R7 at the Edwards Air Force Base airshow
Started 5 months ago | Photos
JayLT4 Regular Member • Posts: 288
23
I had the opportunity to spend the weekend out at Edwards Air Force base for their Aerospace Valley Airshow over the weekend.  I took both the R7 and the R5, but planned on using the R7 for most of the flight shots and the R5 for most of the statics and taxi shots.
The R7 had the RF 100-500 and the R5 had either the 14-35 or the 24-105.
The lighting was pretty rough at times as the sun was in front and to the right but moved off a bit towards the afternoon.  However, the clouds on Saturday made up for the issues with the sun.  Some near-perfect skies in my opinion.  Sunday, on the other hand, was completely void of clouds which made things a bit more difficult as it was a bit hazy from the bright sun.  But you work with what you have.
Overall it was a great show.  Was able to see a lot of things I had never seen in the air before, and the NASA jets rounded things out quite well.
I shot mainly on shutter-priority, with a mixture of electronic shutter for jets (and no opposing passes) and EFCS for props (and opposing passes).  Multiple buttons set for different focus options helped get a decent composition with varying situations and overall the R7 did a very good job, especially considering the conditions.
Still have tons of shots to sort through as I've barely looked at Sunday and any of the static display shots just yet.
DarkStar, TopGun:Mavrick movie prop
 JayLT4's gear list:JayLT4's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon MP-E 65mm f/2.5 1-5x Macro Canon EF 16-35mm F4L IS USM +4 more
Comment & critique:
Canon EOS R5 Canon EOS R7
R2D2 Forum Pro • Posts: 26,536
Re: R7 at the Edwards Air Force Base airshow
Outstanding stuff!  Partly cloudy skies are the BEST!
Can’t wait to see more!  Thanks for posting.
R2
ps. Tell us about your AF settings!
Occams Razor Senior Member • Posts: 1,252
Outstanding set of arial photos   I heard about the show on the news but I’m 90 minutes away and was very busy on that weekend   Your shots really make me regret missing the show .
Thanks for sharing
Randy
 Occams Razor's gear list:Occams Razor's gear list
Canon EOS Rebel SL2 Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 16-35mm F4L IS USM +4 more
Bramble9 Regular Member • Posts: 211
A really excellent set of air show photos-- but I must admit that I think my fave of the bunch is number 1-- really nice work w/ the sun in the frame.  (I'm a sunset shooter too).  Thanks for posting.
Bramble9
 Bramble9's gear list:Bramble9's gear list
Canon EOS R5 Canon EOS R7 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM +1 more
PHAER
PHAER Regular Member • Posts: 104
Wonderful, wonderful shots! Congrats! And what a selection of birds! And seeing (and hearing) a 747 with its classic engines nowadays is so great!!
 PHAER's gear list:PHAER's gear list
Sony RX100 III Canon EOS RP Canon EF 70-200mm F4L IS USM Tamron SP 24-70mm F2.8 Di VC USD Canon EOS 600D +9 more
Karl_Guttag Senior Member • Posts: 1,884
Thanks for sharing some great pictures. I'm getting ready for a couple of airshows in Houston and Dallas, so I have some "technical" questions.
First, are the pictures you posted "cropped" or "reduced" as they are much smaller than the R7's resolution?  My guess, looking at the focal length, framing, and clarity of the shots (you said there was haze), is that they are mostly reduced.
I use a similar strategy but with the RP with a wider lens (the RF24-240)  for "static" shots and the R5 with the RF100-500 for flying shots.
Yes, it seems like airshows deliberately have you shooting into the sun😊.  I primarily prefer to shoot WW2 planes, so I want the sun to illuminate the front of the prop to see the prop and its yellow tips better. But as you say, you must work with what they give you.
I've been shooting with M mode with Auto-ISO, but am thinking about switching to Tv with ISO fixed to 100. And then using an ND filter when shooting prop planes to keep the f-number from getting too high.
I came close to getting the R7 for the extra crop factor but decided to stick with the R5 due to the buffer size and frame rate and less rolling shutter in electronic shutter mode. I like back-button focus with tracking (Vehicle or None) for airshows so I can concentrate on zoom and framing and not keeping a focus target on the plane.
I almost exclusively use electronic shutter for prop planes, but then I typically shoot at 1/60th to 1/125th, so the prop is more of a blur that avoids a warped prop due to the rolling shutter. I'm firing off long bursts of shots to get a few pics where the plane is acceptably sharp with a good amount of the prop disk. I use a 2-stop ND filter when shooting props on a sunny day to keep the f-number in the f11 range.
I'm curious why you decided to use EFCS for the prop planes.  Is it to prevent the warping of the prop or for some other reason?  I assume it is the same reason for planes opposing each other (I will try this at the next airshow where the Blue Angles will be flying).
I'm also curious how you have found the handling of the R7 vs. R5 for airshow photography.
I feel for you. I took about 10,000 pictures daily for two days each in the last two airshows. Shooting at low shutter speeds while panning with planes (with a "hit" rate of 1 in 10 to 1 in 20), I have many shots to weed out.
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
BobKnDP Senior Member • Posts: 3,140
Nice.
I thought that SOFIA had been scrapped. Good to know the aircraft still exists, but I doubt that it's still doing IR astronomy.
OP JayLT4 Regular Member • Posts: 288
Thanks for sharing
Thanks!  I drove about 6 hours in from Phoenix for the weekend.  I don't have a ton of free time and I wanted one last airshow for the year and couldn't pass up Edwards since it was the first time in 13 years they held a show.  I think they said the next one would likely be in 2024, but that's tentative of course!
R2
Thanks! I agree on the clouds, they make such a difference.
For AF on the R7 I set the following;
Global Settings;
Servo AF
Case 2 (-1 tracking, +1 accel/decel tracking)
Tracking - Off
Subject Detection - Off
AF Method - single-point with all surround points
Shutter button - AF+Metering start (uses all global settings)
AF-ON button - AF+Metering start
AF Method - Zone 3
Subject Detection - On
Subject to detect - None
Tracking - On
* Button - AF+Metering start
AF Method - Full
Tracking - On
For prop planes I use the shutter button AF as I don't like using tracking with them, I find it easier to pan with prop planes with a single point and no tracking as it just helps me keep everything centered
For jets, especially formations, I'll use one of the Zone options on the back buttons and tracking to allow me easier options to re-compose if needed
BobKnDP wrote:
Nice.
This was actually her last scheduled flight, and only show she was ever in.  Pretty special moment for a lot of people there that had a big hand in that plane
They're all reduced in size, I always tend to reduce the size of shots I post in forums just to make it easier to upload.  There is some cropping on them, especially the smaller prop-planes, but not much at all and most are at or over 6000 on the long edge in full size
Just a luck of the draw with position and time of year.  When I was at NAF El Centro early this year it was perfect, sun was at my back all day long!
Yeah, I noticed the aperture creeping way up, especially on Sunday with all the extra sun.  For props, and ND filter wouldn't be a back way to go to help dial that back!
I didn't have an issue with the buffer on the R7.  I shot in CRAW and at 15FPS in mechanical and e-shutter, with that I found with a nice V90 SD card I could get a good 5-6 seconds of straight shooting without hitting the buffer, and I never hold for that long in a single string.
My panning kind of sucks, so I tend to err on the side of slightly higher shutter speeds to help offset it!
On the R7 rolling shutter is a much bigger, and much more visible issue, compared to the R5.  The R5 can shoot props, and if you look close you can see a bit of skewing, but with the R7 it's way too apparent.  Same with opposing passes, one place will be good they other will look all stretched out.  EFCS mitigates that.  I could shoot full mechanical, but EFCS has just always been my preference.
The weight made it a very easy show to deal with all day.  However, I miss having a grip.  My hands are a bit too big and my pink has to sit under the camera, which isn't horrible, but after a while it's also not the most comfortable thing.
What I really liked on the R7 was that I could shoot a full battery and not worry about the FPS dropping in mechanical/EFCS mode.  Also, having the fake shutter sound really helps remind you how long you're holding the button down with the electronic shutter.
The other obvious benefit is the field of view of the R7 and the 100-500.  As long as the planes were off the ground I could get nice shots at the full 500mm and not worry about heat mirages.  The haze from the sun, well, it is what it is so you do your best to pick a good spot in the morning to shoot from!
Exactly, the prop plane shots always take a long time to weed through, with jet you can pretty much just pick the one(s) you like and be done with it!
shadowlands
shadowlands Senior Member • Posts: 1,487
Stunning images!!! Well done!!!!
CANON EOS R6
CANON RF 28-70MM F2.0 L IS USM
CANON RF 70-200MM F2.8 L IS USM
https://www.flickr.com/photos/darrenwb/
 shadowlands's gear list:shadowlands's gear list
Canon EOS R5 Canon RF 28-70mm F2L USM Canon RF 70-200mm F2.8L IS USM
Thanks, (selected responses below to reduce space)
I'm also very aware of wind socks. On both of my last two airshows, they changed landing directions. My favorite shots are at take-off and landing.
Applying the "Sunny 16" rule (at f16 shutter speed = 1/ISO), a 2-stop ND filter supports approximately 1/60th at f11. With prop planes, I have been shooting in Auto-ISO and f11, shooting between 1/60th and 1/125th and letting the ISO vary.
I'm thinking about removing the filter and shooting at a higher f-number when planes are in formation to get more depth of field. I think the DoF gain will be more than the diffraction loss. I may also up the shutter speed as you can see (on closeup) the planes are bouncing about relative to each other at lower shutter speeds, giving up prop blur for sharper images. Plus the fighter plane jockeys tend to be hard to track and will do better with more shutter speed.
That's good to know about the buffer. The R7 was getting criticism for its buffer size. I'm using the Express B card for most of my shooting with cRAW and I hit the buffer limit sometimes.
I'm working on panning and practicing (at the local airport with jets on landing). I'm using a combination of better technique (tuck arms in and swivel the body), IS Mode 2 on the RF100-500, electronic shutter (which seems to help tracking in the viewfinder), and bursts (to give me a good shot).
Additionally, I have found that Topaz AI motion blur correction can make a "close" shot look very good. I typically use PS layers to selectively apply the Topaz result.
The rolling shutter difference was my primary reason not to get the R7. I'm hoping Canon will eventually come out with a high-megapixel APS-C camera with little to no rolling shutter (basically what the wildlife shooters also want).
I found that 140 to 700mm on a full frame would be ideal for the airshows I have been to. Unfortunately, the range limit with the 1.4x TC on the RF100-500 is a big problem in this regard. I will only put on the TC when there are only the smaller fighter planes, and it is a hassle and a half to take on and off under the gun to do it quickly (reminds me, I need to practice this before the next air show).
LeicaEye Forum Pro • Posts: 10,560
Hard work and understanding the equipment is foremost in these excellent images...  Well done..     Regards.  L
If you understand everything, you must be misinformed...
JayLT4 wrote:
Thanks for sharing your settings, even though they seem quite different from what I use.
R2
Global Settings;
Servo AF
Tracking - Off
I find it much easier to use subject tracking (none or vehicle) with the R5.  It allows me to concentrate on framing and zooming. I found that with a point-focus mode (even the expanded), I would concentrate too much on keeping the plane in a focus area, and then it would be framed poorly as the plane passed by.
With tracking AF, I get the focus going (back button focus) and then press the shutter button to start shooting and let the camera worry about tracking the plane. I don't think I have ever lost focus of a plane once locked on. Framing became so much easier because I was not worried about losing focus.
AF Method - Zone 3
Tracking - On
AF Method - Full
Tracking - On
Very different from my experience. As per above, I use back-button AF with tracking and get the focus locked on and tracking before I ever hit the shutter button. Sometimes I am waiting on the plane to get to a particular point in the take-off or landing sequence, get closer, or make some other maneuver.
I have my tracking set to start from the current focus point. If I raise the lens and it won't lock (which happens occasionally, and I don't want to take the time to move the focus starting point), I hit my second back button, which is set to eye tracking, and it will lock on something (a plane if there is one in the sky). I then switch the AF button to normal tracking as "eye detection" can jump from plane to plane.
Interesting that you use both the shutter button and back button focusing (if I understand you). Once I changed to back button, that was it for me, as I didn't want to confuse my "muscle memory." I now reflexively hit the back button. The downside of back button is that you have to hit two buttons for continuous shooting (along with the risk of misfocusing if you don't hit is when you need to).
I may be missing something or misunderstanding, but I understand there is no "tracking" with zone AF as tracking only works with the subject tracking modes.  It may not make a difference in common use if the plane is in the zone.
R2
Global Settings;
Servo AF
Tracking - Off
AF Method - Zone 3
Tracking - On
AF Method - Full
Tracking - On
Whoa, thanks very much.  Interesting take on things.  From reading here, it looks like everyone has a slightly different approach .  Indeed, many different ways to skin the proverbial cat.  Definitely worked for you!
Alas.  I still haven’t finished my pics from the show I went to this summer.  I better get crackin’!  Thanks for the inspiration!  Again, great pics!
R2
BirdShooter7 Veteran Member • Posts: 9,127
Absolutely beautiful shots here, thanks very much for sharing!
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
romeo_kc10fe Forum Member • Posts: 97
If you didn't get a shot of the B-1B barrel roll it was a wasted trip...lol!
 romeo_kc10fe's gear list:romeo_kc10fe's gear list
Canon EF 400mm f/4.0 DO IS USM
