Help please - what's wrong here?
Started 5 months ago | Questions
Jim_robinson New Member • Posts: 1
I'm using the R6 to take marching band pictures, and usually don't shoot completely wide open, though close to it. The picture below was taken on an R6, using a RF70-200 set at 153mm, F2.8, SS 800, ISO 12800. THe espose in different across the picture in a way I haven't seen before, and several pictures came out the same. Is it due to the uneven stadium lighting? I can improve it a bit change WB and doing some edits, but it is still visible. Some other pics are completely fine, same settings. I'd appreciate any input on what I might have done wrong here. Thanks!
Canon EOS R6 Canon RF 70-200mm F2.8L IS USM
Younes B Senior Member • Posts: 1,257
Re: Help please - what's wrong here?
I am not sure I got your question correctly: is it the colour variation on the faces ?
That's not your camera or you, it is the changing lighting across the stadium. The camera chose a WB for the entire scene and it happened that a spot light illuminated a face differently from the rest.
Your only option is see if your software can do local corrections of WB. If so, select the greenish face and adjust the WB to taste.
 Younes B's gear list:Younes B's gear list
Pentax K10D Pentax K-30 Pentax K-5 II Pentax K-5 IIs Pentax smc DA 15mm F4 ED AL Limited +6 more
Also, is there a reason you did not frame more tightly? you could have gone all the way to 200mm. The foreground did not bring anything to the scene.
fredlord
fredlord Veteran Member • Posts: 3,303
Artificial lighting pulsates and causes problems.
Stadium and arena lights pulse at a rate that your eyes can't really see. The R6 and other cameras see it, however. It shows as inconsistent exposure across the photographic images.
The R6 has a setting for use with artificial lighting such as the situation you might have been experiencing.
https://cam.start.canon/en/C004/manual/html/UG-03_Shooting-1_0240.html
 fredlord's gear list:fredlord's gear list
Canon EOS R5 Canon EOS R7 Canon TS-E 17mm f/4L Canon EF 100mm F2.8L Macro IS USM Sigma 15mm F2.8 EX DG Diagonal Fisheye +13 more
Karl_Guttag Senior Member • Posts: 1,883
Most stadium and gym lighting is terrible. Not only is it non-uniform, it has a lousy spectrum with some colors missing altogether. They are designed for brightness per Watt and not a uniform color spectrum. This can throw auto-white balancing off. Additionally, in your picture, there are a lot of blue and green primary colors and not much that is "natural."
Still, the main problem is that the face of the girl in the center is very overexposed. Also easy to do with so much black in the background.
When I am faced with a weird color problem, I try and find a "gray card" somewhere in the image to click on to adjust the white balance. Often black will work as it reflects a little of the light, but In this case, I click on the gray part of the person's uniform on the far right with the red stripe. I then change the curve to get the girl in the center's exposure in the 128-range (very approximately). Below is the curves applied.
Next is my version of the corrected image:
There is a lot more that could be done, starting with the RAW/cRAW file to pull down the highlights and up the shadows to make the picture look better. Stadium lighting is also very harsh/contrasty.
Below I used the "Raw Tools" filter in Photoshop (it gives you the same tools but on the post-RAW file -- thus not as good). I found the picture was about 1 stop overexposed, and I brought the Highlights down by 20 and up the shadows by 100 (on whatever scale photoshop uses). I then fudged the Green curve down and the blue curve up based on the prior attempt. This will help reduce the harshness of the lighting, and you can see some details in the uniforms, the people in the stands, and even the trees that were black in the original picture. I probably brought the green down a little too much, but hopefully, it gives you the idea.
These are all quick tests, and I'm sure they can be done better, particularly starting with the RAW/cRAW files.
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
rmexpress22 Senior Member • Posts: 2,304
Re: Artificial lighting pulsates and causes problems.
This is the answer.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
Dan W Senior Member • Posts: 1,154
I'm going to say its the lighting. Look at the cross lighting in the pic by the shadows left from the 2 band members closest to the camera in the image. The shadows are pretty dark in 3 of the 4 ways the light is coming from. the light pointing towards the right bottom edge is faint. Just take a quick snap in your yard using the same lens and exposure if you can and see it is still a problem. You can also set the F stop the same and shoot a blank sky with the same focal length on the same lens to see if its a problem with the lens. But I'm guessing its just the lighting...
 Dan W's gear list:Dan W's gear list
Canon EOS R5 Canon RF 50mm F1.2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 70-200mm F2.8L IS USM +3 more
