EPM2 sunrise shots - Kamloops British Columbia
Arek Halusko Senior Member • Posts: 2,267
14
Kamloops British Columbia Woke up late and wanted to check out a new vantage point i found. Had to run a ways from where I parked and through the trails. Just  made it.  5 2ev HDR merged/edited in Darktable.
I did notice some shutter shock on the 40-150 but not sure if the shutter delay works in HDR mode or If I have to use bracketing instead.
 Arek Halusko's gear list:Arek Halusko's gear list
Olympus E-M1 II Olympus 12-100mm F4.0 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Panasonic 8-18mm F2.8-4 +1 more
Olympus PEN E-PM2
Electro35
Electro35 Junior Member • Posts: 48
Re: EPM2 sunrise shots - Kamloops British Columbia
Great photos!
Regarding shutter shock: My E-PM1 is prone to shutter shock. and I read somewhere that the IBIS in those early models makes things worse. So I keep it turned off most of the time and now I encounter shutter shock much less. Some very unscientific comparison shots showed the same result.
 Electro35's gear list:Electro35's gear list
Olympus XZ-2 iHS Olympus Stylus XZ-10 Olympus PEN E-PM1 Panasonic Lumix DMC-GM1 Olympus E-M5 II +6 more
OP Arek Halusko Senior Member • Posts: 2,267
Electro35 wrote:
Great photos!
I was using a tripod and turned the IBIS off have to read up if the shutter delay works in the HDR mode or just normal/bracketed shooting.,
Nielk Mike Senior Member • Posts: 1,498
Can you post full size samples? Why f11 and up?
