GoPro Hero 11 for transatlantic voyage?
nigelc1 Junior Member • Posts: 43
I'm crewing on a (52") yacht across the Atlantic in November (which will take 18-25 days) and plan to make a video for sharing with friends, personal memory on possibly Youtube in the periods when I'm not either on watch, sleeping or performing other duties. I'm really only into stills and have no video skills but I've been trying out the 4K video for the first time on my Olympus EM1 II/12-40:2.8, which is what I had planned to take. It will primarily be footage of life on the boat and some vlogging to camera.
Now had second thoughts on the Olympus - I'm sure I could get some good footage but:
- it's going to be hard to concentrate on settings in that sort of environment
- high probability of having to have to drop 1 kilogram camera &lens in the cockpit when immediate crew response required - possibility of damage.
I was thinking I would be better off getting a GoPro as:
- Much smaller/lighter, can clip onto self
- smaller sensor, therefore greater depth of field and less opportunity for focussing errors
- Less settings to worry about therefore can concentrate on framing and keeping the thing steady and engaging with the rest of the crew to get more interesting footage
- USB charging
Any thoughts?
Olympus E-M1
sludge21017
sludge21017 Veteran Member • Posts: 3,813
Re: GoPro Hero 11 for transatlantic voyage?
There are no focusing errors unless you are too close to the camera.
Some of the digital zoom options can look blurry if you are doing a selfie - but you have to remember you are cropping in quite a bit and losing detail via "zoom".
You'll need more than a couple batteries, external dual charger (maybe get one of those battery charging pods?).
I'd be slightly concerned depending on how much ocean mist/spray you take on - if running external battery for long periods since the battery door will be open (unless you find one that can make a seal).
Low light isn't that great as you would expect. But what can really see in the dark anyways.
John Koch Senior Member • Posts: 1,602
Gee, I'd say that's 70% of your story is right there. How did that come about? It is hardly a common opportunity or situation.
That matter is vastly more interesting than the question about whether to buy a relatively cheap camera.
And what sort of yacht is involved? A racing sloop, versus a motorized floating palace (mini Titanic), are very different vessels.
Or it could end a serious disappointment, of one sort or another? Think: calm (who cares?) arrival, versus "abandon ship," argh, swoosh, gargle, blotto.
There's another 10% of your story / yarn, if you live to tell it.
Why would any yacht owner choose November to cross the Atlantic? November is a period of shortening days and still within the period of treacherous storms. Could this be a scheme to ditch a depreciated boat and recover higher insurance claims?
Is the route from west to east or east to west?
Why would any Skipper tolerate a "deck hand," who is toying with cameras or vanity projects, whilst urgent hoisting, rigging, hauling, heeling, or scrubbing duties at hand? Even if he / she indulges such things, will how will the rest of the crew respond? Watch your back!
USB charging? Does the yacht have USB ports? In the crew area? Will they work if and when you need them?
Why anguish over whether to spend around $500 to get a recent Go-Pro, and associated accessories? The adventure you postulate (or imagine?) involves, overall, vastly greater matters.
Is there any "day job" back-up for this sort of fantastic fling? That is certainly a more pertinent issue than whether to get a GoPro. If that is of no concern, then I doubt you need any counsel from poorer people who will never be invited to crew on any sea voyage.
All humans prevaricate, at least a little, on occasion. What I regret is that online anonymity begets plenty of hooey.
Cough, cough. Please excuse my congestion. Cough, cough, cough.
Best wishes, in any case. If you are skillful, perhaps your tale will be wonderful.
OP nigelc1 Junior Member • Posts: 43
Brief explanation - it's east to west, Canaries to Caribbean, following trade winds below Azores High. Late November is best time because you don't want to arrive in Caribbean before the end of the hurricane season. Daylight hours much the same throughout the year in the tropics.
The experience is what matters but it would be nice to have a decent quality video record as I might probably won't have the opportunity to do this again. Apart from from factor/ergonomics issues will a GoPro 11 take better 4K than my iPhone XR? Both have USB charging but I'll primarily rely on a power bank. I think the iPhone won't have enough internal storage - icloud is no use if you are off grid.
Markr041 Forum Pro • Posts: 10,078
The Hero 11 takes 5.3K video. Use that and get a high-capacity sd card (256GB), or two (more than enough). The files sizes for 5.3K are not bigger or much bigger than those for 4K so there is no cost essentially, especially if you are using external power. 5.3K gives you flexibility in post - to crop or zoom - or just looks better than 4K no matter how it is viewed.
 Markr041's gear list:Markr041's gear list
Panasonic ZS100 Olympus TG-5 Canon EOS M Panasonic Lumix DMC-GH4 Nikon Z6 +5 more
PerfectMark Regular Member • Posts: 281
If you want video, then something like a GoPRO would be the best option. I have been sailing before, not as exotic as yours, just around the UK and over to Holland. But I had 2 GoPROs mounted on different points on the boat (was only a 4 person one) and then turned them on when it looks like something interesting was about to happen (e.g. sailing into a storm).
The GoPRO 11 only lasts about 1 hour on the internal battery. So you would ether need to keep replacing/recharging them. Or get something like this so you can connect to a USB battery and it still be fairly water proof:
https://gopro.com/en/gb/shop/mounts-accessories/usb-pass-through-door/ADCOD-001.html?gclid=EAIaIQobChMI_PWSqfX9-gIVBbDtCh0XFwunEAQYAiABEgLB_vD_BwE&gclsrc=aw.ds
 PerfectMark's gear list:PerfectMark's gear list
Canon EOS 600D Canon EOS M6 II Canon EF 50mm F1.4 USM Canon EF-S 18-55mm f/3.5-5.6 Canon EF-M 22mm f/2 STM +5 more
