7Artisans 4mm Fisheye - Q&A
matejphoto Forum Member • Posts: 94
I have received the 7Artisans 4mm fisheye and I will be making a youtube review.
If you have any questions you would like to have answered, please go ahead and ask.
I will test it on the M6 mark II and compare it to my Opteka 6.5mm f/2 fisheye.
First impressions:
Lens is very nicely build and quite small.
 matejphoto's gear list:matejphoto's gear list
Canon EOS M Canon EOS 80D Canon EOS R Canon EOS M6 II Canon EOS R5
Canon EOS M6
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,588
Re: 7Artisans 4mm Fisheye - Q&A
This video answers most questions https://www.youtube.com/watch?v=lCLVyLBPGPg
Did you order it from the 7artisans website in China or did you find a local distributor? I suppose import tax is a risk to consider
I would like to see some straight-up shots to see how much ground it captures to make 360° panoramas like this https://www.acapixus.dk/photography/LaowaVenus4mm_EFM/samples.htm
I gave up on in Laowa, as it was not really wide enough
And possibly we could collaborate on making a RectFish profile for the lens while I am figuring out whether to get my own.
Rgds/Kjeld
First impressions:
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
ezriel Regular Member • Posts: 414
Is this could be a good replacement for a UWA lens?
any software can make it looks perfectly straight?
 ezriel's gear list:ezriel's gear list
Nikon D90 Nikon D500 Canon EOS M6 II Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
OP matejphoto Forum Member • Posts: 94
Rgds/Kjeld
First impressions:
7Artisans sent me the lens for review. But generally in the US, big stores like B&H have them in stock pretty shortly after launch.
What do you need to create a RectFish Profile?
You probably could, but I doubt that you should. I personally would not recommend it.
If you want UWA get, depending on budget the Canon 11-22 or 10-18 (with adapter).
Fisheye lenses are great fun, but for me I see them for the special effect.
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
Will the detail resolution hold up after being stretched flat in post compared to e.g. Laowa 9mm?
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
Kjeld Olesen
Rgds/Kjeld
First impressions:
I will send you a private post
Kjeld Olesen
Sometimes you just want that extra wide that no rectilinear lens can produce, and then rectilinearizing a fisheye image can be the only option if you do not want to go into stiching.
A diagonal fisheye will of cause be better for the job as it uses the full width of the imager.
Below a couple of examples, remapped using RectFish, from a couple of recent trips
Rgds/Kjeld
St. Stephen's Basilica/Budapest
Rectilinearized @ 130° hAOV : Canon EOS M + Samyang 7.5mm fisheye
Massimo Theater / Palermo
Rectfished @ 180° hAOV: Canon EOS M + Samyang 7.5mm fisheye
Maxmolly7
Very nice examples, thanx for sharing! 🤩
YouTube review (includes vs. 6.5mm Meike)
I just published my review on youtube. Also included comparison vs. the 6.5mm Meike (also sold under Opteka name).
https://youtu.be/wgEBGWu1oFM
In summary:
Great little lens.
Very sharp.
Obviously a one trick pony but for the price I think it is worth it.
I think it is the cheapest circular fisheye that shows the whole circle on the Canon crop sensor.
