately if I was starting again I’d be after a better lens, eg 2 :1 Laowa and then which sensor/camera
Jim
macrouser
That is exactly right.  I have found that latter generations of sensors produce sharper images.
