Nikon small world
Joel Klein
Joel Klein Senior Member • Posts: 1,320
Nikon small world
https://www.nikonsmallworld.com/galleries/2022-photomicrography-competition/ant-camponotus
Can I capture this with a z MC105?!
Nahh…
Still scary…
 Joel Klein's gear list:Joel Klein's gear list
Nikon Z7 II Nikon Z9 Nikon Z30 Nikon Z 50mm F1.8 Nikon Z 24-70mm F2.8 +10 more
grsnovi Veteran Member • Posts: 3,030
Re: Nikon small world
Joel Klein wrote:
Still scary…
Very!
 grsnovi's gear list:grsnovi's gear list
Panasonic Lumix DMC-GX85 Sony SLT-A65 Sony a7R III Panasonic Lumix DC-GX9 OM-1 +11 more
Joseph S Wisniewski Forum Pro • Posts: 35,461
That was captured with a 5x objective
Nahh…
Exactly.
You need three things.
  1. A microscope objective or a high power macro lens. A tolerable objective can be had for around $100. High power macro lenses like an old Canon EP-65 (which you can use on non-Canon cameras with an adapter) or a new Laowa 2.5-5x (which you can get for most mounts) will set you back at least $400. I'd go with the objective, because it's cheaper, yet better, if you already have some other stuff you need to use with it).
  2. A really big ant. The notes say that image was at 5x magnification. If it was shot on FF, the ant's head would be about 4mm, which means you're dealing with a truly enormous ant, maybe 15-20 mm long. For a smaller ant, you can go with a 10x objective. You're on you own for that.
  3. Some way of positioning the ant and camera, and lighting the scene. Generally, this is at some sort of bench setup with a stable base that holds your subject and camera in relation to each other. Lights can be LED reading lights, small "macro flashes, or whatever flash you have handy. A "focusing rail" lets you focus by moving the camera closer to or farther from the subject.
The notes say that particular shot was captured with a 5x microscope objective. There are two kinds of objectives: finite and infinite. Finite objectives capture light from the subject and focus it directly on the sensor, like a regular macro lens, but way more powerful. To use one of those, you just need the right stack of tubes between the objective and your camera.
Infinity objectives are the "new darlings" of microscopy. They capture light from the subject, and send it through the tube as parallel rays that don't focus anywhere (they're said to "focus at infinity"). A second lens, called the "tube lens" then "grabs" that parallel light and focuses it on your sensor. This lens needs to be around 200mm, because the objectives are only designed to produce their rated magnification and their full image size (which is sometimes closer to APS than FF). The tube lens may be a small, cylindrical "optical capsule" that you mount in a tube. The ITL200 (made by Nikon for Thor Labs) is probably the most popular and people use them with many different brands of objectives: Mitutoyo, Leica, Nikon, Olympus, etc.
My usual setup is a finite objective with a Nikon EVIL (aka "mirrorless") and an older Nikon PB-4 bellows. I'm doing some work lately with infinite objectives, using my Nikon 200mm f/4.0 as a "tube lens". It's not ideal in that it's heavy and bulky, but I already have it. Macro is often about using the stuff you already have, creatively.
Still scary…
Absolutely. That's a camponotus ant, aka a "carpenter ant", probably camponotus ligniperda since the photographer is Greek. They won't hurt you directly, but they can wreck your house. That ghastly mouth is built to chew it's way through wood fibers, and the eyes are only used occasionally, since there's no light at all inside a burrow chewed into a dead tree.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
Joel Klein
OP Joel Klein Senior Member • Posts: 1,320
Good morning.
Thanks you for the information. This is a treasure packed that I will bookmark. I never used any microscopic tools, all though I always had a a dream to look into the unseen world, but I’m afraid I’m going to put my finger in there and see all bacteria and I won’t use my fingers to eat anymore…
ThrillaMozilla Veteran Member • Posts: 7,661
Re: That was captured with a 5x objective
I don't know if they offer any advantages for ordinary macro photography, though.  They are designed for special microscopic techniques such as polarized light microscopy and differential interference contrast.  They are designed so special optical components can be introduced into the optical pathway without additional compensating lenses.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
3D Gunner Senior Member • Posts: 1,025
Nahh…
  1. A really big ant. The notes say that image was at 5x magnification. If it was shot on FF, the ant's head would be about 4mm, which means you're dealing with a truly enormous ant, maybe 15-20 mm long. For a smaller ant, you can go with a 10x objective. You're on you own for that.
Still scary…
Just for fun I have adapted an image of an ant head for the topic at hand.🙂
In my case, the ant species is one of the smaller ones, less than 5mm long, so the head size is probably less than 2mm.
The optical magnification was >5x, the camera APS-C and finally I applied a crop.
With a microscope lens the details would have been finer.
Joel Klein
Nahh…
Still scary…
Wow!!! Look at the eyes!!! Very interesting array of? I’m not sure…
Thank you! 🙂
The eyes are the way they are. I'm not a biologist and I don't see anything special. Perhaps the lighting gives an interesting perspective.
Digital camera sensors are less sensitive and lose a lot of detail in the presence of light of certain wavelengths in the red and sometimes orange color range, especially in underexposed areas.
This can cause areas of high detail to appear next to areas lacking detail, as is the case on the right side of the image for example, from the middle of the eye downwards.
If this suggests that the eye has been cropped from another image and added there, it is not.
The lighting was somewhat complex, with two LED light sources of slightly different spectrum, plus natural light and a small white reflective panel.
The subject wasn't dead but just seriously "incapacitated", and because it moved, I couldn't get enough images for a quality stack.
Was an interesting experience. 🙂
Infinity objectives offer the "three year rule"
  • They couple well to cheap, easily obtainable things.
  • You can change your magnification, within reason.
Anything that can do a reasonable 200mm equivalent and can be manually focused to infinity can work well with an infinity objective, including my phone (Samsung Galaxy S21 Ultra). I've also used them with a Nikon 200mm f/4, and with an old 70-210mm f/4-5.6. You can get an RMS to 52mm or 62mm adapter for around $15. It's going to take more to couple to a finite objective.
I'm great at doing things cheap, but the cheapest one can get away with mounting a 210mm finite objective to a typical DSLR or EVIL is $63. That's $15 for an adapter from your camera to M42, $33 for three M42 extension tube sets (Acouto 3 piece set, 61mm total), and $15 for an M42 to RMS adapter. You probably want a tube clamp with an Arca foot, too.
As far as magnification, most modern infinity objectives have enough resolution to drive a 300mm or even a 400mm telephoto. Some won't vignette on a 135mm on FF, or a 100mm on APS. If you try running a 210mm tube-length finite objective down to 100mm or up to 300mm or 400mm it's going to get a bit squiffy. Been there, done that.
But wait, there's more!
The biggest advantage infinity objectives offer is what my optical engineering prof back at Oakland called "the three-year rule".
More optical design calculations have been performed in the last three years than in the preceding 200 years of optical design.
This is thanks to advances in computers, optical design software, and the growing demands of industry. Optical manufacturing also continues to improve: more glasses of various capabilities are available, more advanced grinding techniques led to simple parabolic aspherical lenses, complex formula aspherical lenses, double sided aspherical lenses, and the abilities to grind aspherical lenses with ever-increasing deviations from the norm.
Infinity kinda' came along for the ride, or the three-year rule enabled it. But whichever side you take in that "the chicken and the egg" discussion, the results are pure win.
At the same time, three other trends converged.
Scope manufacturers increased their parfocal lengths (the length from the base of the objective to the subject) allowing for more complex, faster, higher resolution, and better corrected objectives, as well as increased working distances. I have some old Zeiss objectives with a 35mm parfocal length. Most of my flock of CF and CFI Nikons have a 45mm parfocal length, which is how the 40x ELWD has 33mm for optics and still pulls off a 12mm working distance.
  • The latest Nikon objectives are their CFI60 series, named after the 60mm parfocal length. I have a CFI60 biological objective, and like most biological objectives it has a very short working distance. In this case, 1mm. That leaves 59mm for a heavy, unusually wide objective just packed solid with lens elements.
  • The Mitutoyo 5x that's the darling of the macro field these days has a 95mm parfocal distance, which lets it have an insane 34mm working distance and still leave you 61mm for lens elements.
Scope manufacturers placed nearly all the aberration correction in the objectives. My old CF Nikons had to be matched to Nikon CF eyepieces or a CF "projection eyepiece" for photography. Directly projecting on a camera sensor showed off the high field curvature and chromatic aberrations. (Nikon says CF stands for "color free", but that's only when the objective is matched to a Nikon eyepiece). Now, it's 2022 and focus stacking fixes curvature of field, while software chromatic aberration correction is routine, but still...
The CFI objectives are better corrected on a generic 200mm telephoto than the old finite CF objectives were with matching projection eyepieces.
The fields just keep getting wider. Last week, Allan Walls and I were discussing objectives and their field sizes, and he politely cast doubt on my outdated ideas of field sizes. I tested what he claimed, and yes, the Nikon CF objectives cover a 43mm FF field surprisingly well.
There's a lot to be said for that ability. I'm about to publish my open-source BD/epi illuminator.
Ciao! Joseph
You're welcome
Joel Klein wrote:
Good morning.
You're quite welcome. I've always believed knowledge is meant to be shared.
Bacteria, and mites...
Ciao! Joseph
Re: Infinity objectives offer the "three year rule"
Interesting.  Yes, I see.  A finite objective would require too much extension to change the magnification by much.
Very interesting.
I assume those long working distances come at the expense of NA as before?
Thanks for all that information.  I have not shopped for microscope equipment for quite a long time.
A bit about "finite objectives"
Technically, they were simply optimized for one magnification. It's hard to make a lens perform well at multiple focusing distances/magnifications. You can optimize a design for multiple focusing distances, at the expense of overall resolution.
For camera lenses, this was addressed with "floating elements", like the system that let a Nikon 55mm f/2.8 Micro-Nikkor be bitingly sharp all the way from infinity to 1:2.
But for microscope objectives, there's not much reason to make it adjustable. It would help those of us who repurpose them as macro lenses, but it wouldn't have helped the microscope users they were created for. (I have a "zoom head" for my Nikon Optiphot 88 scope. It's a contraption that replaces the standard head of a high-end modular microscope and lets you crank the magnification up by and additional 2x. You can also change the eyepieces themselves).
So you end up with an objective that has one tube length where it's optimized for the highest resolution, the lowest distortion, curvature of field, etc. That's especially important in scopes like mine that was originally built for IC wafer inspection. And thus scope objectives get "mushy" when you try to use them at other tube lengths. I've cataloged which of mine work well for changing tube lengths, because it's used for a focus stacking technique called "bellows draw focusing".
The classic RMS thread macro lenses like Leitz Photars, Zeiss Luminars, and Nikon Macro Nikkors have wider "tuning", generally being pretty consistent over a 4:1 range.
Enlarger lenses (typically M39 thread) are generally optimized over a 10:1 range.
Very interesting.
I always thought it was. It's why modern lenses are so amazing.
Sometimes, but sometimes the optical engineers surprise you.
The bulk of my objective collection is Nikon CF objectives introduced for the Optiphot 66 and 88 series scopes. I have about twenty-five of that series, most of which are mounted on four turrets.
  • 4 objective BD loaded with a 5, 10, 20, 40x series with the 20 and 40 being ELWD. I have an ELD 100x that can get swapped into one position when I want more magnification. Technique at 100x is basically standard microscopy. For that matter, 40x is more like microscopy than "macro". I also have a 150x standard distance CF PLAN APO (fractional mm,
  • 4 objective BD DIC head loaded with a 5, 10, 20, 40x series of DIC objectives. Nikon DIC objectives are only standard types, no LWD/ELDW.
  • 5 objective brightfield head loaded with a 2.5, 5 DIC, 10 D(C, 20 ELWX, 40x ELWD series. This can also mount on my bellows. I don't have a way of mounting BD turrets.
  • 4 objective BD head loaded with whatever redundant objectives I'm OK to loan out.
Back to ELWD vs NA
  • 20x BD "standard" has a WD of 2.5mm and an NA 0.4
  • 20x BD ELWD has a WD of 8.5mm but that same NA 0.4
  • 40x BD "standard" has a WD 1mm, NA 0.65
  • 40x BD ELWD has a WD 9.8mm, NA 0.50
I find the 20x ELWD to be a generally superior objective to the standard working distance. However, I have to have standard working distance 20x and 40x DIC (strain-free glass and adhesives for use with polarized light) in the DIC head, because Nikon didn't make DIC ELWD objectives in the CF or CFI series. Not sure about CFI60.
Oh, two other changes that came with infinity.
The CFI scopes like Optiphot 100 and 200 have 5 objectives in their BD turrets, 6 in their brightfield turrets.
I believe they pushed that to an insane 6 and 7 for CFI60. With 7 of those massive objectives, the turret looks like an alien cow.
I only have 3 CFI objectives:
  • 5x BD
  • 10x BD DIC
  • 20x brightfield ELWD
And one CFI60
  • 20x brightfield PLAN APO. The working distance is a miniscule 1mm, but the NA is 0.75.
It's pretty complex when you get up to high end biological, metallurgical, or inspection scopes. Heck, the fact that we now have "inspection" as a separate category from "metallurgical" is a big deal. That, and Nikon still has 45mm and 60mm parfocal instruments in their catalog.
Ciao! Joseph
Re: A bit about "finite objectives"
That's also true of infinity-corrected objectives, of course.  But you said you could change the magnification.  I assume you did it with a zoom lens?
...And thus scope objectives get "mushy" when you try to use them at other tube lengths. I've cataloged which of mine work well for changing tube lengths, because it's used for a focus stacking technique called "bellows draw focusing".
Presumably you mean subject and objective in fixed positions.
...The bulk of my objective collection is Nikon CF objectives introduced for the Optiphot 66 and 88 series scopes. I have about twenty-five of that series, most of which are mounted on four turrets.
Holy smokes!  That's a lot of equipment.  I also had the plan CF objectives with an Optiphot.  I had it equipped for polarized light, phase contrast, and polarized epi-illumination.  I notice all this stuff is pretty cheap now used (but toward the high end by photography standards).
