Question but only lens wise
inti4444 Senior Member • Posts: 1,230
I know this might be a strange question.
how would you compare the 23 mm f2 with the 23mm lens on on the x100v and the x100f ?
I am not talking about specific context of the x100 series just lens wise.
if you have some comparisons that would be great.
thank you
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X100F Leica X1
Erik Baumgartner Senior Member • Posts: 6,894
Re: Question but only lens wise
No direct comparison to show, but I’ve used both and definitely prefer the X100V lens overall. Neither lens is really state of the art, but I find the X100V 23mm to be sharper around the periphery at any aperture and very significantly better at close range in pretty much every way, especially wide open. Wide open at f/2, I definitely prefer the X100V lens all around. Note: the 23mm f/2 prime sports a noticeably wider field of view than any of the other 23mm offerings that I’ve run across.
The 23 f/2 prime can be a very good lens, it’s small, lightweight, well built etc., it (at least the copy I had) just falls a bit short of the X100V in most optical respects (IMO). It is, however, capable of pretty decent sunstars when stopped down a bit, the X100V, not so much - it’s kinda lackluster in that one department, even stopped all the way down. Not a dealbreaker for me, but worth noting. I liked both these lenses better than the three crummy 23mm f/1.4s I got in a row. I bought the X100V and have been very happy with it.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
JNR
JNR Veteran Member • Posts: 4,652
The X100 had the same 23mm lens design up to the X100F, but was improved as of the X100V... See DPreview review of the X100V for analysis. As for the earlier design vs the XF, see:
https://mirrorlesscomparison.com/fujifilm-vs-fujifilm/x100t-vs-23mm-f2/
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
