Scary?
3D Gunner Senior Member • Posts: 1,025
Scary?
9
I have found that ants of a species with very small specimens, ~5mm long, looks very strange when seen very close up (enlarged a lot), compared to how they look with the naked eye.
Alive specimen on the field. (<4mm FoV)
Alive specimen on the field. (<5mm FoV)
macrouser
macrouser Senior Member • Posts: 3,979
Re: Scary?
I would like to know how you got that much detail.  Is it stacked?  There is no lens listed in the meta data.
 macrouser's gear list:macrouser's gear list
Sony SLT-A77 Sony a7R III Sigma 150mm F2.8 EX DG Macro HSM Sony FE 90mm F2.8 macro Sony FE 70-300mm F4.5-5.6 G OSS +2 more
OP 3D Gunner Senior Member • Posts: 1,025
Re: Scary?
For macro I use Nikon mount optics and accessories, older models with full manual control, plus Sony mount adapter, so there is no way to display information about the optics and aperture used (between f:11 and f:16 in this case).
As you know, details are degraded quickly at high ISO, in underexposed areas, or with incorrect lighting.
In this case, the lighting was provided with flash and a multi-facets white diffuser, very large (relative to the surface of the area photographed) and which provided a volumetric light, i.e. with different intensity on different areas of the diffuser (including a side metal reflector at the head of the flash, for this effect).
Respectively I tried to get at least minimum illumination all around the subject, with emphasis from certain angles, in order to keep as many details as possible.
Finally a recipe for enhancing and a significant crop (probably 20% of the original frame).
Just for fun, I spent a few hours for fine tuning in detail extraction.
macrouser
Re: Scary?
Thanks for the information.  I may be able to use some of that.  I am old and get worn out quickly but get a lot of pleasure from discovery and seeing other peoples work.
Re: Scary?
Almost the same for me, but I'm also lazy and have a hard time getting started. 😎😀
Bas Hamstra Senior Member • Posts: 2,069
Re: Scary?
Isn't that why we do macro? Little aliens they are...and it's fascinating to make that visible to ourselves and others...
Kind regards,
Bas
 Bas Hamstra's gear list:Bas Hamstra's gear list
Canon EOS 5D Canon EOS 6D Olympus OM-D E-M10 Olympus E-M1 II Canon EF 35mm F1.4L USM +11 more
Re: Scary?
The more enlargement, the more fascinating details. Try to find and see something like this in stereo 3D on a large screen. This is "the thing"!🙂
