Canon vs. Sony FF sensors comparison for capturing *action*
Tom Bak New Member • Posts: 11
Hi all,
it is quite interesting to see what value different brands bring to the table with their camera sensors, when looking at the one topic where ILCs (could) have a big advantage over smartphones: capturing action / fast moving subjects.
Canon sensors for capturing action.
* Please note that the readout time for the R6 II obviously today only is an assumption based on the 40 FPS. Sony for the a7r5 also seems unwilling to officially share even the FPS rates when shooting lossless raw, so the figures are based on preliminary dpr review.
Pretty massive performance differences if you ask me.
What is the point of a silent shutter, if it usefulness indoors with artificial light and outdoors for capturing action is seriously hampered by super slow readout speeds?
I can even ask: What is the point of the last tiny bit of AF improvements if your missing the shot due to low FPS ?
And I guess nobody is spending this amount of money in the $2000+ class just for JPGs or lossy un-raws.
Canon EOS R6 Canon EOS R6 Mark II Sony a7 IV Sony a7R V
PAntunes Senior Member • Posts: 1,279
Re: Canon vs. Sony FF sensors comparison for capturing *action*
Tom Bak wrote:
Hi all,
Ok, so what's the slowest readout speed to have acceptable action images?
Necip
Necip Senior Member • Posts: 1,118
7
If you are interested in performance where is the Sony A1 and A9II in your comparison no point in comparing a A7R5 clearly a landscape cam. still at 61mp 10fps not bad.
would you really prefer having 40fps elongated balls twisted looking tennis racquets or Sony's A1 30fps perfectly round balls and everything well shaped.
shutter fps Looks good on spec sheet but in practice only mech for Canon (wildlife/sports)  unless you get the R3..
 Necip's gear list:Necip's gear list
Canon EOS-1D Mark III Canon EOS 5D Nikon D7100 Canon EOS Rebel SL1 Canon EOS 7D Mark II +2 more
OP Tom Bak New Member • Posts: 11
Sounds like some sad whataboutism. And apples versus oranges. The cameras listed are the direct competitors.
PAntunes wrote:
Tom Bak wrote:
Hi all,
That is the photographers choice and relative to the budget.
In the enthusiast camera range listed any buyer can make a choice.
What is your answer?
Tom Bak wrote:
PAntunes wrote:
Tom Bak wrote:
Hi all,
Having distorted elements in a photo is not relative to the budget. It either works or it doesn’t.
Even before anyone talked about rolling shutter, action cameras already had a faster sync speed than most. 1/250 was ideal. Now some cameras can do 1/400.
A camera with a readout speed of 1/60 isn’t an action camera. Real world usage, anyone wanting a camera on this segment to shoot sports still needs to rely on mechanical shutter.
Necip
But isn't that what you are doing apples vs oranges? you clearly say *action* then you ignore the real action cameras compare a high MP Sony landscape use cameras against a low end Canon action Camera. oh look one is quicker..
Sony A1 would be those big juicy pink Grapefruits Canon R6 small sour grapes if we are talking fruit..
I wrote "capturing action". I do hope you do not get mad at all those people who want to capture action in the R6/A7 or in the R5/A7R market segments.
And you believe the audience for $2000-4000 should be complacent with Sony's obsolete and slow sensor tech?
Not. There are two market segments in my list. Each with a Sony and a Canon one:
Sensors Sony versus Canon
But anyone wanting to capture action with those cameras would do it in mechanical shutter, not electronic.
Or are you saying that the same person that wouldn’t shoot lossy raw with no visible difference in the image, would be ok shooting electronic mode and have visible rolling shutter issues?
Bobby V
Bobby V Senior Member • Posts: 1,592
Thanks for the comparison. I have a couple discussion points below.
Tom Bak wrote:
Hi all,
Xperia Pro-I has a stacked sensor with 8.3 ms readout which is faster than anything in your table, so I don't really see how this is relevant? Nonetheless, AFAIK no one is shooting sporting events with a cell phone as their primary camera.
I think you're referring to E-shutter? If so, I tend to agree that Canon are better performers in this area
Silent shutter is used for more than extreme action, ie situations where you need silence or rolling shutter is not a concern
I would argue that nailing AF is even more important when you have less frames to achieve a high enough hit rate
I guess, but if you want a camera focused on fast action or silent shutter modes without compromising quality, there are much better options out there. A9, A9II, A1, R3, Z9, OM-1, X-H2S. A7RV for example seems to appeal more to the studio, portrait or landscape user who doesn't want to jump to MF.
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
5
PAntunes wrote:
Tom Bak wrote:
PAntunes wrote:
Tom Bak wrote:
Hi all,
That's simply not true. It all depends on the sport, whether it involves the kind of movement that will actually get distorted by rolling shutter, whether the photographer pans with vertical lines in the background (for a landscape orientation shot), etc. For example, I have so far taken several thousand shots of runners, on the track and on a cross-country course, with e-shutter on my R7, which regularly gets bashed for having too much rolling shutter. Not a single one of my shots so far has shown any rolling shutter distortion. I'm sure, if I'd wanted to get some distortion, I could have, by shooting differently from how I usually shoot. But, for my purposes, the readout speed with the possibility of rolling shutter distortion, is simply not a factor (so far). I have also taken a few thousand shots of football (soccer), but I used EFCS for that. But not because I was nervous of rolling shutter in e-shutter, but because I didn't want 15fps. 8fps was plenty.
There is a tendency on these forums for people to get fixated on one feature of a camera, and use it as a badge of honor, or a cudgel to bash other brands with. For many years, it was the overblown fixation on dynamic range, to the exclusion of everything else (including far more important features of cameras). Now, it's all about sensor readout speed and rolling shutter. People are quick to pronounce that certain cameras are simply 'unusable' in e-shutter, if they have relatively slow readout speeds, while totally ignoring the fact that it all depends on what you are shooting and how. For many photographers, yes, including some action shooters, slow readout speeds in e-shutter don't make them anywhere near to being unusable. And even in situations where you do see some rolling shutter distortion, often a burst will contain many shots that don't show any. If you're shooting at 15, 20, 30, or even 40fps, you could still get plenty of shots that are not distorted, probably more than you would get by using mechanical shutter at a slower burst rate.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
bodeswell Senior Member • Posts: 1,378
How are you getting from 40 fps, which I suppose means a new frame every 25ms, to a sensor readout time of 1/60, which would seem to be 16.67ms? Does Canon document that? I am not following.
 bodeswell's gear list:bodeswell's gear list
Canon EOS R Canon EOS R5 Canon EOS R7 Canon EF 135mm F2L USM Canon EF 200mm f/2.8L II USM +4 more
Marximus
Marximus Regular Member • Posts: 474
Joke's on you! I have an R5 and an R6 and I shoot JPEG only.
 Marximus's gear list:Marximus's gear list
Canon EOS R5 Canon EOS R6 Canon EF-S 60mm f/2.8 Macro USM Canon Extender EF 1.4x III Canon Extender EF 2x III +10 more
Necip
Alastair Norcross wrote:
PAntunes wrote:
Tom Bak wrote:
PAntunes wrote:
Tom Bak wrote:
Hi all,
Hi I think before you start giving people advice about camera gear and tech info etc would be good if you learn some stuff about photography.
you've posted so much on dpreview like it's your baby. 9,298 posts has anyone ever constructively crit your pics? so you learn some stuff?
Seriously I think I can paint a better photo than this...
https://anorcross.smugmug.com/Nature/Teller-Farm-September-11-2022/i-xfcFDSS/A
not just one they're all similar with your R7 and 100-500mm.
The cam info says...
CameraCanon EOS R7LensCanon RF 100-500mm F4.5-7.1L IS USM + 1.4x or Canon RF 100-500mm F4.5-7.1L IS USM + RF1.4x + 1.4x or Canon RF 100-500mm F4.5-7.1L IS USM + RF2x + 1.4xFocal Length560.0 mm (1528.7 mm in 35mm)Aperturef/11Exposure Time0.0004s (1/2500)ISO1000Date Taken2022-09-11 14:49:28AuthorAlastair Norcross
You have the latest Canon R7 and the 100-500mm cost a few pennies but I was consistently getting better shots 2 decades ago with a fraction of that gear when digital was really just starting. Those don't even look like photos what did you do to them?
I spent some years on a few photo critique websites posting pics and critiquing it helped a lot. not trying to be hurtful but helpful.
regards
Occams Razor Senior Member • Posts: 1,252
You can ask the same question on the R5 - 20 fps is 50ms and 1/50 is 20ms.   Electronic fps does not equal readout speed.
Randy
 Occams Razor's gear list:Occams Razor's gear list
Canon EOS Rebel SL2 Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 16-35mm F4L IS USM +4 more
Ayoh Regular Member • Posts: 394
12 bit vs 14 bit
Tom Bak wrote:
Hi all,
But if an unfair comparison since the Canon files are 12bit in the high speed modes you listed and the Sony are 14bit. The Sony are faster when also in 12 bit mode
