Question about the video camera on body strap?
Gary3000 Senior Member • Posts: 1,510
Re: Question about the video camera on body strap?
Sean Nelson wrote:
Gary3000 wrote:
nobody wants to pack a helmet in their suitcase for travels, not when they can do better with a skinny little collapsable stick that can shoot better video!
It doesn't have to be an actual helmet, it can be a head strap.
....but with a head strap,.  you can't wear a hat.  (and your videos will still look worse).
and who wants to walk around as a tourist with a camera strapped to their head?  and outside of sports, when was the last time any of you saw such a thing?
you guys are kinda grasping on an inferior option.
 Gary3000's gear list:Gary3000's gear list
Sony RX100 V Canon EOS 5D Mark II Sony a6500 Canon PowerShot G12 Canon PowerShot S110 +14 more
Sean Nelson
Sean Nelson Forum Pro • Posts: 16,109
To each their own...
Have you done so yourself? or even know anyone who has done so?
guessing the answer is “no but..”
and if so..perhaps there’s a pretty good reason
Sean Nelson
https://www.youtube.com/watch?v=SDVXsMo8kyM
DMKAlex
DMKAlex Veteran Member • Posts: 6,721
Wouldn't the guy get a stiff neck after 5 minutes?
 DMKAlex's gear list:DMKAlex's gear list
Panasonic GH5 Panasonic Leica Summilux DG 25mm F1.4 Samyang 7.5mm F3.5 Fisheye Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Leica DG 50-200mm F2.8-4 +2 more
-  that is not a tourist video,
-nor are there any long duration shots, it's an edit.
- nor does it hold a candle to the OPs example video.
There's a reason why in that example, the professional did not go with a helmet-cam.
Sean Nelson
The "guy" is me. No, I didn't get a stiff neck, I was perfectly fine just as I am when I wear my bike helmet for actual biking.
I wore the helmet with the camera running in time lapse mode for the entire 2 1-/2 hour duration of the 10km fun run. In fact, I wore it while biking from home to the run, while waiting for the run to start, during the run, and then while I biked back home again. What you see in the video are excerpts from the captured footage.
It was powered via USB cable to a power pack I carried in my pocket. I also carried a handheld camera for selfies and other shots.
