Understading Photons to Photos graph for my X-S10 (or any other camera)
Started 6 months ago | Questions
Tom45
Tom45 Forum Member • Posts: 67
So recently I've noticed that casual snap and camera's EV being on 0 just doesn't cut it for some scenes that have a lot of dynamic range, and I'm reading around about it, trying to learn more how to protect the highlights and use the histo.
But also it seems that ISO plays a role and I found the Photons to Photos website and two graphs with X-S10 data plotted.
One is Photographic Dynamic Range vs Iso, another is Photographc Dynamic Range Shadow improvement vs Iso.
I went thru few videos that comment on these graphs for astrophotography but I got lost in the jargon...so to put it simply, what would be the main takeaway for my camera regarding these two graphs?
On the PDR vs ISO graph, there's a slight bump from 400 to 500 ISO, 500 having slightly higher PDR number than 400...what would that signify in real life scenario and use case, should I avoid ISO 400 or something else?
On the other graph, PDRSI vs ISO, ISO 400 has 0.07EV value, ISO 500 has 0.49...again I'm trying to understand what does that imply.
If someone can simplify this to me, would be grateful thanks
Squaring the circles
 Tom45's gear list:Tom45's gear list
Fujifilm X-S10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm II Sigma 56mm F1.4 DC DN | C (X-mount)
Ysarex
Ysarex Veteran Member • Posts: 3,354
Re: Understading Photons to Photos graph for my X-S10 (or any other camera)
PDR graph: You lose the ability to record dynamic range as you raise the ISO. A scene with very high DR can exceed your camera's max capacity of 10.4 stops at ISO 160. Raise ISO and that gap gets bigger.
PDR (Shadow Improvement) graph: Your camera graphs flat which means it's effectively ISO invariant. There's something else for you to research. It's pretty esoteric and I wouldn't waste too much time.
Fuji buys their sensors from Sony. Sony bought a patent from Aptina (now ON Semiconductor) for what is called a dual gain or dual impedance sensor and that's the type of sensor in your camera.
It's almost like your camera has two sensors. It has two read channels with different impedance levels and reading the sensor can be switched between the channels. The bump you see in those graphs is the switch between channels. The first channel is optimized for more exposure (low ISO values) and the second channel is optimized for less exposure (higher ISO values). Fuji throws the switch in your camera for ISO values above 400.
It's a real difference but not a big difference. I wouldn't modify my behavior for it.
Zinch Senior Member • Posts: 1,122
I wouldn't spend too much time looking at the exact numbers. That page has more use when you compare cameras IMO.
At the end, what you have to do is try to use as low ISO as posible while avoiding clipping highlights (shadow recovery is awesome nowadays). If you believe the scene requieres more dinamic range, just use exposure bracketing to merge in post.
 Zinch's gear list:Zinch's gear list
Fujifilm X-T4 Voigtlander 35mm F1.2 Nokton Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R Fujifilm XF 16-80mm F4 +3 more
