R7 and RF 600 f11
TeeJay626 Contributing Member • Posts: 566
R7 and RF 600 f11
5
I've been on the fence with the RF 600 f11.  I'm an enthusiast wildlife shooter and my primary camera is the R7, while I also have a R10.  I have the RF 100-400 as well as my trusty EF 70-300 nano USM II.
I got the 600 a little while ago and have had mixed results.  It does poorly with BIF, and farther away subjects, but closer subjects it seems to be good.  It also seems to suffer more from heatwaves than my 100-400 on subjects at the same distance.
Anyway, here are a few test shots from earlier this week at my local wildlife refuge.  I'm not really that happy with it overall, but I think more testing is needed.  C&C welcome.
 TeeJay626's gear list:TeeJay626's gear list
Sony Cyber-shot DSC-H55 Canon EOS R7 Canon EOS R10 Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Canon EOS R10 Canon EOS R7
Avenger20 Regular Member • Posts: 179
Re: R7 and RF 600 f11
Nice pictures, but I think the RF 600mm f11 might be too much for a 30mpix APS-C (and the f11 too slow for the AF of this camera). So I was thinking about getting the RF 100-400mm f5.6-8. Is the performance and picture quality good on a R7?
R2D2 Forum Pro • Posts: 26,531
6
960mm (equiv) puts this combo in an entirely different class (of difficulty). Generally speaking, your approach needs to account for that.
The sample you posted has a shutter speed well below what I would personally recommend for that focal length (4x the equiv focal length is a good rule of thumb).
You don’t mention anything about your AF settings. For BIFs I really like Eye AF with “Auto Initial” and Case 2 with "Tracking sensitivity" set all the way to ( - ), and "Accel./decel. tracking" set all the way to ( + ). "Switching tracked subjects" all the way to ( 0 ).
I would also turn IS off for BIFs (I get higher keeper rates with it off).
If you have a filter on the lens, remove it. Also watch for the temperature layer that can set up within your lens hood. My hood has a port in the bottom of it which I keep open at all times.
Is it the AF accuracy or the IQ? Mech shutter or electronic? What are your image settings? What do you use for software? Do you shoot bursts?
That means your lens is likely not defective.
Longer focal lengths magnify heat waves too. Atmospherics can ruin the whole day.
My (maximum) optimal focal length for birding is about 800mm equiv. I’m currently shooting at 700mm (on FF). It works great for BIFs (for me). Anything much longer than that and things get a lot more tricky (very quickly). Remember that Canon itself classifies anything 400mm and above as “Super Telephoto.” You have to treat things accordingly. Your technique and settings (and shooting situations) have to be close to perfect.
I would suspect that improvements could be made on all threee fronts. Pick away at each phase and your success rate should climb steadily.
Best of luck to you!
R2
OP TeeJay626 Contributing Member • Posts: 566
The RF 100-400 is great on the R7 and R10.  That lens is on my R7 most of the time.  Also, the EF 70-300 nano USM II adapted to both cameras works very well.
I've been trying different things and techniques.  I did have, for a while, the Sigma 150-600 C and while it was much heavier, I had better success with it vs. the 600 f11.
I've been varying my shutter speeds, all the way up to 1/4000 and not seeing much difference.
I'll try Case 2 with the adjustments you mention. I do use Case 2, but at it's defaults.  Eye AF is being used.
No filter.  I do have a lens hood so I'll try shooting without it.
Mostly IQ.  When shooting BIF I use EFC to avoid rolling shutter with electronic.  I always shoot RAW and process my RAW files with DxO Pure RAW 2, edit in Lightroom and use Topaz Photo AI for any touch up work.  And yes, It do shoot in bursts.
Absolutely.  I've had that happen more than once.
R2
CameraCarl Veteran Member • Posts: 9,193
A friend had rented the 800mm f/11 and I tried it on my R5 for a few hundred bird photos in Alaska last summer. I was not happy with it. The long focal length made subject acquisition difficult for birds on the ground or in the water -- and almost impossible for birds in flight. No matter what shutter speed I used, I never got what I thought were sharp images. My best luck was with birds along the shore or swimming in the water. I really don't have many suggestions to make about how to get better images with your lens. The ones you shared are as good as any that I got. (If you're not happy, is there any chance you can return the lens?)
John Sheehy Forum Pro • Posts: 26,688
None of the OP's main complaints will be improved with a shorter, slightly-faster lens, with no larger entrance pupil.
The point of the RF600/11 (besides price) is low weight for high magnification.  The RF100-400 will only be more flexible, allowing one to shoot closer and larger subjects, or more room to track an active subject in the frame.  Those certainly have value, and AF may be a little faster with the zoom if one doesn't add the RF1.4x.  When one is focal-length-limited, however, and one doesn't need to stop down past f/11, the RF600/11 should be expected to give slightly better subject quality.
The RF600/11 has a very slightly larger entrance pupil, and should get slightly more total light from the subject, and slightly higher background blur, and slightly less diffraction, and maybe even less lens aberration, with the prime design.
400/8 = 50mm pupil diameter.
600/11 = 53mm pupil diameter.
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
Dave C 150 Regular Member • Posts: 320
https://www.flickr.com/photos/dcweather/
What is the reason why higher mp resolution will give inferior results? I've read this before and understand with respect to noise but I am not clear why it would be given the APS -C would need to be cropped less to get the same size image. (Not disagreeing by the way, just wondering why).
 Dave C 150's gear list:Dave C 150's gear list
Sony RX10 IV Pentax Q Nikon D500 Canon EOS R7 Sigma 105mm F2.8 EX DG OS HSM +6 more
Is that IBIS, lens or both? I am experimenting still with the R7 and 100-400mm RF. At what shutter speed would you consider turning it on again. (Sometimes we are often forced to lower than ideal shutter speeds in the UK
Sittatunga Veteran Member • Posts: 5,406
With R series cameras it's all or nothing. Turning the lens IS off also turns off the IBIS.
Ah, thanks, I didn't know that.
