best used Powershot for close ups?
OpticsEngineer Veteran Member • Posts: 7,822
I am looking for a low cost solution to take photos of various small objects.  Mostly optics ranging down to half an inch in diameter.   Is there a particular Canon Powershot I could find used that would be best for that.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Pentax *ist D +27 more
arrow501 Senior Member • Posts: 1,030
Re: best used Powershot for close ups?
Something like an A480 is the cheapest I can think of if you don't want anything beyond Program mode. The lens starts at 37mm equivalent and can focus as close as 1cm.
https://www.dpreview.com/products/canon/compacts/canon_a480
 arrow501's gear list:arrow501's gear list
Canon PowerShot SX240 HS Sony RX100 Panasonic Lumix DMC-FZ300
OP OpticsEngineer Veteran Member • Posts: 7,822
Thanks. I saw one of those at the thrift store the other day. I will go see if it is still there.
jackwelch Senior Member • Posts: 1,088
You might want to check out the mobile thread. Some of these phones come with great macro cameras. Just have to view some samples from the mobile thread section.
YehudaKatz Senior Member • Posts: 2,512
SX50.
No text.
 YehudaKatz's gear list:YehudaKatz's gear list
Canon EOS 6D Canon EOS M50 Canon EF 24-105mm f/4L IS USM Canon EF-M 22mm f/2 STM
Cyril Catt Veteran Member • Posts: 5,453
The Canon TX1 from 2007 has a Super Macro mode that allows it to focus as close as the front of the lens
Cyril
 Cyril Catt's gear list:Cyril Catt's gear list
Canon PowerShot TX1 Panasonic Lumix DMC-LX7 Apple iPhone 13 Pro Max +3 more
Great examples. thank you.
No text.
Re: Great examples. thank you.
YehudaKatz wrote:
It also had an acceptable 741 mm equivalent zoom
Cairo rooftops and distant Pyramids. TX1 at widest FL, 39mm
Zoom from same position: Pyramids through heat haze. 741mm FL
Unfortunately, no TX2! followed it.
Cyril
