100mm with Raynox DCR vs MP-E 65mm
PhasmatosOculus Forum Member • Posts: 93
Hi all,
Body I am using is an R7
Currently have a Canon 100mm f/2.8 USM lens with Raynox DCR-250 for my macro.
I can handheld stack (especially as I use a flash to "freeze" the action) and get relatively close to insects and with the Raynox, I adjust focus/magnification via the ring manually.
I am considering a Canon MP-E 65mm 5x Macro lens - aware it is manual only. Also aware that I can go from 1:1 to 5:1 and move back and forwards for focusing.
Does anyone have experience with the latter, handheld?
If I set the MP-E to the same sort of mag produced by the former setup, will handheld be just as possible?
I am just wondering if it was upgrading to the MP-E 65mm lens (and sell on the Canon 100mm as I only use it purely for macro) as I may want the additional magnification which would be easy by a turn of the lens.
And if there are any clever people who can calculate working distances for both setups, I'd greatly appreciate that too.
M
 PhasmatosOculus's gear list:PhasmatosOculus's gear list
Canon EOS R7 Canon EF 100mm f/2.8 Macro USM Canon Extender EF 1.4x III Canon EF 100-400mm F4.5-5.6L IS II Canon RF 50mm F1.8 STM +2 more
Canon EF 100mm f/2.8 Macro USM Canon EOS R7
oneofone25
oneofone25 Senior Member • Posts: 1,586
Re: 100mm with Raynox DCR vs MP-E 65mm
PhasmatosOculus wrote:
Hi all,
I do not use Canon, however, I just read somewhere else that:
You CAN use the 100 Macro F2.8 with the Canon 1.4X teleconverter... I do it all the time. However, you have to insert an extension tube (the 12 mm one will do) between lens and extender to keep the extended front element of the extender from crunching on the rear of the lens. As long as you don't want to focus to infinity --and I gather you don't -- it works just fine. Make sure you don't stop down too much or you'll run into diffraction issues.
The reason I bring this up is this is what I do with the Olympus 60mm macro lens.  I use their 2x teleconverter with it and use a 16mm extension tube in between the teleconverter and 60mm lens acting as a coupler to attach them together,  Autofocus won't work, but focus bracketing does.  I even  use that setup with a Raynox macro filter to get anywhere from 5x to 9x magnification depending on the Raynox used.  So maybe see if that's an option for your Canon setup??
 oneofone25's gear list:oneofone25's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Samyang 16mm F2 +1 more
OP PhasmatosOculus Forum Member • Posts: 93
I’m just wanting a comparison between the two originally mentioned.
M
racketman Veteran Member • Posts: 3,160
I’ve hand held sequences of shots to produce stacked images typically 6-8 shots at f5.6 x4 mag but only when the subject has been on a flat surface and I can rest the front hand on same. Probably always going to be flash although if it’s very sunny you can try natural light with a higher ISO.
There was a guy Eddie the Bugman doing insanely detailed large stacks in the field, hand held of springtails no larger than 2mm and with TC and extension tubes added to the MPE65.
If you have the determination anything is possible.
And was that just as easy/difficult as stacking had you used the 100mm macro with Raynox dcr?
M
It’s about the same, bit bulkier of course with the full extension.
Joseph S Wisniewski Forum Pro • Posts: 35,461
My MP-E 65 experience
Hi all,
Can an R7 engage flash while you're using a zero-vibration mode? I know my Nikon Z7 can't.
Yes. I found it pleasant at 1x, but excruciating past 2x: near impossible at 5x.
The MPE-65 has a working distance of 42mm at 5x, which doesn't sound so bad until you realize that the front tube diameter is an ungodly 60mm. You will find setting up lighting to be frustrating because you run into the shadow of the lens anything closer than 35 degrees off center. You can't really change magnification on the fly because the front of the lens moves so much when you do that you'll be outside the lighting setup you had for a different magnification.
I will stick with my bellows and a 50mm f/2 Leitz Photar. The front end of the Photar is only 35mm in diameter, and the working distance at 5x on a bellows or tubes is 50mm. You can get your lights within 19 degrees of the lens axis.
Only with flash at high mag, but then again a DCR-250 on a 100mm Canon, you're looking at a WD of about 40mm at max magnification, which should be about 2.6x.
There's a massive difference in the perspective you have with your entrance pupil nearly 200mm from the subject at 1:1 with the 100mm vs. about 90mm for the MPE. Seriously, for my own work I like to be out past 100mm, and typically resort to a 200mm 1:1 macro on a 2x TC. DLAATW.
It doesn't feel that easy when you start doing it. I personally found the old setup with a Photar or Luminar on a bellows to be easier.
I sort of did that on the fly, but Canon states the MPE-65 drops to 42mm at 5x, and my calculations for the Raynox are nearly identical, but that's based on a wild guess that the focal length of the Canon 100mm at max mag is 60mm.
At least the Raynox has a smaller front: down around 50mm if you dismount it from the clip-on contraption and purchase the proper step-down rings to get you from its M43 rear threads to the M67 on the 100mm. I'd go four rings: 67-62-58-52-43.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
bclaff Forum Pro • Posts: 13,922
MP-E65 at the PhotonsToPhotos Optical Bench
Rather than derail this thread I started a separate one
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
Re: My MP-E 65 experience
Joseph,
Great points.
Note that the PhotonsToPhotos Optical Bench reports the 5x entrance pupil distance at about 71mm. I'm not sure how you arrived at your figure.
FWIW, the Canon RF100mm F2.8 L Macro IS USM at 1.4x is only 36mm in focal length.
Hi all,
The R7 can utilise mechanical shutter and electronic first curtain shutter with the flash. The IBIS does work and I have not had any issues using it handheld with the Canon 100mm USM macro and the Raynox DCR-250, even at max maginifcation.
I do have a focus rail, tripod etc for the higher mags for first light when nothing is moving, but I tend to spend a bit of time during the later hours of morning and afternoon.
I only use flash with macro so this should not be an issue
I'm wondering with practice would it be easy enough
M
