Android Phone: White Balance App?
Newb Image Seeker New Member • Posts: 13
Are Android photo queries okay in this subforum? I am still saving up to get a decent SLR for my business.
Question: I'm need a white balance app for shooting my shots. Is there one that can be installed that sets the white balance BEFORE ths shot, or are these all applied after the fact? (If so, I believe the stock, built-in version will be sufficient for my purposed.)
Also, can any recommend a possible Android-specific forum that might be more clued in to camera phone features?
Thank You,
Scott
Bikeridr Forum Member • Posts: 76
Re: Android Phone: White Balance App?
Thank You,
Scott
You can try to search for "camera raw" in play store. My former Andriod 9 phone was able to record .dng files with a raw app. My Android 11 cant, though.
Then, of course, you'll need a raw converter for your pc/mac to set the white balance and convert it to a corrected .jpg.
Bikeridr - Happy amateur photographer
 Bikeridr's gear list:Bikeridr's gear list
Canon EOS 5D Mark II Canon EOS M100 Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 400mm f/5.6L USM +9 more
OP Newb Image Seeker New Member • Posts: 13
Thanks, Folks. I was unaware of the Android photo subforum down below. I'll get the model number and Android version I'm using and post down there.
Thanks!
Scott
Patrick T. Kelly Veteran Member • Posts: 4,629
My Sony Xperia allows me to set the white balance manually before I shoot.
Patrick T. Kelly
Oaxaca, Mexico
CAcreeks
CAcreeks Forum Pro • Posts: 18,924
I recommend OpenCamera
Or mirrorless? DSLR cameras suffer from mirror slap - often cellphones give better results at wide angle. Interchangeable lens camera (ILC) is way better for telephoto.
Question: I'm need a white balance app for shooting my shots. Is there one that can be installed that sets the white balance BEFORE the shot, or are these all applied after the fact? (If so, I believe the stock, built-in version will be sufficient for my purposed.)
Yes, OpenCamera has this interface, if you enable Camera2 API.
https://opencamera.sourceforge.io/help.html#user_interface
OpenCamera also has a Raw (DNG) option, so you can change white balance ex post facto. This is what I would recommend because the human eye is not good at judging proper white balance in the field. Darktable is able to edit DNG files, and is free.
The Google forums are full of cr@p but you might find something there, or on Reddit. This forum is generally quiet but posters here are knowledgeable.
