Sale on refurbished M6II $549
StrugglingforLight Regular Member • Posts: 126
Re: Silver M6ii back in stock 12/13
My refurb kit came in the M200 and lens look new. But is it normal for the battery to come without a protective cover? It was in a locked plastic bag and in bubble wrap. But no plastic protective cover on the battery terminals.
Apologies if this is a stupid question.
adventurer69
adventurer69 Senior Member • Posts: 1,938
Re: Sale on refurbished M6II $549
I can't wait to get one when there's another price drop .I would not abandon my M mount as yet , once it still works .
 adventurer69's gear list:adventurer69's gear list
Canon PowerShot A590 IS Canon PowerShot SD880 IS Canon PowerShot SX50 HS Canon EOS M Canon EOS M50 +11 more
DC Guy Forum Member • Posts: 68
Thanks for your recommendations.
I used ShutterCheck and it showed sub 1000 clicks (the tool quoted that for some cameras it will only show 1K increments) and I'm assuming I'm lucky to get a new body (unless it was reset before packaging)
 DC Guy's gear list:DC Guy's gear list
Canon EOS M Canon EOS M6 Canon EOS M100 Canon EF 100mm F2.8L Macro IS USM Canon EF-S 55-250mm f/4-5.6 IS II +3 more
m100
m100 Senior Member • Posts: 2,048
My refurbished M6II came with a new battery in the package.
Dr. says listen to this every morning.
https://www.youtube.com/watch?v=bEeaS6fuUoA
 m100's gear list:m100's gear list
Canon EOS M6 II
refrax Regular Member • Posts: 103
You got lucky! I ran ShutterCheck on the M6II (black) refurb I received last week and it reports a count of 3000. The camera has zero signs of prior use. I was bit surprised to see the 3k, I was thinking it would be less than that. I'm liking it so far though, nice step up from my Mark 1 M6.
 refrax's gear list:refrax's gear list
Canon EOS 6D Canon EOS M5 Canon EOS Rebel SL2 Canon EOS M6 II Canon EF 85mm F1.8 USM +10 more
ThrillaMozilla Veteran Member • Posts: 7,665
It's not a stupid question.  I have received two refurbs, and as I recall they both had the cover.  You can always ask Canon to send one, but if it were me, I would probably let it go if they don't send you one.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
I happened to come across this guy's unboxing of a refurb M6 II and his battery came just like mine, without the battery terminal protective cover. His battery came with scratches as well (mine did too). But those glossy black are scratch magnets. I assume these are not new batteries though, some did come with new batteries apparently.
istscott
istscott Regular Member • Posts: 467
I actually decided recently to send that camera in and got a replacement back from Canon instead of them repairing/returning the camera I sent. The button with an issue got a lot worse and started sounding sticky/crunchy. Anyways, editing a follow-up video right now on the process.
The replacement they sent oddly enough was a full refurbished kit so it included another battery/charger. The battery was in a taped plastic bag with no cap.
Well that's the way they're supplying them, then.  Take it or leave it.
But a sticky button?  I wouldn't accept that either.
istscott
True, I should have RMA-ed the original.
Also, my mistake, the battery came in a little zip-top bag. The charger was the one in a tape sealed bag.
I wouldn't worry about the battery.  I'm sure it will be just fine.  They last a long time, and the risk is small.
Yes my battery came the same way. In a zip top bag without the plastic protector for the battery terminals. Thanks for confirming that is how they send some of them. Your video was the best unboxing I saw.
