Re: Getting Topaz AI instead of an OM-1 ?
Stefandreas wrote:
Hi, I tried to treat the Raw files in Photo Lab 6 but am not experienced in denoising. So the results clearly looked worse than the JPEG.
Also I tried to compare treating the Raw file with Topaz AI versus treating the JPEG with Topaz AI - and very very clearly the Topaz worked better on the JPEG than on the Raw. In Raw it washed out all the details whereas in JPEG the results were more subtle.
I really played around with Raw a lot this last days and I cannot confirm your assumption that Raw processing will result in a much better output taking the example below. Maybe a Raw master can but I cannot, spending 30 minutes on Photo Lab 6 newest denoising models. The Raw already contains very funky artefacts which are not easy to correct and frankly: the Olympus JPEG really does a good job. At least better than myself.
Anyway, I think I jump the boat for the OM-1 for the reason of better JPEG in high ISO, overall AF speed and accuracy, animal AF AI, pro capture mode for Leica lenses, better viewfinder. Also EM-10 II as a second body is not good, can’t operate it in the dark, too fiddly, and sensor output is too different from EM-1 II . So first body OM-1 and second EM-1 II makes sense.
Thanks a lot,
Stefan
Serguei Palto wrote:
Lez325 wrote:
Original image - LOOK AT BOTH IMAGES AS original SIZE TO SEE THE DIFFERENECES
2 mins in Topaz- a very usable program
Les
Both are just terrible due to artifacts from AI. I am convinced that RAW processed in Adobe PS with just default color denoise would be significantly better.
Let me clarify my point on examples below, which are the hard crops of Raw processed image using different RAW converters. The image is taken at ISO 25600 using G9 camera.
#1. This is the output from Adobe Raw with no denoise. The image does demonstrate an intensive color and luminance noise. At the same time the image shows the maximum details with no artifacts (hair and face skin are realistic)
#2. This is the output from Adobe Raw with the default color denoise. Color noise is completely removed. Some loosing of chrominance is quite visible. All the fine details remain. Artifacts are absent!
#3. This is the output from Adobe Raw with both color denoise (10 units) and luminance denoise (60 units). Due to lower color denoise the chrominance is improved compared to #2. The luminance noise is significantly suppressed and some loosing fine details takes place. Artifacts are absent!
#4. Output from DXO PhotoLab 6 with DeepPrimeXD technology. Color and Luminance noise is well removed. Loosing the chrominance is well visible. Huge number of artifacts, which does not allow to consider the image as acceptable (Hairs are far from realistic; terrible skin artifacts). Actually, the image is ruined!
#5. Output from Topaz DeNoise AI v.3.6.2 with raw model. Color and Luminance noise is well removed. Chrominance is still OK. Huge number of artifacts. Hairs have nothing with the reality, while artifacts differ from the DXO case ; many skin artifacts). The image is killed!
#6. Output from Topaz DeNoise AI v.3.6.2 with low light model. Luminance noise is well removed, but loosing the details in some areas is well visible. Color noise removal is not very good (violet patches remain). Number of artifacts is low, but they still exist at careful study.
Conclusion.
The best in this comparison is Adobe Raw converter - no artifacts; exellent control for the color noise; quite good results with luminance denoise.
Both DXO PL6 and Topaz Denoise AI (raw model) are not acceptable due to artifacts.
The best of AI denoise models is Topaz low light model, which provides lowest number of artifacts. Nevertheless the Adobe RAW is ahead due to the most realistic output.
#1 Hard crop of the image from Adobe PS 2021; no denoise is applyed
#2 Hard crop of the image from Adobe PS 2021; color denoise of 20 units is applyed; No luminance denoise
#3 Hard crop of the image from Adobe PS 2021; color denoise of 10 units is applyed; luminance denoise of 60 units
#4 Hard crop of the image from DXO PhotoLab 6; Denoise by DeepPrimeXD
#5 Hard crop of the image from TopazDenoise AI v.3.6.2; Raw model default +original details restore (50 units)
#6 Hard crop of the image from TopazDenoise AI v.3.6.2; Low light model default +original details restore (50 units)
