Canon rebel t7 paired with 70-200 2.8 mid level lens
Livin The Life New Member • Posts: 1
Okay. I’m a first timer. Shooting a bull bucking tonight, starts at 4. I’m figuring it’ll go into evening. What is the best way to use this lens?
Canon EOS Rebel T7 (EOS 2000D)
tdbmd Senior Member • Posts: 1,547
Re: Canon rebel t7 paired with 70-200 2.8 mid level lens
If it were me, I would go into Manual mode, set the aperture to f2.8 or 3.2, depending on what you can get away with.  Set shutter speed to something fast enough to freeze the action, maybe 1/800 to start and see what that gives you.  I generally use auto ISO for most things.  I don't know how well the T7 handles higher ISO, so try to adjust aperture/shutter speed to keep the ISO at maybe 6400 or less?  Depends on the lighting in your arena.  Should be easy before sunset but after that, who knows...
 tdbmd's gear list:tdbmd's gear list
Canon EOS 7D Mark II Canon EOS Rebel T8i (EOS 850D) Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +11 more
