OP
Abbazz
Re: Infrared pictures taken with NX Mini
ge0rg wrote:
Congratulations, you made me "break" another camera. I've converted a spare NX mini to infrared and got a few filters for it too, now.
NX mini photo sensor disassembled
NX mini IR-blocker filter filmed with NX mini without IR-blocker filter
Congratulations on the conversion. These NX Mini are quite cheap now (at least here in Asia), so they are the perfect material for experimenting!
You seem to have opened the camera casing and dismantled the whole sensor assembly in order to remove the UV-IR cut filter. I followed the procedure highlighted here (bottom of page): http://mecastronics.free.fr/SamsungNXminiTopIR.html
In fact, it is even possible to remove the UV-IR cut filter without completely detaching the plastic sensor cover from its ribbon cable and risk losing its delicate gold contacts. It is enough to just flip it out of the way to be able to pry open the underneath filter holder and pull out the UV-IR cut filter with a pair of flat tweezers, like illustrated by these pictures.
Here's a recap of the whole pocedure:
1. Follow the steps 1 to 9 from the disassembly procedure on the iFixIt website (https://www.ifixit.com/Guide/Samsung+NX+Mini+Disassembly/55038) in order to open the camera front casing.
2. Flip open the plastic sensor cover but without removing the screw attaching the sensor cover to the ribbon cable. Your camera should look like this:
Image Credit : IFixIt https://www.ifixit.com/Guide/Samsung+NX+Mini+Disassembly/55038
3. Using a small flat screwdriver blade, pry open the UV-IR cut filter holder from the top right edge without applying too much force (you don't want to destroy the plastic filter holder):
Picture Credit : Dima Lootvoet http://mecastronics.free.fr/SamsungNXminiTopIR.html
4. Delicately pull the UV-IR filter out of its holder with a pair of flat bladed tweezers and save it in a safe place in case you want to put it back later.
5. Reassemble the camera by reversing the previous steps.
Now I wonder whether it would be possible to remove the filter without removing the front casing, by just accessing the filter holder from the lens mount opening.
NX mini IR720 shot of old town with bridge and castle
NX mini IR720 shot of tree, with the sun hiding behind it
NX mini IR720 shot of castle on a high rock
(Darktable, converted to monochrome, split-toning module for sepia)
Congrats on the beautiful pictures, I love them!
Cheers!
Abbazz
