MP-E at 10X
Victor Engel Forum Pro • Posts: 20,968
MP-E at 10X
6
This is my first attempt to use the Canon MP-E 65mm f/2.8 lens with a Canon 2X III teleconverter. This is a focus stack of Plusiodonta compressipalpus. Stacked using Zerene. I wasn't sure how successful using the converter would be.
Victor Engel
 Victor Engel's gear list:Victor Engel's gear list
Canon EOS 5D Canon EOS 5D Mark II Canon EOS 600D Canon EOS 5DS Canon EF 50mm F1.8 II +13 more
SigmaTog
SigmaTog Senior Member • Posts: 1,114
Re: MP-E at 10X
You have got a great result.
Cariboou
Cariboou Veteran Member • Posts: 3,732
Re: MP-E at 10X
Hi,
How many photo for your result, and for stack do you use
a micro rail? You have a great result
Thanks for share
 Cariboou's gear list:Cariboou's gear list
Nikon D810 Nikon D850 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-120mm f/3.5-5.6G ED-IF VR Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR +2 more
OP Victor Engel Forum Pro • Posts: 20,968
Re: MP-E at 10X
Cariboou wrote:
Hi,
Thanks for share
There were 101 photos in the stack, but I think the first 8 or so were basically unused because my starting point was too close. I didn't use the calculator to determine the step size, which would have been 0.02mm by the calculator. I just guessed at 0.01mm. I used a StackShot rail drive by Zerene software. Illumination was by an LED household lamp so exposure time was 4 seconds per shot.
I tried doing a focus stack of some mold a similar way, and it didn't turn out because the mold moved around between frames. That was kind of interesting and surprising.
Victor Engel
Cariboou
Re: MP-E at 10X
Tkanks
Victor for explanation, I will try of to do something but with manual rail and will see if working of I need something that take care the movement rail like you
Pansottin
Pansottin Contributing Member • Posts: 501
Re: MP-E at 10X
Thanks for sharing. What a beautiful texture this wing has. I've been using this lens for years but I've never tested it with a teleconverter. The magnification doubled; interesting!
Can you please tell us what effective aperture you got with a 10:1 magnification. It's just that I notice the image with lack of sharpness in general. High diffraction?
Attention, sharpeness is not everything. In addition, your image has a consistent smoothness. But I'd like to know if it was intentional or if it's diffraction or the teleconverter effect.
I hope to test it soon with a Novoflex BallPro 1 bellows (my camera is the GFX50R) to see results and possible magnification. Bellows will have a maximum span of 192mm.
 Pansottin's gear list:Pansottin's gear list
Fujifilm GFX 50R Canon MP-E 65mm f/2.5 1-5x Macro Carl Zeiss Makro-Planar T* 2/100 Fujifilm 120mm F4 Macro Fujifilm GF 110mm F2 +4 more
oneofone25
oneofone25 Senior Member • Posts: 1,586
Re: MP-E at 10X
I find it very interesting - and I love the result -
I just wonder why there is detail on some scales and others nothing.
 oneofone25's gear list:oneofone25's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Samyang 16mm F2 +1 more
jim mij Senior Member • Posts: 1,027
Re: MP-E at 10X
Very interesting, makes a change from eyes. I like drilling into detail so I’d have liked to see a picture of the moth and then what specific part you then examined
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
Re: MP-E at 10X
Indicated aperture was f/2.8 and the formula Canon uses is (magnification + 1) * f-number for effective f-number, so 11 * 2.8 or about f/30. That's wide open. I could have stopped down half a stop or a whole stop to get the sweet spot of the lens, but I think the increased diffraction would counter that. I seem to notice less sharpness around the periphery, which is probably a result of using the teleconverter.
Victor Engel
Re: MP-E at 10X
Probably mostly because of how Topaz Sharpen AI works. If it thinks the detail is unimportant, it squelches it. If it thinks it's important, it enhances it. I didn't play with the settings. It usually does a pretty good job of macro shots, though. This is my first time using it with a 10X image, though. The AI is probably not trained with this sort of photo.
Victor Engel
Re: MP-E at 10X
This one might be the same moth but it's quite likely it's a different one - same species though. https://www.inaturalist.org/observations/136883594
Victor Engel
SigmaTog
Re: MP-E at 10X
Can the MPE65 be used with an electric extension tube ?
Re: MP-E at 10X
Extension tubes work fine, but the lens is basically a built in extension tube lens anyway, so you'd need a lot of length to make much difference.
Victor Engel
SigmaTog
Re: MP-E at 10X
Thanks Victor
Pansottin
Re: MP-E at 10X
Hi, what if it's a bellows with a maximum extension of 192mm like the Novoflex BallPro1? How will the MP-E 65mm perform?
Thanks.
Re: MP-E at 10X
Thanks.
An approximation is to use the lens equation: 1/d0 + 1/d1 = 1/f where d0 is the sensor distance to the lens and d1 is the subject distance. At 1:1 d0 = d1 = 2f
I think the magnification is basically d0/d1.
So the MPE at maximum extension would be 1/5D + 1/D = 1/f
Solving for D,
1/5 + 1 = D/f
f/5 + f = D
So at full extension, the distance from lens to focal plane is 5(6/5 f) or 6f.
The focal length f = 65mm so the extension is 6*65 = 390mm
So how much difference will a 192mm extension tube make? (192 + 390) * 5 / 390 = about 7.5x
The MP-E is not a simple lens, but I think this formula is close enough for this question.
Derivations were done while I was in a meeting, so there could be an error.
Victor Engel
Pansottin
Re: MP-E at 10X
Victor Engel wrote:
Thanks.
Solving for D,
1/5 + 1 = D/f
f/5 + f = D
Thank you Victor. Even if there is a margin of error, it gives an idea of what can be expected in terms of magnification.
And by the way; your solution with the Canon extender x2 III produces more magnification than a 192mm bellows. Is this due to the nature of the extender which includes optics and the bellows is just empty space between the lens and sensor?
Pansottin
Re: MP-E at 10X
What do you think is the sweet spot of the lens? Thanks.
Re: MP-E at 10X
Not sure - for most of my photos taken at 1x-2x I use indicated f/16. There's a compromise, depth of field vs. sharpness. To get more of one you sacrifice the other. So for living subjects, which is mostly what I shoot, where focus stacking doesn't work because of movement, I prefer DOF to sharpness. For a static subject where I can do focus stacking, I open up the lens. It seems to be quite sharp wide open, but I've not really done any tests for that.
Victor Engel
