Strange focusing issue
SteveHU89 Regular Member • Posts: 119
Bought a used EF 35mm F/2 IS USM. It is pristine and everything works fine except for focusing on distance subjects with viewfinder. Short distance (like less than 3 meters or ~ 10 feet) both viewfinder and live view use produce same accurate results. Beyond that the photos taken with viewfinder create such out of focus image that I can't even tell if it's front or back focusing.
These shots are converted RAW-s with PS. Zero sharpening, NR nor other processing. I used center focus point, single shot mode. Focus was the center of the frame in both cases.
Viewfinder
Live view
Viefinder crop
Live view crop
Viewfinder
Live view
Viewfinder crop
Live view crop
Hope someone can help get to the bottom of this. Thank you in advance...
 SteveHU89's gear list:SteveHU89's gear list
Canon EOS 6D Canon EF 70-200mm F4L IS USM Canon EF 35mm F2 IS USM Canon EF 50mm F1.8 STM
Aoi Usagi Veteran Member • Posts: 3,221
Re: Strange focusing issue
The liveview image looks much more in focus than the viewfinder image.  I would suggest to use a simpler (flatter) subject for more testing.  Those tree may be too much for the 6D's AF with the lens at F2.8.  After testing, you may need to adjust the autofocus micro adjustment to get more accurate autofocus.
neilt3
neilt3 Veteran Member • Posts: 3,011
Agreed with Aoi .
For testing focus issues you need a clearly defined target , not a fuzzy ball .
Stand at 45° to a fence or wall , place a target 99° to you ( square on ) and take a test shot of that .
Standing diagonally to something will allow you to determine front or back focus issues .
You can do this with a yard stick / meter rule , but that will only show you at a close distance with a wide angle lens .
How the camera and lens behaved at distance can be very different ( as you've found ) .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
