X100f and tcl
Sorabh Regular Member • Posts: 146
X100f and tcl
Hi all. I’ve never had an issue with the sharpness of my x100f but whenever I use my tcl I find that I sometimes miss focus. Especially if the pictures are taken indoors or in low light.
is it down to my camera technique rather than the tcl itself? Has anyone else faced a similar issue?
the image quality itself is stellar with the tcl but I just get really annoyed when I miss focus at f2.
any help would be appreciated. Thanks.
 Sorabh's gear list:Sorabh's gear list
Fujifilm X-T30 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X100F Leica X1
Erik Baumgartner Senior Member • Posts: 6,894
Re: X100f and tcl
What focusing mode? Have you tried bumping up the focus box size in low light?
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
OP Sorabh Regular Member • Posts: 146
Re: X100f and tcl
Hi. Almost always at at-s. I do use a smaller zone box. I’ll try using the bigger one. Thanks
paulhoppe_photography
paulhoppe_photography Regular Member • Posts: 256
Re: X100f and tcl
I remember using the X100F and the TCL and found it tended to hunt more or miss focus sometimes.
 paulhoppe_photography's gear list:paulhoppe_photography's gear list
Fujifilm XF 16mm F2.8 Fujifilm XF 27mm F2.8 R WR Fujifilm XQ2 Ricoh GR III Nikon D80 +4 more
Re: X100f and tcl
I would go with AF-S single point for the best results, increasing the box size in low r flat light will help. Make sure the camera is in Boost mode.
Re: X100f and tcl
Thank you. I didn’t realise increase the box size would help focus speed but it makes sense.
Re: X100f and tcl
Thanks. That confirms what I’m experiencing. Shame because I actually prefer the look from the TCL as compared to the F2 version. But it misses focus all too often and it’s really annoying.
Re: X100f and tcl
It can make a very significant difference, the more image detail the AF is allowed to contemplate, the better - especially important in low or flat light where there is less contrast to work with. Always try to position the AF box on an area with good contrast, if the desired focus point is lacking in contrast, try to find somewhere else with better contrast on the same plane to use instead.
